Gradient reconstruction at boundaries and associated functions. More...
#include "cs_defs.h"#include <assert.h>#include <errno.h>#include <stdio.h>#include <stdarg.h>#include <string.h>#include <math.h>#include <float.h>#include "bft_error.h"#include "bft_mem.h"#include "bft_printf.h"#include "cs_ext_neighborhood.h"#include "cs_field.h"#include "cs_halo.h"#include "cs_gradient_priv.h"#include "cs_math.h"#include "cs_mesh.h"#include "cs_mesh_adjacencies.h"#include "cs_mesh_quantities.h"#include "cs_parall.h"#include "cs_gradient_boundary.h"
Include dependency graph for cs_gradient_boundary.c:Functions | |
| void | cs_gradient_boundary_iprime_lsq_s (const cs_mesh_t *m, const cs_mesh_quantities_t *fvq, cs_lnum_t n_faces, const cs_lnum_t *face_ids, cs_halo_type_t halo_type, double clip_coeff, const cs_field_bc_coeffs_t *bc_coeffs, const cs_real_t c_weight[], const cs_real_t var[], cs_real_t *restrict var_iprime) |
| Compute the values of a scalar at boundary face I' positions using least-squares interpolation. More... | |
| void | cs_gradient_boundary_iprime_lsq_s_ani (const cs_mesh_t *m, const cs_mesh_quantities_t *fvq, cs_lnum_t n_faces, const cs_lnum_t *face_ids, double clip_coeff, const cs_field_bc_coeffs_t *bc_coeffs, const cs_real_t c_weight[][6], const cs_real_t var[], cs_real_t *restrict var_iprime) |
| Compute the values of a scalar at boundary face I' positions using least-squares interpolation with anisotropic weighting. More... | |
| void | cs_gradient_boundary_iprime_lsq_v (const cs_mesh_t *m, const cs_mesh_quantities_t *fvq, cs_lnum_t n_faces, const cs_lnum_t *face_ids, cs_halo_type_t halo_type, double clip_coeff, const cs_field_bc_coeffs_t *bc_coeffs_v, const cs_real_t c_weight[], const cs_real_t var[][3], cs_real_t var_iprime[restrict][3]) |
| Compute the values of a vector at boundary face I' positions using least-squares interpolation. More... | |
| void | cs_gradient_boundary_iprime_lsq_t (const cs_mesh_t *m, const cs_mesh_quantities_t *fvq, cs_lnum_t n_faces, const cs_lnum_t *face_ids, cs_halo_type_t halo_type, double clip_coeff, const cs_field_bc_coeffs_t *bc_coeffs_ts, const cs_real_t c_weight[], const cs_real_t var[][6], cs_real_t var_iprime[restrict][6]) |
| Compute the values of a symmetric tensor at boundary face I' positions using least-squares interpolation. More... | |
| void cs_gradient_boundary_iprime_lsq_s | ( | const cs_mesh_t * | m, |
| cs_lnum_t | n_faces, | ||
| double | clip_coeff, | ||
| cs_real_t *restrict | var_iprime | ||
This assumes ghost cell values for the variable (var) are up-to-date.
A simple limiter is applied to ensure the maximum principle is preserved (using non-reconstructed values in case of non-homogeneous Neumann conditions).
To compute the values at I', we only need the gradient along II', so in most cases, we could simply assume a Neumann BC for a given face.
We still use the provided BC's when possible, for the following cases:
| [in] | n_faces | number of faces at which to compute values |
| [in] | face_ids | ids of boundary faces at which to compute values, or NULL for all |
| [in] | halo_type | halo (cell neighborhood) type |
| [in] | clip_coeff | clipping (limiter) coefficient (no limiter if < 0) |
| [in] | bc_coeffs | boundary condition structure, or NULL |
| [in] | c_weight | cell variable weight, or NULL |
| [in] | var | variable values et cell centers |
| [out] | var_iprime | variable values et face iprime locations |
| void cs_gradient_boundary_iprime_lsq_s_ani | ( | const cs_mesh_t * | m, |
| const cs_real_t | c_weight[][6], | ||
| [in] | bc_coeffs | boundary condition structure |
| void cs_gradient_boundary_iprime_lsq_t | ( | const cs_mesh_t * | m, |
| const cs_field_bc_coeffs_t * | bc_coeffs_ts, | ||
| const cs_real_t | var[][6], | ||
| cs_real_t | var_iprime[restrict][6] | ||
This function uses a local iterative approach to compute the cell gradient, as handling of the boundary condition terms b in higher dimensions would otherwise require solving higher-dimensional systems, often at a higher cost.
To compute the values at I', we only need the gradient along II', so in most cases, we could simply assume a Neuman BC.
The same logic is applied as for cs_gradient_boundary_iprime_lsq_s.
| [in] | bc_coeffs_ts | boundary condition structure, or NULL |
| void cs_gradient_boundary_iprime_lsq_v | ( | const cs_mesh_t * | m, |
| const cs_field_bc_coeffs_t * | bc_coeffs_v, | ||
| const cs_real_t | var[][3], | ||
| cs_real_t | var_iprime[restrict][3] | ||
| [in] | bc_coeffs_v | boundary condition structure, or NULL |
