Introduction
Compatible Discrete Operator (CDO) and Hybrid High-Order (HHO) schemes are available in code_saturne as alternative space discretizations to the legacy Finite Volumes (FV) schemes. These are new generation of space discretizations dedicated to polyhedral meshes. The capabilities of these schemes in terms of physical modelling are limited compared to the legacy FV schemes.
Overview
With CDO schemes, the resolution of the following models/equations are available:
- User-defined scalar-valued or vector-valued equations with
- unsteady term
- advection term (the advection-field can be user-defined or one retrieves the mass flux from the Navier–Stokes equations or the Darcy velocity from the Richards equation for instance)
- diffusion term with a homogeneous or heterogeneous + isotropic/orthotropic or anisotropic diffusivity tensor
- reaction term (also called implicit source term in the FV parts of this documentation)
- source terms (also called explicit source term in the FV parts of this documentation)
- Steady/unsteady Stokes or Navier–Stokes equations in a laminar flow regime : NavSto module
- Several velocity/pressure coupling algorithms are available: monolithic, artifical compressibility or prediction/correction algorithm
- Please refer to the dedicated page for more details.
- Thermal systems with the possibility to model phase-change (liquid/solid)
- Groundwater flows: GWF module
- This module computes the Darcy velocity from the hydraulic state of the soil seen as porous media and can advect tracers (possibly radioactive tracers) in that soil.
- Solidification process:
- This module relies on the NavSto module and the Thermal module. Phase transitions between solid and liquid states (solidification or melting) are taken into account.
- Segregation phenomena can be considered with binary alloys
- Wall distance computations.
- Maxwell module. This is an on-going work. Up to now, electro-static and magneto-static problems are available.
Moreover, it is possible to setup advanced SLES (Sparse Linear Equation Solver) settings. More details are available here
To get started
A simple example relying on the resolution of the Laplace equation (steady isotropic diffusion equation with Dirichlet boundary conditions) in a cube with CDO schemes is available here. This is a good starting point for beginers.
Case settings for CDO/HHO schemes
To set-up a CDO computation, one has to update the cs_user_parameters.c file and edit successively the following functions
In addition, volume or boundary zones useful to set properties, equations, etc. are defined either thanks to the GUI or by editing the function cs_user_zones for more advanced definitions from the file cs_user_zones.c. This is similar to what is done with the legacy FV schemes.
More precisely, in each function above-mentioned the following settings can be done:
- cs_user_model
- Activation of CDO/HHO schemes,
- Definition of the domain boundaries
- Add new user-defined equations
- Add new user-defined advection fields
- Add new user-defined properties
- Activate predefined modules (GWF, solidification, Navier–Stokes, thermal system or wall-distance computation)
- cs_user_parameters
- Definition of the time stepping strategy (if different from the one pre-defined in th GUI)
- Definition of the logging/restart frequency
- Update of the numerical settings of each equation thanks to cs_equation_param_set (including the way to solve the linear or the non-linear equations).
- cs_user_finalize_setup
- Complete the definition of advection fields
- Complete the definition of properties.
- Complete the definition of an equation
- Definition of boundary conditions
- Definition of initial conditions
- Defintion of source terms,
- Activate predefined terms of a user-defined equation
- The unsteady term by adding a link between an equation to a property
- The advection term by adding a link to an advection field
- The diffusion term by adding a link to a property
- The reaction term by adding a link to a property
Settings done in cs_user_model()
Activation of the CDO/HHO part
The very first step is to activate the CDO module in the function cs_user_model There are two ways to switch on CDO/HHO schemes:
- CS_PARAM_CDO_MODE_ONLY for a usage of CDO or HHO in stand-lone (i.e. without the legacy Finite Volume approach)
- CS_PARAM_CDO_MODE_WITH_FV for a usage which can share some equations/models solved with CDO/HHO schemes and some other equations/models solved with the legacy Finite Volume approach.
CDO/HHO schemes can be activated within this function as follows:
void cs_param_cdo_mode_set(cs_param_cdo_mode_t mode)
Set the global variable storing the mode of activation to apply to CDO/HHO schemes....
