#include "cs_defs.h"#include <assert.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include <math.h>#include "bft_mem.h"#include "bft_error.h"#include "bft_printf.h"#include "cs_log.h"#include "cs_field.h"#include "cs_field_pointer.h"#include "cs_map.h"#include "cs_math.h"#include "cs_parall.h"#include "cs_mesh_location.h"#include "cs_turbulence_model.h"#include "cs_turbulence_bc.h"
Include dependency graph for cs_turbulence_bc.cpp:Functions | |
| void | cs_turbulence_bc_init_pointers (void) |
| Initialize turbulence model boundary condition pointers. More... | |
| void | cs_turbulence_bc_free_pointers (void) |
| Free memory allocations for turbulence boundary condition pointers. More... | |
| void | cs_turbulence_bc_ke_hyd_diam (double uref2, double dh, double rho, double mu, double *ustar2, double *k, double *eps) |
| Calculation of | |
| void | cs_turbulence_bc_ke_turb_intensity (double uref2, double t_intensity, double dh, double *k, double *eps) |
| Calculation of | |
| void | cs_turbulence_bc_inlet_hyd_diam (cs_lnum_t face_id, double uref2, double dh, double rho, double mu) |
| Set inlet boundary condition values for turbulence variables based on a diameter | |
| void | cs_turbulence_bc_inlet_turb_intensity (cs_lnum_t face_id, double uref2, double t_intensity, double dh) |
| void | cs_turbulence_bc_inlet_k_eps (cs_lnum_t face_id, double k, double eps) |
| Set inlet boundary condition values for turbulence variables based on given k and epsilon values. More... | |
| void | cs_turbulence_bc_set_hmg_neumann (cs_lnum_t face_id) |
| Assign homogeneous Neumann turbulent boundary conditions to a given face. More... | |
| void | cs_turbulence_bc_set_uninit_inlet_hyd_diam (cs_lnum_t face_id, double vel_dir[], double shear_dir[], double uref2, double dh, double rho, double mu) |
| void | cs_turbulence_bc_set_uninit_inlet_turb_intensity (cs_lnum_t face_id, double uref2, double t_intensity, double dh) |
| void | cs_turbulence_bc_set_uninit_inlet_k_eps (cs_lnum_t face_id, double k, double eps, double vel_dir[], double shear_dir[]) |
| Set inlet boundary condition values for turbulence variables based on given k and epsilon values only if not already initialized. More... | |
| void | cs_turbulence_bc_rij_transform (int is_sym, cs_real_t p_lg[3][3], cs_real_t alpha[6][6]) |
| Compute matrix | |
Base turbulence boundary conditions.
| void cs_turbulence_bc_free_pointers | ( | void | ) |
| void cs_turbulence_bc_init_pointers | ( | void | ) |
| void cs_turbulence_bc_inlet_hyd_diam | ( | cs_lnum_t | face_id, |
| double | uref2, | ||
| double | dh, | ||
| double | rho, | ||
| double | mu | ||
and the reference velocity
for a circular duct flow with smooth wall.
We use the laws from Idel'Cik, i.e. the head loss coefficient
is defined by:
then the relation reads
depends on the hydraulic Reynolds number
and is given by:
From
, we can estimate
and
from the well known formulae of developped turbulence
| [in] | face_id | boundary face id |
| [in] | uref2 | square of the reference flow velocity |
| [in] | dh | hydraulic diameter |
| [in] | rho | mass density |
| [in] | mu | dynamic viscosity |
| void cs_turbulence_bc_inlet_k_eps | ( | cs_lnum_t | face_id, |
| double | k, | ||
| double | eps | ||
| [in] | k | turbulent kinetic energy |
| [in] | eps | turbulent dissipation |
| void cs_turbulence_bc_inlet_turb_intensity | ( | cs_lnum_t | face_id, |
| double | t_intensity, | ||
| double | dh | ||
, a turbulent intensity
| [in] | t_intensity | turbulent intensity |
| void cs_turbulence_bc_ke_hyd_diam | ( | double | uref2, |
| double | dh, | ||
| double | rho, | ||
| double | mu, | ||
| double * | ustar2, | ||
| double * | k, | ||
| double * | eps | ||
Calculation of
and
from a diameter
for a circular duct flow with smooth wall (use for inlet boundary conditions).
Both
and
are returned, so that the user may compute other values of
and
with
is defined by:
and is given by:
From
, we can estimate
and
| [out] | ustar2 | square of friction speed |
| [out] | k | calculated turbulent intensity |
| [out] | eps | calculated turbulent dissipation |
| void cs_turbulence_bc_ke_turb_intensity | ( | double | uref2, |
| double | dh, | ||
| double * | k, | ||
| double * | eps | ||
Calculation of
and
from a diameter
for a circular duct flow with smooth wall (for inlet boundary conditions).
Compute matrix
used in the computation of the Reynolds stress tensor boundary conditions.
We note
the Reynolds Stress tensor in the global reference frame (mesh reference frame) and
the Reynolds stress tensor in the local reference frame (reference frame associated to the boundary face).
is the change of basis orthogonal matrix from local to global reference frame.
is a 6 by 6 matrix defined such that:
where symetric tensors
have been unfolded as follows:
should be computed as a function of
as follows:
with
and
Constant c is chosen depending on the type of the boundary face:
at a wall face,
at a symmetry face.
| [in] | is_sym | Constant c in description above (1 at a symmetry face, 0 at a wall face) |
| [in] | p_lg | change of basis matrix (local to global) |
| [out] | alpha | transformation matrix |
| void cs_turbulence_bc_set_hmg_neumann | ( | cs_lnum_t | face_id | ) |
This is useful for outgoing flow.
| void cs_turbulence_bc_set_uninit_inlet_hyd_diam | ( | cs_lnum_t | face_id, |
| double | vel_dir[], | ||
| double | shear_dir[], | ||
| double | dh, | ||
| double | rho, | ||
| double | mu | ||
for a circular duct flow with smooth wall, only if not already set.
Apart from assigning values where not already initialized, this function is similar to cs_turbulence_bc_inlet_hyd_diam.
| [in] | vel_dir | velocity direction (not normalized, or nullptr) |
| [in] | shear_dir | shear direction (or nullptr), it also contains the level of anisotropy (Rnt = a_nt k) |
| void cs_turbulence_bc_set_uninit_inlet_k_eps | ( | cs_lnum_t | face_id, |
| double | k, | ||
| double | eps, | ||
| double | shear_dir[] | ||
| [in] | vel_dir | velocity direction |
| [in] | shear_dir | shear direction, it also contains the level of anisotropy (Rnt = a_nt k) |
| void cs_turbulence_bc_set_uninit_inlet_turb_intensity | ( | cs_lnum_t | face_id, |
| double | dh | ||
Apart from assigning values where not already initialized, this function is similar to cs_turbulence_bc_inlet_turb_intensity.
