8.1
cs_cdo_toolbox.h
1 #ifndef __CS_CDO_TOOLBOX_H__
2 #define __CS_CDO_TOOLBOX_H__
5  * Set of toolbox functions: shared buffer, balance, synchronization
29  * Local headers
32 #include "cs_cdo_connect.h"
33 #include "cs_flag.h"
34 #include "cs_xdef.h"
41  * Macro definitions
44 /* Strategy of synchronization of values shared across several cells
45  * This applies to vertices, edges and faces
46  *
47  * CS_CDO_SYNC_ZERO_VALUE
48  * If zero is a possible value then set this value, otherwise one takes
49  * the mean-value
50  *
51  * CS_CDO_SYNC_MEAN_VALUE
52  * Compute the mean-value across values to set
53  *
54  */
55
56 #define CS_CDO_SYNC_ZERO_VALUE 1
57 #define CS_CDO_SYNC_MEAN_VALUE 2
58
59 /*============================================================================
60  * Type definitions
62
63 /*
64  * Structure used to store information generated during the analysis
65  * of the balance of each term of an equation
66  */
67
68 typedef struct {
69
70  /* Where the balance is computed: primal vertices or primal cells */
71
75
76  /* Balance for each main term */
77
84
86
87 /*============================================================================
88  * Public function prototypes
89  *============================================================================*/
90
91 /*----------------------------------------------------------------------------*/
107 /*----------------------------------------------------------------------------*/
108
109 void
111  cs_flag_t eb_flag,
112  cs_flag_t fb_flag,
113  cs_flag_t cb_flag,
114  cs_flag_t vb_flag,
115  cs_flag_t vcb_flag,
116  cs_flag_t hho_flag);
117
118 /*----------------------------------------------------------------------------*/
123
124 void
126
135 /*----------------------------------------------------------------------------*/
136
137 cs_real_t *
139
140 /*----------------------------------------------------------------------------*/
147
148 size_t
150
151 /*----------------------------------------------------------------------------*/
160 /*----------------------------------------------------------------------------*/
161
164  cs_lnum_t size);
165
166 /*----------------------------------------------------------------------------*/
172 /*----------------------------------------------------------------------------*/
173
174 void
176
177 /*----------------------------------------------------------------------------*/
184 /*----------------------------------------------------------------------------*/
185
186 void
188  cs_cdo_balance_t *b);
189
190 /*----------------------------------------------------------------------------*/
196 /*----------------------------------------------------------------------------*/
197
198 void
200
201 /*----------------------------------------------------------------------------*/
210 /*----------------------------------------------------------------------------*/
211
212 void
214  cs_xdef_t **defs,
215  cs_lnum_t def2v_idx[],
216  cs_lnum_t def2v_ids[]);
217
218 /*----------------------------------------------------------------------------*/
227 /*----------------------------------------------------------------------------*/
228
229 void
231  cs_xdef_t **defs,
232  cs_lnum_t def2e_idx[],
233  cs_lnum_t def2e_ids[]);
234
235 /*----------------------------------------------------------------------------*/
244 /*----------------------------------------------------------------------------*/
245
246 void
248  cs_xdef_t **defs,
249  cs_lnum_t def2f_idx[],
250  cs_lnum_t def2f_ids[]);
251
260 /*----------------------------------------------------------------------------*/
261
262 void
264  int *counter,
265  cs_real_t *values);
266
267 /*----------------------------------------------------------------------------*/
268
270
271 #endif /* __CS_CDO_TOOLBOX_H__ */
size_t cs_cdo_toolbox_get_tmpbuf_size(void)
Get the allocation size of the temporary buffer.
Definition: cs_cdo_toolbox.c:291
cs_cdo_balance_t * cs_cdo_balance_create(cs_flag_t location, cs_lnum_t size)
Allocate a cs_cdo_balance_t structure.
Definition: cs_cdo_toolbox.c:308
void cs_cdo_sync_vertex_mean_values(int dim, int *counter, cs_real_t *values)
Compute the mean-value across ranks at each vertex.
Definition: cs_cdo_toolbox.c:733
cs_real_t * cs_cdo_toolbox_get_tmpbuf(void)
Retrieve a pointer to a buffer of size at least the 2*n_cells The size of the temporary buffer can be...
Definition: cs_cdo_toolbox.c:277
void cs_cdo_toolbox_finalize(void)
Free buffers shared among the equations solved with CDO schemes.
Definition: cs_cdo_toolbox.c:251
void cs_cdo_toolbox_init(const cs_cdo_connect_t *connect, cs_flag_t eb_flag, cs_flag_t fb_flag, cs_flag_t cb_flag, cs_flag_t vb_flag, cs_flag_t vcb_flag, cs_flag_t hho_flag)
Allocate a pointer to a buffer of size at least the n_cells for managing temporary usage of memory wh...
Definition: cs_cdo_toolbox.c:118
void cs_cdo_sync_vol_def_at_edges(int n_defs, cs_xdef_t **defs, cs_lnum_t def2e_idx[], cs_lnum_t def2e_ids[])
Synchronize the volumetric definitions to consider at each edge.
Definition: cs_cdo_toolbox.c:528
void cs_cdo_balance_reset(cs_cdo_balance_t *b)
Reset a cs_cdo_balance_t structure.
Definition: cs_cdo_toolbox.c:345
void cs_cdo_sync_vol_def_at_faces(int n_defs, cs_xdef_t **defs, cs_lnum_t def2f_idx[], cs_lnum_t def2f_ids[])
Synchronize the volumetric definitions to consider at each face.
Definition: cs_cdo_toolbox.c:631
void cs_cdo_balance_sync(const cs_cdo_connect_t *connect, cs_cdo_balance_t *b)
Synchronize balance terms if this is a parallel computation.
Definition: cs_cdo_toolbox.c:370
void cs_cdo_balance_destroy(cs_cdo_balance_t **p_balance)
Free a cs_cdo_balance_t structure.
Definition: cs_cdo_toolbox.c:400
void cs_cdo_sync_vol_def_at_vertices(int n_defs, cs_xdef_t **defs, cs_lnum_t def2v_idx[], cs_lnum_t def2v_ids[])
Synchronize the volumetric definitions to consider at each vertex.
Definition: cs_cdo_toolbox.c:425
Definition: cs_defs.h:514
Definition: cs_defs.h:319
Definition: cs_defs.h:515
Definition: cs_defs.h:313
unsigned short int cs_flag_t
Definition: cs_defs.h:321
Definition: cs_cdo_toolbox.h:68
cs_real_t * boundary_term
Definition: cs_cdo_toolbox.h:83
cs_real_t * unsteady_term
Definition: cs_cdo_toolbox.h:78
cs_real_t * advection_term
Definition: cs_cdo_toolbox.h:81
cs_real_t * reaction_term
Definition: cs_cdo_toolbox.h:79
cs_real_t * source_term
Definition: cs_cdo_toolbox.h:82
cs_lnum_t size
Definition: cs_cdo_toolbox.h:73
cs_flag_t location
Definition: cs_cdo_toolbox.h:72
cs_real_t * balance
Definition: cs_cdo_toolbox.h:74
cs_real_t * diffusion_term
Definition: cs_cdo_toolbox.h:80
Definition: cs_xdef.h:160