Definition: cs_param_cdo.cpp:87
@ CS_PARAM_CDO_MODE_ONLY
Definition: cs_param_cdo.h:98
Domain boundaries
Domain boundaries are useful for the (Navier-)Stokes equations or for the computation of the wall distance. Several types of domain boundaries can be defined. They are gathered in cs_boundary_type_t (a flag built from a set of predefined bits)
The definition of the domain boundaries for CDO/HHO schemes is performed in two steps: (1) set the default boundary and then add other boundaries which do not fit the default one. The two possible default domain boundaries are CS_BOUNDARY_WALL or CS_BOUNDARY_SYMMETRY Here is a first example.
void cs_boundary_set_default(cs_boundary_t *boundaries, cs_boundary_type_t type)
Set the default boundary related to the given cs_boundary_t structure.
Definition: cs_boundary.cpp:429
void cs_boundary_add(cs_boundary_t *bdy, cs_boundary_type_t type, const char *zone_name)
Add a new boundary type for a given boundary zone.
Definition: cs_boundary.cpp:505
@ CS_BOUNDARY_SYMMETRY
Definition: cs_boundary.h:89
@ CS_BOUNDARY_WALL
Definition: cs_boundary.h:80
cs_domain_t * cs_glob_domain
Definition: cs_domain.cpp:89
Structure storing information related to the "physical" boundaries associated with the computational ...
Definition: cs_boundary.h:155
Definition: cs_domain.h:129
cs_boundary_t * boundaries
Definition: cs_domain.h:152
Here is a second example.
"inlet_faces");
"outlet_faces");
@ CS_BOUNDARY_OUTLET
Definition: cs_boundary.h:86
@ CS_BOUNDARY_INLET
Definition: cs_boundary.h:83
@ CS_BOUNDARY_IMPOSED_VEL
Definition: cs_boundary.h:101
Activate predefined equations
Several predefined models are available (and thus equation or set of equations). When activating a predefined module, this implies:
- adding equations and variable fields;
- adding properties (and sometimes an advection field);
- adapting the default numerical settings of the added equations to get more relevant settings.
Navier-Stokes (NavSto module)
Please refer to the dedicated documentation available here.
Groundwater flows (GWF)
Solidification/melting module
Thermal system
The activation of the thermal module yields the following actions:
- Add an equation called "thermal_equation" (the name of the associated variable depends on the choice of the variable, by default, the variable is "temperature")
- Add the properties "mass_density", "thermal_capacity" and "thermal_conductivity"
For the thermal equation, the default boundary condition is a no flux (i.e. a homogeneous Neumann boundary condition). Here is the simplest example to activate the thermal module.
0,
0);
cs_thermal_system_t * cs_thermal_system_activate(cs_thermal_model_type_t model, cs_flag_t numeric, cs_flag_t post)
Allocate and initialize the thermal system.
Definition: cs_thermal_system.cpp:292
The first parameter is a flag to describe the thermal model to consider. This flag can be built from the following tags (cs_thermal_model_type_bit_t)
To specify the choice of the variable used in the thermal model (by default, the temperature in Kelvin). This can be modified by adding the tag
and to change the main variable use the one of the following tag
The two previous options are not fully implemented.
The second parameter is a flag related to the numerical aspects. There is no tag available up to now.
The third parameter is a flag related to the activation of automatic post-processings.
Wall-distance computation
It is possible to activate the computation of the distance to the wall using CDO schemes (CDO vertex-based schemes are used) as follows:
void cs_walldistance_activate(void)
Activate the future computation of the wall distance.
Definition: cs_walldistance.cpp:425
Add a property
User-defined properties are added thanks to a call to the function cs_property_add in cs_user_model Here are several examples:
cs_property_t * cs_property_add(const char *name, cs_property_type_t type)
Create and initialize a new property structure.
Definition: cs_property.cpp:1047
#define CS_PROPERTY_ISO
Definition: cs_property.h:75
#define CS_PROPERTY_ANISO
Definition: cs_property.h:88
The function cs_property_add returns a pointer to a cs_property_t structure which can be used to set advanced parameters. If the pointer to a cs_property_t structure is not available, this can be easily recover thanks to a call to the function cs_property_by_name
To enable the computation of the Fourier number related to a given property in an unsteady simulation proceed as follows:
cs_property_t * cs_property_by_name(const char *name)
Find the related property definition from its name.
