Macros | |
Flags specifying the type of cell | |
#define | CS_FLAG_BOUNDARY_CELL_BY_FACE (1 << 0) |
(= 1) boundary cell with at least one border face More... | |
#define | CS_FLAG_BOUNDARY_CELL_BY_VERTEX (1 << 1) |
(= 2) boundary cell with at least one border vertex More... | |
#define | CS_FLAG_BOUNDARY_CELL_BY_EDGE (1 << 2) |
(= 4) boundary cell with at least one border edge More... | |
#define | CS_FLAG_SOLID_CELL (1 << 3) |
(= 8) cell attached to a solid zone during the calculation More... | |
Flags specifying the type of update to perform | |
#define | CS_FLAG_CURRENT_TO_PREVIOUS (1 << 0) |
(value = 1) perform a previous to current operation on fields during the update step More... | |
#define | CS_FLAG_INITIALIZATION (1 << 1) |
(value = 2) This is the first time that the update is called so it is also an initialization step More... | |
Flag related to the way a CDO system is built | |
#define | CS_FLAG_SYS_MASS_MATRIX (1 << 0) |
#define | CS_FLAG_SYS_SYM (1 << 1) |
#define | CS_FLAG_SYS_TIME_DIAG (1 << 2) |
#define | CS_FLAG_SYS_REAC_DIAG (1 << 3) |
#define | CS_FLAG_SYS_SOURCES_HLOC (1 << 4) |
#define | CS_FLAG_SYS_VECTOR (1 << 5) |
Flags use to identify the nature/status of an object | |
Apply this flag on a variable, a property or an advection field | |
#define | CS_FLAG_STATE_UNIFORM (1 << 0) |
#define | CS_FLAG_STATE_CELLWISE (1 << 1) |
#define | CS_FLAG_STATE_FACEWISE (1 << 2) |
#define | CS_FLAG_STATE_STEADY (1 << 3) |
#define | CS_FLAG_STATE_POTENTIAL (1 << 4) |
#define | CS_FLAG_STATE_CIRCULATION (1 << 5) |
#define | CS_FLAG_STATE_FLUX (1 << 6) |
#define | CS_FLAG_STATE_DENSITY (1 << 7) |
Flags use to identify metadata for a quantity | |
where is located this quantity and how to access to its values | |
#define | CS_FLAG_FULL_LOC (1 << 0) |
#define | CS_FLAG_SCALAR (1 << 1) |
#define | CS_FLAG_VECTOR (1 << 2) |
#define | CS_FLAG_TENSOR (1 << 3) |
#define | CS_FLAG_VERTEX (1 << 4) |
#define | CS_FLAG_EDGE (1 << 5) |
#define | CS_FLAG_FACE (1 << 6) |
#define | CS_FLAG_CELL (1 << 7) |
#define | CS_FLAG_PRIMAL (1 << 8) |
#define | CS_FLAG_DUAL (1 << 9) |
#define | CS_FLAG_BORDER (1 << 10) |
#define | CS_FLAG_BY_CELL (1 << 11) |
#define | CS_FLAG_BY_FACE (1 << 12) |
Flags use to identify the type of equations requested. | |
There exists one flag for each type of space discretization. If this flag is activated, then at least one equation or system of this kind is discretized with this space discretization scheme. | |
#define | CS_FLAG_SCHEME_SCALAR (1 << 0) |
#define | CS_FLAG_SCHEME_VECTOR (1 << 1) |
#define | CS_FLAG_SCHEME_NAVSTO (1 << 2) |
#define | CS_FLAG_SCHEME_POLY0 (1 << 3) |
#define | CS_FLAG_SCHEME_POLY1 (1 << 4) |
#define | CS_FLAG_SCHEME_POLY2 (1 << 5) |
typedef unsigned char | cs_mask_t |
typedef unsigned int | cs_eflag_t |
static bool | cs_flag_test (cs_flag_t flag_to_check, cs_flag_t reference) |
Check if a two flag share the same pattern Return true if the flag to check has at least the pattern of the reference flag. More... | |
static bool | cs_flag_at_least (cs_flag_t flag_to_check, int n_masks, cs_flag_t masks[]) |
Check if a flag has in common at least one of the given masks Return true if the test is satisfied. More... | |
static bool | cs_eflag_test (cs_eflag_t flag_to_check, cs_eflag_t reference) |
Check if a two compute flag share the same pattern Return true if the computed flag to check has at least the pattern of the reference compute flag. Case of extended flags. More... | |
const char * | cs_flag_str_location (cs_flag_t loc) |
Retrieve the label associated to a location flag. More... | |
const cs_flag_t | cs_flag_primal_vtx |
const cs_flag_t | cs_flag_primal_edge |
const cs_flag_t | cs_flag_primal_face |
