Include dependency graph for cs_sles.h:Go to the source code of this file.
| typedef struct _cs_sles_t | cs_sles_t |
| typedef void() | cs_sles_setup_t(void *context, const char *name, const cs_matrix_t *a, int verbosity) |
| Function pointer for pre-resolution setup of a linear system's context. More... | |
| typedef cs_sles_convergence_state_t() | cs_sles_solve_t(void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residual, const cs_real_t *rhs, cs_real_t *vx, size_t aux_size, void *aux_vectors) |
| Function pointer for resolution of a linear system. More... | |
| typedef void() | cs_sles_free_t(void *context) |
| Function pointer for freeing of a linear system's context data. More... | |
| typedef void() | cs_sles_log_t(const void *context, cs_log_t log_type) |
| Function pointer for logging of linear solver history and performance data. More... | |
| typedef void *() | cs_sles_copy_t(const void *context) |
| Function pointer for creation of a solver context based on the copy of another. More... | |
| typedef void() | cs_sles_destroy_t(void **context) |
| typedef bool() | cs_sles_error_handler_t(cs_sles_t *sles, cs_sles_convergence_state_t state, const cs_matrix_t *a, const cs_real_t *rhs, cs_real_t *vx) |
| Function pointer for handling of non-convergence when solving a linear system. More... | |
| typedef void() | cs_sles_define_t(int f_id, const char *name, const cs_matrix_t *a) |
| Function pointer for the default definition of a sparse linear equation solver. More... | |
| typedef int() | cs_sles_verbosity_t(int f_id, const char *name) |
| Function pointer for the default definition of a sparse linear equation solver's verbosity. More... | |
Enumerations | |
| enum | cs_sles_convergence_state_t { CS_SLES_DIVERGED = -3 , CS_SLES_BREAKDOWN = -2 , CS_SLES_MAX_ITERATION = -1 , CS_SLES_ITERATING = 0 , CS_SLES_CONVERGED = 1 } |
| void | cs_sles_set_epzero (double new_value) |
| Set the threshold value used in the detection of immediate exit. More... | |
| double | cs_sles_get_epzero (void) |
| Get the current threshold value used in the detection of immediate exit. More... | |
| void | cs_sles_initialize (void) |
| Initialize sparse linear equation solver API. More... | |
| void | cs_sles_finalize (void) |
| Finalize sparse linear equation solver API. More... | |
| void | cs_sles_log (cs_log_t log_type) |
| cs_sles_t * | cs_sles_find (int f_id, const char *name) |
| Return pointer to linear system object, based on matching field id or system name. More... | |
| cs_sles_t * | cs_sles_find_or_add (int f_id, const char *name) |
| void | cs_sles_push (int f_id, const char *name) |
| Temporarily replace field id with name for matching calls to cs_sles_setup, cs_sles_solve, cs_sles_free, and other operations involving access through a field id. More... | |
| void | cs_sles_pop (int f_id) |
| Restore behavior temporarily modified by cs_sles_push. More... | |
| cs_sles_t * | cs_sles_define (int f_id, const char *name, void *context, const char *type_name, cs_sles_setup_t *setup_func, cs_sles_solve_t *solve_func, cs_sles_free_t *free_func, cs_sles_log_t *log_func, cs_sles_copy_t *copy_func, cs_sles_destroy_t *destroy_func) |
| Define sparse linear equation solver for a given field or equation name. More... | |
| void | cs_sles_set_verbosity (cs_sles_t *sles, int verbosity) |
| Set the verbosity for a given linear equation solver. More... | |
| int | cs_sles_get_verbosity (cs_sles_t *sles) |
| Get the verbosity for a given linear equation solver. More... | |
| void | cs_sles_set_post_output (cs_sles_t *sles, int writer_id) |
| Activate postprocessing output for a given linear equation solver. More... | |
| int | cs_sles_get_post_output (cs_sles_t *sles) |
| Return the id of the associated writer if postprocessing output is active for a given linear equation solver. More... | |
| const char * | cs_sles_get_type (cs_sles_t *sles) |
| Return type name of solver context. More... | |
| void * | cs_sles_get_context (cs_sles_t *sles) |
| Return pointer to solver context structure pointer. More... | |
| int | cs_sles_get_f_id (const cs_sles_t *sles) |
| Return field id associated with a given sparse linear equation solver. More... | |
| const char * | cs_sles_get_name (const cs_sles_t *sles) |
| Return name associated with a given sparse linear equation solver. More... | |
| bool | cs_sles_get_allow_no_op (const cs_sles_t *sles) |
| Query if immediate_return ("no-op") is allowed when initial guess is zero (solve by increments) and the RHS is already zero within the normalized tolerance criteria. More... | |
| void | cs_sles_set_allow_no_op (cs_sles_t *sles, bool allow_no_op) |
| Indicate if immediate_return ("no-op") is allowed when initial guess is zero (solve by increments) and the RHS is already zero within the normalized tolerance criteria. More... | |
| void | cs_sles_setup (cs_sles_t *sles, const cs_matrix_t *a) |
| Setup sparse linear equation solver. More... | |
| cs_sles_convergence_state_t | cs_sles_solve (cs_sles_t *sles, const cs_matrix_t *a, double precision, double r_norm, int *n_iter, double *residual, const cs_real_t *rhs, cs_real_t *vx, size_t aux_size, void *aux_vectors) |
| General sparse linear system resolution. More... | |
