Coal combustion model boundary conditions. More...
#include "cs_defs.h"#include <assert.h>#include <stdarg.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include "bft_mem.h"#include "bft_printf.h"#include "cs_boundary.h"#include "cs_boundary_conditions.h"#include "cs_boundary_zone.h"#include "cs_coal.h"#include "cs_coal_ht_convert.h"#include "cs_combustion_model.h"#include "cs_field.h"#include "cs_field_pointer.h"#include "cs_math.h"#include "cs_mesh.h"#include "cs_mesh_quantities.h"#include "cs_parameters.h"#include "cs_parameters_check.h"#include "cs_physical_constants.h"#include "cs_physical_model.h"#include "cs_prototypes.h"#include "cs_coal_boundary_conditions.h"
Include dependency graph for cs_coal_boundary_conditions.c:Functions | |
| cs_coal_bc_inlet_t * | cs_coal_boundary_conditions_get_inlet (const cs_zone_t *zone) |
| Return pointer to coal boundary conditions inlet structure. More... | |
| void | cs_coal_boundary_conditions_inlet_set_air_mass_flow_rate_by_value (const cs_zone_t *z, cs_real_t q) |
| Assign a constant air mass flow rate to an inlet. More... | |
| void | cs_coal_boundary_conditions_inlet_set_air_mass_flow_rate_by_func (const cs_zone_t *z, cs_eval_at_location_t *func, void *input) |
| void | cs_coal_boundary_conditions (int bc_type[]) |
| Automatic boundary condition for pulverized coal combution. More... | |
| void | cs_coal_boundary_conditions_inlet_density (void) |
| Compute density at inlets for pulverized coal combustion. More... | |
| void cs_coal_boundary_conditions | ( | int | bc_type[] | ) |
| [in] | bc_type | type of boundary for each face |
| cs_coal_bc_inlet_t* cs_coal_boundary_conditions_get_inlet | ( | const cs_zone_t * | zone | ) |
If no such structure was previously present, it is created and linked to the matching open boundary condition inlet.
| [in] | zone | pointer to associated zone |
| void cs_coal_boundary_conditions_inlet_density | ( | void | ) |
This is based on boundary condition definitions, but is called at an earlier stage in the time step.
| void cs_coal_boundary_conditions_inlet_set_air_mass_flow_rate_by_func | ( | const cs_zone_t * | z, |
| cs_eval_at_location_t * | func, | ||
| void * | input | ||
| void cs_coal_boundary_conditions_inlet_set_air_mass_flow_rate_by_value | ( | const cs_zone_t * | z, |
| cs_real_t | q | ||
The total mass flow rate will also include that of the pulverized coals.
This is otherwise similar to cs_boundary_conditions_open_set_mass_flow_rate_by_value.
| [in] | z | pointer to associated zone |
| [in] | q | associated constant mass flow rate |
