#include "cs_defs.h"#include <chrono>#include <assert.h>#include <math.h>#include <stdio.h>#include <stdlib.h>#include "bft_mem.h"#include "bft_error.h"#include "bft_printf.h"#include "cs_array.h"#include "cs_base.h"#include "cs_blas.h"#include "cs_boundary_conditions.h"#include "cs_dispatch.h"#include "cs_domain.h"#include "cs_equation_iterative_solve.h"#include "cs_equation_param.h"#include "cs_face_viscosity.h"#include "cs_field.h"#include "cs_field_default.h"#include "cs_field_operator.h"#include "cs_field_pointer.h"#include "cs_gradient.h"#include "cs_lagr.h"#include "cs_log_iteration.h"#include "cs_mass_source_terms.h"#include "cs_math.h"#include "cs_mesh.h"#include "cs_mesh_quantities.h"#include "cs_parall.h"#include "cs_physical_constants.h"#include "cs_physical_model.h"#include "cs_porous_model.h"#include "cs_prototypes.h"#include "cs_rotation.h"#include "cs_solid_zone.h"#include "cs_thermal_model.h"#include "cs_time_step.h"#include "cs_timer.h"#include "cs_turbomachinery.h"#include "cs_turbulence_bc.h"#include "cs_turbulence_model.h"#include "cs_volume_mass_injection.h"#include "cs_velocity_pressure.h"#include "cs_wall_functions.h"#include "cs_turbulence_rij.h"
Include dependency graph for cs_turbulence_rij.cpp:Functions | |
| void | cs_turbulence_rij (int phase_id) |
| Solve the | |
| void | cs_turbulence_rij_solve_alpha (int f_id, int phase_id, cs_real_t c_durbin_l) |
| Solve the equation on alpha in the framework of the Rij-EBRSM model. More... | |
| void | cs_turbulence_rij_init_by_ref_quantities (cs_real_t uref, cs_real_t almax) |
| Initialize Rij-epsilon variables based on reference quantities. More... | |
| void | cs_turbulence_rij_clip (int phase_id, cs_lnum_t n_cells) |
| Clip the turbulent Reynods stress tensor and the turbulent dissipation (coupled components version). More... | |
| void | cs_turbulence_rij_mu_t (int phase_id) |
| Compute the turbulent viscosity for the Reynolds Stress model. More... | |
| void | cs_turbulence_rij_compute_rusanov (void) |
| Compute Rusanov equivalent diffusivity of the model. ! More... | |
| void cs_turbulence_rij | ( | int | phase_id | ) |
| void cs_turbulence_rij_clip | ( | int | phase_id, |
| cs_lnum_t | n_cells | ||
| [in] | phase_id | turbulent phase id (-1 for single phase flow) |
| void cs_turbulence_rij_compute_rusanov | ( | void | ) |
If uref is not provided (0 or negative), values are set at a large negative value (-cs_math_big_r) to allow for later checks.
| [in] | uref | characteristic flow velocity |
| [in] | almax | characteristic macroscopic length of the domain |
| void cs_turbulence_rij_mu_t | ( | int | phase_id | ) |
| void cs_turbulence_rij_solve_alpha | ( | int | f_id, |
| int | phase_id, | ||
| cs_real_t | c_durbin_l | ||
Also called for alpha of scalars for EB-DFM.
| [in] | f_id | field id of alpha variable |
| [in] | c_durbin_l | constant for the Durbin length ! |