| void | cs_sles_free (cs_sles_t *sles) |
| Free sparse linear equation solver setup. More... | |
| int | cs_sles_copy (cs_sles_t *dest, const cs_sles_t *src) |
| Copy the definition of a sparse linear equation solver to another. More... | |
| void | cs_sles_set_error_handler (cs_sles_t *sles, cs_sles_error_handler_t *error_handler_func) |
| Associate a convergence error handler to a given sparse linear equation solver. More... | |
| cs_sles_define_t * | cs_sles_get_default_define (void) |
| Return pointer to default sparse linear solver definition function. More... | |
| void | cs_sles_set_default_define (cs_sles_define_t *define_func) |
| Set default sparse linear solver definition function. More... | |
| void | cs_sles_set_default_verbosity (cs_sles_verbosity_t *verbosity_func) |
| Set default verbosity definition function. More... | |
| void | cs_sles_post_error_output_def (const char *name, int mesh_id, const cs_matrix_t *a, const cs_real_t *rhs, cs_real_t *vx) |
| Output default post-processing data for failed system convergence. More... | |
| void | cs_sles_post_output_var (const char *name, int mesh_id, int location_id, int writer_id, int diag_block_size, cs_real_t var[]) |
| Output post-processing variable related to system convergence. More... | |
| const char * | cs_sles_base_name (int f_id, const char *name) |
| Return base name associated to a field id, name couple. More... | |
| const char * | cs_sles_name (int f_id, const char *name) |
| Return name associated to a field id, name couple. More... | |
| cs_sles_copy_t |
The new context copies the settings of the copied context, but not its setup data and logged info, such as performance data.
This type of function is optional, but enables associating different solvers to related systems (to differentiate logging) while using the same settings by default.
| [in] | context | context to copy |
| cs_sles_define_t |
The function may be associated using cs_sles_set_default_define, so that it may provide a definition that will be used when cs_sles_setup or cs_sles_solve is used for a system for which no matching call to cs_sles_define has been done.
The function should call cs_sles_define with arguments f_id and name, and appropriately chosen function pointers.
A pointer to the matrix of the system to be solved is also provided, so that the corresponding information may be used to better choose defaults.
| [in] | a | matrix |
| cs_sles_destroy_t |
Function pointer for destruction of a linear system solver context.
This function should free all context data, and will be called for each system when cs_sles_finalize is called.
| [in,out] | context | pointer to solver context |
| cs_sles_error_handler_t |
Such a function is optional, and may be used for a variety of purposes, such as logging, postprocessing, re-trying with different parameters, aborting the run, or any combination thereof.
An error handler may be associated with a given solver context using cs_sles_set_error_handler, in which case it will be called whenever convergence fails.
| [in] | status | convergence status |
| [in] | a | matrix |
| [in] | rhs | Right hand side |
| [out] | vx | System solution |
| cs_sles_free_t |
Note that this function should free resolution-related data, such as multigrid hierarchy, preconditioning, and any other temporary arrays or objects required for resolution, but should not free the whole context, as info used for logging (especially performance data) should be maintained.
| [in,out] | context | pointer to solver context. |
| cs_sles_log_t |
This function will be called for each solver when cs_sles_finalize is called.
| [in] | context | pointer to solver context |
| cs_sles_setup_t |
This setup may include building a multigrid hierarchy, or a preconditioner.
Use of this type of function is optional: the context is expected to maintain state, so that if a cs_sles_solve_t function is called before a cs_sles_setup_t function, the latter will be called automatically.
| [in] | name | pointer to name of linear system |
| [in] | a | matrix |
| cs_sles_solve_t |
If the associated cs_sles_setup_t function has not been called before this function, it will be called automatically.
The solution context setup by this call (or that of the matching cs_sles_setup_t function) will be maintained until the matching cs_sles_free_t function is called.
The matrix is not expected to change between successive calls, although the right hand side may. If the matrix changes, the associated cs_sles_setup_t or cs_sles_free_t function must be called between solves.
The system is considered to have converged when residual/r_norm <= precision, residual being the L2 norm of a.vx-rhs.
| [in] | a | matrix |
| [out] | vx | system solution |
| [in] | aux_size | number of elements in aux_vectors |
| typedef struct _cs_sles_t cs_sles_t |
| cs_sles_verbosity_t |
The function may be associated using cs_sles_set_default_verbosity, so that it may provide a definition that will be used when cs_sles_find_or_add is called.
| const char* cs_sles_base_name | ( | int | f_id, |
| const char * | name | ||
This is simply a utility function which will return its name argument if f_id < 0, and the associated field's name or label otherwise.