Definition: cs_property.cpp:1179
void cs_property_set_option(cs_property_t *pty, cs_property_key_t key)
Set optional parameters related to a cs_property_t structure.
Definition: cs_property.cpp:1226
@ CS_PTYKEY_POST_FOURIER
Definition: cs_property.h:134
Add an advection field
The definition of an advection field allows one to handle flows with a frozen velocity field or the transport of scalar quantities without solving the Navier-Stokes system. The add of a new user-defined advection field with CDO/HHO schemes is specified as follows:
assert(adv != nullptr);
cs_adv_field_t * cs_advection_field_add_user(const char *name)
Add and initialize a new user-defined advection field structure.
Definition: cs_advection_field.cpp:440
Definition: cs_advection_field.h:151
When an advection field is defined, it is possible to retrieve it and then set a post-processing operation. For instance, to activate the post-processing of the CFL number proceed as follows:
void cs_advection_field_set_postprocess(cs_adv_field_t *adv, cs_flag_t post_flag)
Set optional post-processings.
Definition: cs_advection_field.cpp:720
cs_adv_field_t * cs_advection_field_by_name(const char *name)
Search in the array of advection field structures which one has the name given in argument.
Definition: cs_advection_field.cpp:390
#define CS_ADVECTION_FIELD_POST_COURANT
Definition: cs_advection_field.h:62
Add a user-defined equation
User-defined equation with CDO/HHO schemes are added thanks to a call to the function cs_equation_add_user in cs_user_model Here are several examples:
"my_variable",
1,
"Pot.Upw",
1,
"Pot.SG",
1,
cs_equation_t * cs_equation_add_user(const char *eqname, const char *varname, int dim, cs_param_bc_type_t default_bc)
Add a new user equation structure and set a first set of parameters.
Definition: cs_equation.cpp:1592
@ CS_BC_SYMMETRY
Definition: cs_param_types.h:487
@ CS_BC_HMG_DIRICHLET
Definition: cs_param_types.h:483
There is an other way to add a user-defined equation relying on the function cs_equation_add_user_tracer which combines (1) the add of a user-defined equation and (2) its association with properties for the unsteady and/or the diffusion term along with the association with an advection field.
"MyTracerVar",
1,
time_pty,
adv_field,
diff_pty);
cs_equation_t * cs_equation_add_user_tracer(const char *eqname, const char *varname, int dim, cs_param_bc_type_t default_bc, cs_property_t *time_pty, cs_adv_field_t *adv, cs_property_t *diff_pty)
Add a new user transport equation and set a first set of parameters If time_pty is nullptr,...
Definition: cs_equation.cpp:1642
Settings done in cs_user_finalize_setup()
Boundary conditions
User-defined equations
"boundary_faces",
_define_bcs,
nullptr);
cs_equation_param_t * cs_equation_param_by_name(const char *eqname)
Return the cs_equation_param_t structure associated to a cs_equation_t structure based on the equatio...
Definition: cs_equation.cpp:600
cs_xdef_t * cs_equation_add_bc_by_analytic(cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_analytic_func_t *analytic, void *input)
Define and initialize a new structure to set a boundary condition related to the given equation param...
Definition: cs_equation_param.cpp:2610
@ CS_BC_DIRICHLET
Definition: cs_param_types.h:484
Thermal system
The mechanism is the same as for user-defined equations. The name of the equation is defined in the macro CS_THERMAL_EQNAME
double Tleft = -1;
"left",
&Tleft);
double WallFlux = 2;
"wall",
&WallFlux);
double RobinBCs[3] = {10,
1,
-2};
"right",
RobinBCs);
cs_xdef_t * cs_equation_add_bc_by_value(cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_real_t *values)
Define and initialize a new structure to set a boundary condition related to the given equation struc...
Definition: cs_equation_param.cpp:2337
@ CS_BC_NEUMANN
Definition: cs_param_types.h:486
@ CS_BC_ROBIN
Definition: cs_param_types.h:491
#define CS_THERMAL_EQNAME
Definition: cs_thermal_system.h:51
Initial conditions
Thermal system
The mechanism is detailed for the thermal system but the same mechanism can be used for user-defined equations. In our example, the name of the equation is defined in the macro CS_THERMAL_EQNAME
nullptr,
_initial_temperature,
nullptr);
cs_xdef_t * cs_equation_add_ic_by_analytic(cs_equation_param_t *eqp, const char *z_name, cs_analytic_func_t *analytic, void *input)
Define the initial condition for the unknown related to this equation. This definition applies to a v...
