1 #ifndef __CS_CDO_SOLVE_H__
2 #define __CS_CDO_SOLVE_H__
74 double *normalization);
int cs_cdo_solve_vector_system(cs_lnum_t n_scatter_elts, bool interlace, const cs_param_sles_t *slesp, const cs_matrix_t *matrix, const cs_range_set_t *rset, cs_real_t normalization, bool rhs_redux, cs_sles_t *sles, cs_real_t *x, cs_real_t *b)
Solve a linear system arising from CDO schemes with vector-valued degrees of freedom (DoFs)....
Definition: cs_cdo_solve.c:503
int cs_cdo_solve_scalar_cell_system(cs_lnum_t n_dofs, const cs_param_sles_t *slesp, const cs_matrix_t *matrix, cs_real_t normalization, cs_sles_t *sles, cs_real_t *x, cs_real_t *b)
Solve a linear system arising with scalar-valued cell-based DoFs No rotation is taken into account wh...
Definition: cs_cdo_solve.c:307
int cs_cdo_solve_scalar_system(cs_lnum_t n_scatter_dofs, const cs_param_sles_t *slesp, const cs_matrix_t *matrix, const cs_range_set_t *rset, cs_real_t normalization, bool rhs_redux, cs_sles_t *sles, cs_real_t *x, cs_real_t *b)
Solve a linear system arising from CDO schemes with scalar-valued degrees of freedom.
Definition: cs_cdo_solve.c:403
void cs_cdo_solve_prepare_system(int stride, bool interlace, cs_lnum_t x_size, const cs_range_set_t *rset, bool rhs_redux, cs_real_t *x, cs_real_t *b)
Prepare a linear system and synchronize buffers in case of parallel or periodic computations....
Definition: cs_cdo_solve.c:229
void cs_cdo_solve_sync_rhs_norm(cs_param_resnorm_type_t type, double vol_tot, cs_lnum_t rhs_size, const cs_real_t rhs[], double *normalization)
Compute the value of the rhs norm used as a renormalization coefficient for the residual norm when so...
Definition: cs_cdo_solve.c:171
Definition: cs_defs.h:514
Definition: cs_defs.h:319
Definition: cs_defs.h:515
Definition: cs_defs.h:313
Definition: cs_matrix.h:110
Structure and routines handling the SLES settings stored inside a cs_param_sles_t structure.
Definition: cs_param_types.h:1021
struct _cs_sles_t cs_sles_t
Definition: cs_sles.h:68
Definition: cs_param_sles.h:213
Definition: cs_range_set.h:57
