8.1
cs_cdovb_vecteq.c File Reference
Build an algebraic CDO vertex-based system for unsteady convection-diffusion-reaction of vector-valued equations with source terms. More...
#include <float.h>
#include <bft_mem.h>
#include "cs_array.h"
#include "cs_cdo_advection.h"
#include "cs_cdo_bc.h"
#include "cs_cdo_diffusion.h"
#include "cs_cdo_local.h"
#include "cs_cdo_solve.h"
#include "cs_cdo_system.h"
#include "cs_cdo_toolbox.h"
#include "cs_cdovb_priv.h"
#include "cs_equation_bc.h"
#include "cs_equation_builder.h"
#include "cs_evaluate.h"
#include "cs_hodge.h"
#include "cs_math.h"
#include "cs_mesh_location.h"
#include "cs_post.h"
#include "cs_quadrature.h"
#include "cs_reco.h"
#include "cs_scheme_geometry.h"
#include "cs_search.h"
#include "cs_sles.h"
#include "cs_source_term.h"
#include "cs_timer.h"
#include "cs_cdovb_vecteq.h"
+ Include dependency graph for cs_cdovb_vecteq.c:
bool cs_cdovb_vecteq_is_initialized (void)
 Check if the generic structures for building a CDO-Vb scheme are allocated. More...
void cs_cdovb_vecteq_init_sharing (const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
 Allocate work buffer and general structures related to CDO vector-valued vertex-based schemes Set shared pointers. More...
void cs_cdovb_vecteq_get (cs_cell_sys_t **csys, cs_cell_builder_t **cb)
void cs_cdovb_vecteq_finalize_sharing (void)
 Free work buffer and general structure related to CDO vertex-based schemes. More...
void * cs_cdovb_vecteq_init_context (const cs_equation_param_t *eqp, int var_id, int bflux_id, cs_equation_builder_t *eqb)
 Initialize a cs_cdovb_vecteq_t structure storing data useful for building and managing such a scheme. More...
void * cs_cdovb_vecteq_free_context (void *builder)
 Destroy a cs_cdovb_vecteq_t structure. More...
void cs_cdovb_vecteq_init_values (cs_real_t t_eval, const int field_id, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
 Set the initial values of the variable field taking into account the boundary conditions. Case of vector-valued CDO-Vb schemes. More...
void cs_cdovb_vecteq_solve_steady_state (bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
 Build and solve the linear system arising from a vector steady-state convection/diffusion/reaction equation with a CDO-Vb scheme. One works cellwise and then process to the assembly. More...
void cs_cdovb_vecteq_update_field (const cs_real_t *solu, const cs_real_t *rhs, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data, cs_real_t *field_val)
 Store solution(s) of the linear system into a field structure Update extra-field values if required (for hybrid discretization) More...
cs_real_tcs_cdovb_vecteq_get_vertex_values (void *context, bool previous)
 Retrieve an array of values at mesh vertices for the variable field associated to the given context The lifecycle of this array is managed by the code. So one does not have to free the return pointer. More...
cs_real_tcs_cdovb_vecteq_get_cell_values (void *context, bool previous)
 Compute an array of values at mesh cells by interpolating the variable field associated to the given context located at mesh vertices The lifecycle of this array is managed by the code. So one does not have to free the return pointer. More...
void cs_cdovb_vecteq_current_to_previous (const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
void cs_cdovb_vecteq_extra_post (const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
◆ cs_cdovb_vecteq_current_to_previous()
void cs_cdovb_vecteq_current_to_previous ( const cs_equation_param_t eqp,
cs_equation_builder_t eqb,
void *  context
[in,out]contextpointer to cs_cdovb_vecteq_t structure
◆ cs_cdovb_vecteq_extra_post()
void cs_cdovb_vecteq_extra_post ( const cs_equation_param_t eqp,
void *  context
◆ cs_cdovb_vecteq_finalize_sharing()
void cs_cdovb_vecteq_finalize_sharing ( void  )
◆ cs_cdovb_vecteq_free_context()
void* cs_cdovb_vecteq_free_context ( void *  builder)
[in,out]builderpointer to a cs_cdovb_vecteq_t structure
a NULL pointer
◆ cs_cdovb_vecteq_get()
void cs_cdovb_vecteq_get ( cs_cell_sys_t **  csys,
cs_cell_builder_t **  cb
◆ cs_cdovb_vecteq_get_cell_values()
cs_real_t* cs_cdovb_vecteq_get_cell_values ( void *  context,
bool  previous
a pointer to an array of cs_real_t (size: 3*n_cells)
◆ cs_cdovb_vecteq_get_vertex_values()
cs_real_t* cs_cdovb_vecteq_get_vertex_values ( void *  context,
bool  previous
a pointer to an array of cs_real_t (size: 3*n_vertices)
◆ cs_cdovb_vecteq_init_context()
void* cs_cdovb_vecteq_init_context ( const cs_equation_param_t eqp,
int  var_id,
int  bflux_id,
a pointer to a new allocated cs_cdovb_vecteq_t structure
◆ cs_cdovb_vecteq_init_sharing()
void cs_cdovb_vecteq_init_sharing ( const cs_cdo_quantities_t quant,
const cs_time_step_t time_step
◆ cs_cdovb_vecteq_init_values()
void cs_cdovb_vecteq_init_values ( cs_real_t  t_eval,
const int  field_id,
const cs_mesh_t mesh,
void *  context
◆ cs_cdovb_vecteq_is_initialized()
bool cs_cdovb_vecteq_is_initialized ( void  )
DOXYGEN_SHOULD_SKIP_THIS
true or false
◆ cs_cdovb_vecteq_solve_steady_state()
void cs_cdovb_vecteq_solve_steady_state ( bool  cur2prev,
const int  field_id,
void *  context
◆ cs_cdovb_vecteq_update_field()
void cs_cdovb_vecteq_update_field ( const cs_real_t solu,
const cs_real_t rhs,
void *  data,
cs_real_t field_val
[in]solusolution array
[in]rhsrhs associated to this solution array
[in,out]datapointer to cs_cdovb_vecteq_t structure
[in,out]field_valpointer to the current value of the field