Definition: cs_equation_param.cpp:2184
where the function _initial_temperature has a predefined prototype (cf. the definition of the function pointer cs_analytic_func_t)
static void
bool dense_output,
void *input,
if (elt_ids == nullptr) {
retval[i] = -1 + 2*coords[3*i];
else {
if (dense_output)
retval[i] = -1 + 2*coords[3*elt_ids[i]];
else {
retval[elt_id] = -1 + 2*coords[3*elt_id];
Definition: cs_defs.h:342
#define CS_NO_WARN_IF_UNUSED(x)
Definition: cs_defs.h:529
Definition: cs_defs.h:335
GWF module
Here is another example extracted from the file cs_user_parameters-cdo-gwf.c (in src/user_examples) but this is readily applicable to any equation.
where the function get_tracer_ic has a predefined prototype (cf. the definition of the function pointer cs_analytic_func_t)
static inline void
bool dense_output,
void *input,
const double magnitude = 2*k1/(k1 + k2);
const double x_front = magnitude * time;
const cs_lnum_t id = (pt_ids ==
nullptr) ? i : pt_ids[i];
const cs_lnum_t r_id = (dense_output) ? i :
id;
const double x = xyz[3*id];
if (x <= x_front)
retval[r_id] = 1;
else
retval[r_id] = 0;
#define CS_UNUSED(x)
Definition: cs_defs.h:528
Definition of properties
When a property has been added, the second step is to define this property. According to the type of property (isotropic, orthotropic or anisotropic) definitions differ. Here are two examples:
cs_real_33_t tensor = {{1.0, 0.5, 0.0}, {0.5, 1.0, 0.5}, {0.0, 0.5, 1.0}};
"cells",
tensor);
"cells",
iso_val);
cs_real_t cs_real_33_t[3][3]
Definition: cs_defs.h:368
cs_xdef_t * cs_property_def_iso_by_value(cs_property_t *pty, const char *zname, double val)
Define an isotropic cs_property_t structure by value for entities related to a volume zone.
Definition: cs_property.cpp:1783
cs_xdef_t * cs_property_def_aniso_by_value(cs_property_t *pty, const char *zname, cs_real_t tens[3][3])
Define an anisotropic cs_property_t structure by value for entities related to a volume zone.
Definition: cs_property.cpp:1978
Thermal system
The mechanism is the same as for user-defined properties. The named are predefined and associated to the following macros:
@ cp
Definition: cs_field_pointer.h:102
@ rho
Definition: cs_field_pointer.h:99
@ lambda
Definition: cs_field_pointer.h:108
#define CS_PROPERTY_MASS_DENSITY
Definition: cs_property.h:51
#define CS_THERMAL_LAMBDA_NAME
Definition: cs_thermal_system.h:53
#define CS_THERMAL_CP_NAME
Definition: cs_thermal_system.h:52
Definition of an advection field
When an advection field has been added, the second step is to define this advection field. Here are is an example of definition using an anlytic function and the activation of optional features:
void cs_advection_field_def_by_analytic(cs_adv_field_t *adv, cs_analytic_func_t *func, void *input)
Define a cs_adv_field_t structure thanks to an analytic function.
Definition: cs_advection_field.cpp:768
Definition of source terms
A first simple example.
cs_xdef_t * cs_equation_add_source_term_by_val(cs_equation_param_t *eqp, const char *z_name, cs_real_t *val)
Add a new source term by initializing a cs_xdef_t structure. Case of a definition by a constant value...
Definition: cs_equation_param.cpp:3280
The second example shows an advanced usage relying on an analytic function and an input structure. Moreover, a more accurate quadrature rule is specified.
double *input = nullptr;
input[0] = 0.5;
input[1] = 4.0*atan(1.0);
"x_leq_0",
_my_source_term,
input);
Definition: bft_mem.h:58
cs_xdef_t * cs_equation_add_source_term_by_analytic(cs_equation_param_t *eqp, const char *z_name, cs_analytic_func_t *func, void *input)
Add a new source term by initializing a cs_xdef_t structure. Case of a definition by an analytical fu...
