1 #ifndef __CS_CDO_DIFFUSION_H__
2 #define __CS_CDO_DIFFUSION_H__
void cs_cdo_diffusion_svb_wbs_wsym_dirichlet(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Take into account Dirichlet BCs by a weak enforcement using Nitsche technique plus a symmetric treatm...
Definition: cs_cdo_diffusion.c:2678
void cs_cdo_diffusion_wbs_get_dfbyc_flux(const cs_cell_mesh_t *cm, const cs_real_t *pot, const cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_real_t *flx)
Compute the diffusive flux across dual faces for a given cell Use the WBS algo. for approximating the...
Definition: cs_cdo_diffusion.c:3217
void cs_cdo_diffusion_vvb_ocs_weak_dirichlet(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Take into account Dirichlet BCs by a weak enforcement using Nitsche technique. A Dirichlet is set for...
Definition: cs_cdo_diffusion.c:2130
void() cs_cdo_diffusion_cw_flux_t(const cs_cell_mesh_t *cm, const cs_real_t *pot, const cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_real_t *flx)
Cellwise computation of the diffusive flux.
Definition: cs_cdo_diffusion.h:65
void cs_cdo_diffusion_vcb_weak_dirichlet(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Take into account Dirichlet BCs by a weak enforcement using Nitsche technique. Case of CDO-VCb scheme...
Definition: cs_cdo_diffusion.c:2780
void cs_cdo_diffusion_sfb_cost_flux(short int f, const cs_cell_mesh_t *cm, const cs_real_t *pot, const cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_real_t *flux)
Compute the normal diffusive flux for a face assuming only the knowledge of the potential at faces an...
Definition: cs_cdo_diffusion.c:3541
void cs_cdo_diffusion_sfb_cost_robin(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Take into account Robin BCs. Case of scalar-valued CDO-Fb schemes with a CO+ST algorithm....
Definition: cs_cdo_diffusion.c:1881
void cs_cdo_diffusion_alge_dirichlet_extra_block(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Function close to cs_cdo_diffusion_alge_dirichlet but dedicated to systems by blocks and especially f...
Definition: cs_cdo_diffusion.c:1035
void cs_cdo_diffusion_vfb_wsym_sliding(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Take into account sliding BCs by a weak enforcement using Nitsche technique plus a symmetric treatmen...
Definition: cs_cdo_diffusion.c:1744
void cs_cdo_diffusion_sfb_get_face_flux(const cs_cell_mesh_t *cm, const double *pot, const cs_hodge_t *hodge, cs_cell_builder_t *cb, double *flx)
Compute the diffusive flux across primal faces for a given cell. Use the same consistent approximatio...
Definition: cs_cdo_diffusion.c:2967
void cs_cdo_diffusion_vfb_weak_dirichlet(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Take into account Dirichlet BCs by a weak enforcement using Nitsche technique. Case of vector-valued ...
Definition: cs_cdo_diffusion.c:1344
void cs_cdo_diffusion_svb_ocs_weak_dirichlet(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Take into account Dirichlet BCs by a weak enforcement using Nitsche technique. Case of scalar-valued ...
Definition: cs_cdo_diffusion.c:2039
void cs_cdo_diffusion_svb_get_dfbyc_flux(const cs_cell_mesh_t *cm, const double *pot, const cs_hodge_t *hodge, cs_cell_builder_t *cb, double *flx)
Compute the diffusive flux across dual faces for a given cell. Use the same consistent approximation ...
Definition: cs_cdo_diffusion.c:3008
void cs_cdo_diffusion_svb_get_cell_flux(const cs_cell_mesh_t *cm, const double *pot, const cs_hodge_t *hodge, cs_cell_builder_t *cb, double *flx)
Compute the constant approximation of the diffusive flux inside a (primal) cell. Use the same consist...
