The Navier–Stokes equations can be solved using CDO face-based discretizations. Other space discretizations are not available. Up to now, there is no turbulence modelling when using CDO schemes. This is a work in progress.
The rationale to set up the computation in the case of the Navier-Stokes equations is the very near of the one explained for user-defined equations here. One only focuses on the specifities arising from the Navier-Stokes case.
The activation of the NavSto module is done thanks to the function cs_navsto_system_activate For instance, here are two examples to activate and set the main parameters for the NavSto module
or
The first parameter is the structure managing the domain boundaries. An example of settings for the domain boundaries is described here.
The second parameter specifies the type of model to consider among the following choice:
The base model can be updated thanks to the third parameter which is a flag built from the following elemental bit (cs_navsto_param_model_bit_t):
The fourth parameter specifies which type of velocity-pressure algorithm will be used (cs_navsto_param_coupling_t). The choice is done among:
The last parameter specifies predefined post-processing operations. As the third parameter, this a flag built from the following elemental bit (cs_navsto_param_post_bit_t):
Predefined equations associated to the Navier–Stokes equations are
In all cases, a vector-valued field named velocity and a scalar-valued field named _"pressure"_ are created. Moreover, several properties are added:
along with the advection field mass_flux (a cs_adv_field_t structure)
In the case of the NavSto module, this is done as follows (One does not access to the equation directly since it depends on the way the velocity/pressure coupling is done).
where the function _vel_def is defined as follows
Since the equation on which this source term applies, depends on the choice of the velocity-pressure algorithm, the way to proceed varies slightly of the way used on a user-defined equation.
where the function _src_def is defined as follows
The rationale is similar to the one detailed in this section.
Here are listed some specificities related to the NavSto module.
When a monolithic velocity-pressure is set, the linear system to solve is a saddle-point problem. This class of linear systems needs specific choices of preconditioner/solver. The default settings is not always the optimal choice in terms of efficiency. The settings of saddle-point problems is detailed here
The detailed description of CDO schemes, the mathmatical analysis and numerical results on benchmarks are available in the following PhD thesis:
Additional publications :