const cs_flag_t | cs_flag_primal_cell |
const cs_flag_t | cs_flag_vertex |
const cs_flag_t | cs_flag_cell |
const cs_flag_t | cs_flag_boundary_face |
const cs_flag_t | cs_flag_dual_vtx |
const cs_flag_t | cs_flag_dual_face |
const cs_flag_t | cs_flag_dual_cell |
const cs_flag_t | cs_flag_primal_edge_byc |
const cs_flag_t | cs_flag_dual_cell_byc |
const cs_flag_t | cs_flag_dual_face_byc |
const cs_flag_t | cs_flag_dual_closure_byf |
const cs_eflag_t | cs_flag_need_v |
const cs_eflag_t | cs_flag_need_e |
const cs_eflag_t | cs_flag_need_f |
const cs_eflag_t | cs_flag_need_fe |
const cs_eflag_t | cs_flag_need_ef |
const cs_eflag_t | cs_flag_need_peq |
const cs_eflag_t | cs_flag_need_dfq |
const cs_eflag_t | cs_flag_need_pfq |
const cs_eflag_t | cs_flag_need_deq |
const cs_eflag_t | cs_flag_need_pfc |
#define CS_FLAG_BORDER (1 << 10) |
1024: located on the boundary
#define CS_FLAG_BOUNDARY_CELL_BY_EDGE (1 << 2) |
#define CS_FLAG_BOUNDARY_CELL_BY_FACE (1 << 0) |
#define CS_FLAG_BOUNDARY_CELL_BY_VERTEX (1 << 1) |
#define CS_FLAG_BY_CELL (1 << 11) |
2048: by cell (c2e, c2f, c2v)
#define CS_FLAG_BY_FACE (1 << 12) |
4096: by face (bf2v)
#define CS_FLAG_CELL (1 << 7) |
128: on cells
#define CS_FLAG_CURRENT_TO_PREVIOUS (1 << 0) |
#define CS_FLAG_DUAL (1 << 9) |
512: on dual mesh
#define CS_FLAG_EDGE (1 << 5) |
32: on edges
#define CS_FLAG_FACE (1 << 6) |
64: on faces
#define CS_FLAG_FULL_LOC (1 << 0) |
1: defined on the whole location
#define CS_FLAG_INITIALIZATION (1 << 1) |
#define CS_FLAG_PRIMAL (1 << 8) |
256: on primal mesh
#define CS_FLAG_SCALAR (1 << 1) |
2: scalar-valued (stride = 1)
#define CS_FLAG_SCHEME_NAVSTO (1 << 2) |
4: Navier-Stokes system
#define CS_FLAG_SCHEME_POLY0 (1 << 3) |
8: lowest-order scheme
#define CS_FLAG_SCHEME_POLY1 (1 << 4) |
16: Linear gradient approx.
#define CS_FLAG_SCHEME_POLY2 (1 << 5) |
32: Quadratic gradient approx.
#define CS_FLAG_SCHEME_SCALAR (1 << 0) |
1: scheme for scalar eq.
#define CS_FLAG_SCHEME_VECTOR (1 << 1) |
2: scheme for a vector eq.
#define CS_FLAG_SOLID_CELL (1 << 3) |
#define CS_FLAG_STATE_CELLWISE (1 << 1) |
2: cellwise uniform
#define CS_FLAG_STATE_CIRCULATION (1 << 5) |
32: circulation
#define CS_FLAG_STATE_DENSITY (1 << 7) |
128: density
#define CS_FLAG_STATE_FACEWISE (1 << 2) |
4: uniform on each face
#define CS_FLAG_STATE_FLUX (1 << 6) |
64: flux
#define CS_FLAG_STATE_POTENTIAL (1 << 4) |
16: potential
#define CS_FLAG_STATE_STEADY (1 << 3) |
8: steady
#define CS_FLAG_STATE_UNIFORM (1 << 0) |
1: uniform (in space)
#define CS_FLAG_SYS_MASS_MATRIX (1 << 0) |
1: build a mass matrix
#define CS_FLAG_SYS_REAC_DIAG (1 << 3) |
8: lump the reaction term
#define CS_FLAG_SYS_SOURCES_HLOC (1 << 4) |
16: Hodge op. for source terms
#define CS_FLAG_SYS_SYM (1 << 1) |
2: system matrix is symmetric
#define CS_FLAG_SYS_TIME_DIAG (1 << 2) |
4: lump the time term
#define CS_FLAG_SYS_VECTOR (1 << 5) |
32: vector-valued variable
#define CS_FLAG_TENSOR (1 << 3) |
8: tensor-valued (stride = 9)
#define CS_FLAG_VECTOR (1 << 2) |
4: vector-valued (stride = 3)
#define CS_FLAG_VERTEX (1 << 4) |
16: on vertices
typedef unsigned int cs_eflag_t |
typedef unsigned char cs_mask_t |
enum cs_flag_comp_bits_t |
enum cs_flag_location_t |
inlinestatic |
[in] | flag_to_check | flag corresponding to the location to check |
[in] | reference | flag corresponding to the referenced support |
inlinestatic |
[in] | n_masks | number of masks to check |
[in] | masks | array of masks |
const char* cs_flag_str_location | ( | cs_flag_t | loc | ) |
extern |
extern |
extern |
extern |
extern |
extern |
extern |
extern |
extern |
extern |
extern |
extern |
extern |
extern |
extern |
extern |
extern |
extern |
extern |
extern |
extern |
extern |
extern |
extern |