Definition: cs_cdo_diffusion.c:3057
double cs_cdo_diffusion_wbs_face_flux(const cs_face_mesh_t *fm, const cs_real_t pty_tens[3][3], const double *p_v, const double p_f, const double p_c, cs_cell_builder_t *cb)
Compute the diffusive flux across a face (based on a subdivision into tetrahedra of the volume p_{f,...
Definition: cs_cdo_diffusion.c:3460
void cs_cdo_diffusion_svb_cost_robin(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Take into account Robin BCs. Case of scalar-valued CDO-Vb schemes with a CO+ST algorithm....
Definition: cs_cdo_diffusion.c:1950
void cs_cdo_diffusion_alge_block_dirichlet(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Take into account Dirichlet BCs by keeping the DoFs related to Dirichlet BCs in the algebraic system ...
Definition: cs_cdo_diffusion.c:1121
void cs_cdo_diffusion_svb_wbs_weak_dirichlet(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Take into account Dirichlet BCs by a weak enforcement using Nitsche technique. Case of CDO-Vb schemes...
Definition: cs_cdo_diffusion.c:2591
void cs_cdo_diffusion_vfb_wsym_dirichlet(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Definition: cs_cdo_diffusion.c:1591
void cs_cdo_diffusion_wbs_vbyf_flux(short int f, const cs_cell_mesh_t *cm, const cs_real_t *pot, const cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_real_t *flux)
Compute the normal flux for a face assuming only the knowledge of the potential at cell vertices (and...
Definition: cs_cdo_diffusion.c:3360
void cs_cdo_diffusion_svb_ocs_wsym_dirichlet(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Definition: cs_cdo_diffusion.c:2388
void cs_cdo_diffusion_sfb_wsym_dirichlet(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Definition: cs_cdo_diffusion.c:1469
void cs_cdovb_diffusion_p0_face_flux(const short int f, const cs_cell_mesh_t *cm, const cs_real_t diff_tensor[3][3], const cs_real_t *pot_values, cs_real_t *fluxes)
Compute the normal flux for a face assuming only the knowledge of the potential at cell vertices....
Definition: cs_cdo_diffusion.c:3619
void cs_cdo_diffusion_alge_dirichlet(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Definition: cs_cdo_diffusion.c:945
void cs_cdo_diffusion_vcb_wsym_dirichlet(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Definition: cs_cdo_diffusion.c:2867
void cs_cdo_diffusion_vvb_ocs_sliding(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Take into account a sliding BCs. Case of vector-valued CDO-Vb schemes with a OCS algorithm....
Definition: cs_cdo_diffusion.c:2254
void cs_cdo_diffusion_svb_vbyf_flux(short int f, const cs_cell_mesh_t *cm, const cs_real_t *pot, const cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_real_t *flux)
Definition: cs_cdo_diffusion.c:3115
void cs_cdo_diffusion_pena_block_dirichlet(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Take into account Dirichlet BCs by a weak enforcement by a penalization technique with a huge value....
Definition: cs_cdo_diffusion.c:869
void cs_cdo_diffusion_wbs_get_cell_flux(const cs_cell_mesh_t *cm, const cs_real_t *pot, const cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_real_t *flx)
Compute the diffusive flux inside a given primal cell Use the WBS algo. for approximating the gradien...
Definition: cs_cdo_diffusion.c:3321
void cs_cdo_diffusion_sfb_weak_dirichlet(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Definition: cs_cdo_diffusion.c:1238
void cs_cdo_diffusion_pena_dirichlet(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Definition: cs_cdo_diffusion.c:819
void cs_cdo_diffusion_svb_wbs_robin(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Take into account Robin BCs. Case of scalar-valued CDO-Vb schemes with a WBS algorithm....
Definition: cs_cdo_diffusion.c:2486
Definition: cs_defs.h:514
Definition: cs_defs.h:319
Definition: cs_defs.h:515
@ fm
Definition: cs_field_pointer.h:127
Definition: cs_cdo_local.h:60
Set of local quantities and connectivities related to a mesh face Structure used to get a better memo...
Definition: cs_cdo_local.h:279
Definition: cs_hodge.h:183