Definition: cs_equation_param.cpp:3331
@ CS_QUADRATURE_HIGHER
Definition: cs_quadrature.h:89
void cs_xdef_set_free_input_function(cs_xdef_t *d, cs_xdef_free_input_t *free_input)
In case of a definition by an analytic function, a time function or a function relying on degrees of ...
Definition: cs_xdef.cpp:769
void cs_xdef_set_quadrature(cs_xdef_t *d, cs_quadrature_type_t qtype)
Set the type of quadrature to use for evaluating the given description.
Definition: cs_xdef.cpp:823
Definition: cs_xdef.h:160
The user-defined function to compute the source term is specified as follows
static void
bool dense_output,
void *input,
const double *pcoefs = (double *)input;
const double mu = pcoefs[0];
const double pi = pcoefs[1];
const double x = xyz[3*id], y = xyz[3*id+1], z = xyz[3*id+2];
const double px =
pi*x, cpx = cos(px), spx = sin(px);
const double py = 2*
pi*y, cpy = cos(py), spy = sin(py);
const double pz =
pi*z, cpz = cos(pz), spz = sin(pz);
values[ii] =
pi*( (y-0.5)*
gx + (0.5-x)*
gy + (z+1.0)*
gz ) +
mu*spx*spy*spz;
@ mu
Definition: cs_field_pointer.h:105
double precision pi
value with 16 digits
Definition: cstnum.f90:48
real(c_double), pointer, save gz
Definition: cstphy.f90:77
real(c_double), pointer, save gx
Gravity.
real(c_double), pointer, save gy
and the function for the memory management of a cs_xdef_t structure is
static void *
_free_input(void *input)
double *_input = (double *)input;
input = nullptr;
return nullptr;
#define BFT_FREE(_ptr)
Definition: bft_mem.h:90
Add diffusion, advection, etc. to a user-defined equation
Add terms to an equation like a diffusion term, an advection term, unsteady term, reaction terms.
void cs_equation_add_advection(cs_equation_param_t *eqp, cs_adv_field_t *adv_field)
Associate a new term related to the advection operator for the equation associated to the given cs_eq...
Definition: cs_equation_param.cpp:3190
void cs_equation_add_time(cs_equation_param_t *eqp, cs_property_t *property)
Associate a new term related to the time derivative operator for the equation associated to the given...
Definition: cs_equation_param.cpp:3165
void cs_equation_add_diffusion(cs_equation_param_t *eqp, cs_property_t *property)
Associate a new term related to the Laplacian operator for the equation associated to the given cs_eq...
Definition: cs_equation_param.cpp:3082
In some cases, one can also add less common terms such as a
or
(only available with CDO edge_based schemes).
false);
void cs_equation_add_graddiv(cs_equation_param_t *eqp, cs_property_t *property)
Associate a new term related to the grad-div operator for the equation associated to the given cs_equ...
Definition: cs_equation_param.cpp:3139
void cs_equation_add_curlcurl(cs_equation_param_t *eqp, cs_property_t *property, int inversion)
Associate a new term related to the curl-curl operator for the equation associated to the given cs_eq...
Definition: cs_equation_param.cpp:3108
@ gamma
Definition: cs_field_pointer.h:224
Settings done in cs_user_parameters()
Logging options
The management of the level and frequency of details written by the solver can be specified for CDO/HHO schemes as follows:
10,
2);
void cs_domain_set_output_param(cs_domain_t *domain, int restart_nt, int log_nt, int verbosity)
Set parameters related to the way output/logging is done.
Definition: cs_domain.cpp:352
#define CS_RESTART_INTERVAL_ONLY_AT_END
Definition: cs_restart.h:53
Time stepping strategy
The management of the time step with CDO/HHO schemes can be specified as follows:
100,
-1.);
void cs_domain_def_time_step_by_value(cs_domain_t *domain, double dt)
Define the value of the time step.
Definition: cs_domain_setup.cpp:433
void cs_domain_set_time_param(cs_domain_t *domain, int nt_max, double t_max)
Set parameters for unsteady computations: the max number of time steps or the final physical time of ...
