Coal combustion model.
More...
◆ cs_coal_add_property_fields()
| void cs_coal_add_property_fields |
void | | ) |
Add property fields for pulverized coal combustion model.
◆ cs_coal_add_variable_fields()
| void cs_coal_add_variable_fields |
void | | ) |
Add variable fields for pulverized coal combustion model.
◆ cs_coal_model_get_type()
Return coal combustion model type.
- Returns
- type of active coal combustion model (CS_COMBUSTION_COAL_NONE if model not active)
◆ cs_coal_model_set_model()
Activate coal combustion model.
- Returns
- pointer to coal combustion model structure.
- Parameters
| [in] | type | coal combustion model type |
◆ cs_coal_rad_transfer_st()
Take in account the radiative source terms in the particle equation of a given class for pulverized coal flame.
- Parameters
| [in] | f | pointer to scalar field |
| [in,out] | smbrs | right and side (explicit ST contribution) |
| [in,out] | rovsdt | system diagonal (implicit ST contribution) |
◆ cs_coal_setup()
| void cs_coal_setup |
void | | ) |
Specific setup operations for pulverized coal combustion model.
◆ cs_combustion_coal_log_setup()
| void cs_combustion_coal_log_setup |
void | | ) |
Print pulverized combustion module options to setup.log.
◆ cs_coal_atom_id_c
| const int cs_coal_atom_id_c = 0 |
◆ cs_coal_atom_id_h
| const int cs_coal_atom_id_h = 1 |
◆ cs_coal_atom_id_n
| const int cs_coal_atom_id_n = 3 |
◆ cs_coal_atom_id_o
| const int cs_coal_atom_id_o = 2 |
◆ cs_coal_atom_id_s
| const int cs_coal_atom_id_s = 4 |
◆ cs_coal_epsilon
| const double cs_coal_epsilon = 1.e-8 |
◆ cs_coal_prefth
| const double cs_coal_prefth = 1.01325e5 |
reference pressure for molar volume
◆ cs_coal_trefth
| const double cs_coal_trefth = 25. + 273.15 |
molar volume under normal pressure and temperature conditions (1 atmosphere, 0 degres C) in m-3
reference temperature for molar volume
◆ cs_coal_volmol
| const double cs_coal_volmol = 22.41e-3 |
) in
◆ cs_glob_coal_model
Coal combustion model parameters structure