Definition: cs_domain_setup.cpp:328
This can be completed with numerical options to specify the time scheme. See the next section)
Discretization parameters associated to an equation
To modify the numerical settings, the mechanism relies on a (key, value) rationale. The function to use is cs_equation_param_set For instance, with an equation called "MyEquation", and a key called CS_EQKEY_PARAM_TO_SET with the value "value_to_set".
void cs_equation_param_set(cs_equation_param_t *eqp, cs_equation_key_t key, const char *keyval)
Set a parameter attached to a keyname in a cs_equation_param_t structure.
Definition: cs_equation_param.cpp:1419
If one wants to modify the settings for all equations, this is possible using the function cs_equation_set_default_param
void cs_equation_set_default_param(cs_equation_key_t key, const char *keyval)
Set a parameter attached to a keyname for the default settigns.
Definition: cs_equation.cpp:1855
All available keys are listed and described with cs_equation_key_t One gives some examples for some of them.
Set the space discretization scheme
The key is CS_EQKEY_SPACE_SCHEME with the possible value gathered in the following table
| key_value | description |
"cdo_vb" or "cdovb" | Switch to a CDO vertex-based discretization (degrees of freedom are located at the mesh vertices). One value per vertex in the case of scalar-valued equation and three values per vertex in the case of a vector-valued equation. |
"cdo_vcb" or "cdovcb" | Switch to a CDO vertex+cell-based discretization (degrees of freedom are located at the mesh vertices and at the mesh cells). One value per vertex and per cell in the case of scalar-valued equation and three values per vertex and pêr cell in the case of a vector-valued equation. Thanks to a static condensation operation, the algebraic system is reduced to only vertex unknows. |
"cdo_fb" or "cdofb" | Switch to a CDO face-based discretization (degrees of freedom are located at interior and boundary faces and at mesh cell). One value per face and mesh cell in the case of scalar-valued equation and three values per face and mesh cell in the case of a vector-valued equation. Thanks to a static condensation operation, the algebraic system is reduced to only face unknows. |
"cdo_cb" or "cdocb" | Switch to a CDO cell-based discretization (degrees of freedom are located at mesh cells for the potential and at faces for the flux). Only scalar-valued equation are possible. One value per cell for the potential. One value per face for the flux unknown (the normal component of the flux). |
"cdo_eb" or "cdoeb" | Switch to CDO edge-based discretization (degrees of freedom are located at mesh edges, one scalar per edge corresponding to the circulation). Only vector-valued equation are handled with this discretization. |
"hho_p0" | Switch to a HHO(k=0) discretization relying on polynomial approximation. (degrees of freedom are located at interior and boundary faces and at mesh cells). One value per face and per mesh cell in the case of scalar-valued equation and three values per face and mesh cell in the case of a vector-valued equation. Thanks to a static condensation operation, the algebraic system is reduced to only face unknows. |
"hho_p1" | Switch to a HHO(k=1) discretization relying on polynomial approximation. (degrees of freedom are located at interior and boundary faces and at mesh cells). Three values per face and four values per cell in the case of scalar-valued equation and nine values per face and 12 values per cell in the case of a vector-valued equation. Thanks to a static condensation operation, the algebraic system is reduced to only face unknows. |
"hho_p2" | Switch to a HHO(k=2) discretization relying on polynomial approximation. (degrees of freedom are located at interior and boundary faces and at mesh cells). Six values per face and ten values per cell in the case of scalar-valued equation and 18 values per face and 30 values per cell in the case of a vector-valued equation. Thanks to a static condensation operation, the algebraic system is reduced to only face unknows. |
An example of usage:
@ CS_EQKEY_SPACE_SCHEME
Definition: cs_equation_param.h:1246
More details can be found in [4] for CDO-Vb, CDO-Fb, CDO-Cb and CDO-Eb. CDO-Fb are also detailed in [15]. CDO-VCb are detailed in [7]
Set the advection scheme
@ CS_EQKEY_ADV_SCHEME
Definition: cs_equation_param.h:1200
@ CS_EQKEY_ADV_FORMULATION
Definition: cs_equation_param.h:1199
The available advection schemes are listed in the description of the key CS_EQKEY_ADV_SCHEME
| key value | description | type | available with |
"upwind" | first order upwind scheme (convergence rate is equal to 0.5 on pure advection problem with a solution having a low regularity). This is the most robust choice. This yields a high-level of numerical diffusion. Thus, when the Péclet number (ratio between convection and diffusion) is low, a centered scheme or a scheme with less upwinding is a better choice in terms of accuracy | CS_PARAM_ADVECTION_SCHEME_UPWIND | CDO vb, CDO fb |
"centered" | second-order scheme on sufficiently regular solution. Dispersivity issue can occur with this scheme. This is not a good choice when the problem is dominated by the convection term. | CS_PARAM_ADVECTION_SCHEME_CENTERED | CDO vb, CDO fb |
"mix_centered_upwind", "hybrid_centered_upwind" | This is a hybrid advection scheme mixing an upwind and a centered advection scheme. The portion of upwinding (between 0. and 1.) is set thanks to the key CS_EQKEY_ADV_UPWIND_PORTION By default, the value 0.15 is used (0.25 when the GWF module is activated). | CS_PARAM_ADVECTION_SCHEME_HYBRID_CENTERED_UPWIND | CDO vb |
"cip" | "Continuous Interior Penalty" scheme detailed in [7] This scheme is only available with a non conservative or gradient formulation of the advective term. A switch to this formulation is automatically done. This a second-order scheme on regular solutions with a built-in stabilization relying on the jump of the gradient. The scaling in front of the stabilization term is computed automatically but it can be modified by the user thanks to the key CS_EQKEY_ADV_CIP_COEF | CS_PARAM_ADVECTION_SCHEME_CIP | CDO vcb |
"cip_cw" | Same as the "cip" but the advective field is assumed to be constant in each cell. This enables further optimizations when building the advection matrix. | CS_PARAM_ADVECTION_SCHEME_CIP_CW | CDO vcb |
"samarskii" | This scheme shares some similarities with a "hybrid_centered_upwind" scheme since a portion of upwinding is added to a centered scheme. This portion smoothly varies between mesh cells according to the evaluation of a local Péclet number. A function (the samarskii one) relates the Péclet number to the level of upwinding. | CS_PARAM_ADVECTION_SCHEME_SAMARSKII | CDO vb |
"sg" | SG means "Scharfetter Gummel". This is as a Samarskii scheme. The difference holds in the function computing the portion of upwinding from a local Péclet number. | CS_PARAM_ADVECTION_SCHEME_SG | CDO vb |
Here is a second set of examples
@ CS_EQKEY_ADV_UPWIND_PORTION
Definition: cs_equation_param.h:1202
@ CS_EQKEY_ADV_CIP_COEF
Definition: cs_equation_param.h:1197
There is no advection scheme available with HHO schemes or CDO cb and CDO eb schemes up to now.
Set the time scheme
When the equation to solve is unsteady, one has to specify a time discretization scheme. Available time schemes are listed in the description of the key CS_EQKEY_TIME_SCHEME By default, a first order implicit Euler scheme is used. To modify this default settings, please proceed as follows:
@ CS_EQKEY_TIME_SCHEME
Definition: cs_equation_param.h:1247
@ CS_EQKEY_TIME_THETA
Definition: cs_equation_param.h:1248
The mass matrix associated to the unsteady term is also a parameter. One can use either a mass matrix like in FV scheme using a "voronoi" algorithm (default) or the "wbs" algorithm like in Finite Element (FE) schemes.
@ CS_EQKEY_HODGE_TIME_ALGO
Definition: cs_equation_param.h:1212
Modify the numerical scheme for the diffusion term
Several algorithms are available to build the diffusion term. They are all listed in the description of the key CS_EQKEY_HODGE_DIFF_ALGO Please refer to [4] for more details In the case of the cost (or ocs), one can specify the value of the scaling coefficient in front of the stabilization part. This is done using the key CS_EQKEY_HODGE_DIFF_COEF
@ CS_EQKEY_HODGE_DIFF_COEF
Definition: cs_equation_param.h:1211
@ CS_EQKEY_HODGE_DIFF_ALGO
Definition: cs_equation_param.h:1210
Linear algebra settings
Many options are available in code_saturne to specify the way to solve a linear system. This is detailed here for the CDO/HHO part.
To go further
The detailed description of CDO schemes, the mathmatical analysis and numerical results on benchmarks are available in the following PhD thesis:
Additional publications :