The intended use of this function is to allow associating different solvers to related systems, so as to differentiate logging, while using the same settings by default.
If the source solver does not provide a cs_sles_copy_t function, No modification is done to the solver. If the copy function is available, the context is copied, as are the matching function pointers.
If previous settings have been defined and used, they are saved as per cs_sles_define.
| [in,out] | dest | pointer to destination solver object |
| [in] | src | pointer to source solver object |
| cs_sles_t* cs_sles_define | ( | int | f_id, |
| const char * | name, | ||
| void * | context, | ||
| const char * | type_name, | ||
| cs_sles_setup_t * | setup_func, | ||
| cs_sles_solve_t * | solve_func, | ||
| cs_sles_free_t * | free_func, | ||
| cs_sles_log_t * | log_func, | ||
| cs_sles_copy_t * | copy_func, | ||
| cs_sles_destroy_t * | destroy_func | ||
If this system did not previously exist, it is added to the list of "known" systems.
The context pointer is used to point to a structure adapted to the function pointers given here, and combined with those functions, allows using both built-in, external, or user-defined solvers.
It is recommended the context type name provided here directly relate to the associated structure type (for example, "cs_sles_it_t" or "cs_multigrid_t").
| [in,out] | context | pointer to solver context management structure (cs_sles subsystem becomes owner) |
| [in] | type_name | context structure or object type name |
| [in] | setup_func | pointer to system setup function |
| [in] | solve_func | pointer to system solution function (also calls setup_func if not done yet or free_func called since last solve) |
| [in] | free_func | pointer function freeing system setup |
| [in] | log_func | pointer to system info logging function (optional, but recommended) |
| [in] | copy_func | pointer to settings copy function (optional) |
| [in] | destroy_func | pointer to function destroying solver context (called with cs_sles_finalize or with a new call to this function for the same system) |
| void cs_sles_finalize | ( | void | ) |
| cs_sles_t* cs_sles_find | ( | int | f_id, |
If this system did not previously exist, NULL is returned.
| cs_sles_t* cs_sles_find_or_add | ( | int | f_id, |
If this system did not previously exist, it is created and added to to the list of "known" systems. In this case, it will be usable only if cs_sles_define() is called for the same field id and name (in which case calling the present function is redundant), or if cs_sles_set_sefault_define() has been previously used to define the default solver policy.
| void cs_sles_free | ( | cs_sles_t * | sles | ) |
This function frees resolution-related data, such as multigrid hierarchy, preconditioning, and any other temporary arrays or objects required for resolution, but maintains context information such as that used for logging (especially performance data).
| bool cs_sles_get_allow_no_op | ( | const cs_sles_t * | sles | ) |
| [in] | sles | pointer to solver object |
| void* cs_sles_get_context | ( | cs_sles_t * | sles | ) |
The context structure depends on the type of solver used, which may in turn be determined by the string returned by cs_sles_get_type(). If may be used by appropriate functions specific to that type.
| cs_sles_define_t* cs_sles_get_default_define | ( | void | ) |
The associated function will be used to provide a definition when cs_sles_setup or cs_sles_solve is used for a system for which no matching call to cs_sles_define has been done.
| double cs_sles_get_epzero | ( | void | ) |
| int cs_sles_get_f_id | ( | const cs_sles_t * | sles | ) |
| const char* cs_sles_get_name | ( | const cs_sles_t * | sles | ) |
| int cs_sles_get_post_output | ( | cs_sles_t * | sles | ) |
| const char* cs_sles_get_type | ( | cs_sles_t * | sles | ) |
The returned string is intended to help determine which type is associated with the void * pointer returned by cs_sles_get_context for a given solver definition, so as to be able to call additional specific functions beyond the generic functions assigned to a cs_sles_t object.
If no type_name string was associated to the solver upon its definition by cs_sles_define, or it has not been defined yet, the string returned is "<undefined>". It is recommended the type name provided cs_sles_define directly relate to the associated structure type (for example, "cs_sles_it_t" or "cs_multigrid_t").
| int cs_sles_get_verbosity | ( | cs_sles_t * | sles | ) |
This verbosity will be used by cs_sles_setup and cs_sles_solve.
| void cs_sles_initialize | ( | void | ) |
| void cs_sles_log | ( | cs_log_t | log_type | ) |
| [in] | log_type | log type (CS_LOG_SETUP or CS_LOG_PERFORMANCE) |
| const char* cs_sles_name | ( | int | f_id, |
| void cs_sles_pop | ( | int | f_id | ) |
| void cs_sles_post_error_output_def | ( | const char * | name, |
| int | mesh_id, | ||
| cs_real_t * | vx | ||
| [in] | name | variable name |
| [in] | mesh_id | id of error output mesh, or 0 if none |
| [in] | a | linear equation matrix |
| [in,out] | vx | current system solution |
| void cs_sles_post_output_var | ( | const char * | name, |
| int | mesh_id, | ||
| int | location_id, | ||
| int | writer_id, | ||
| int | diag_block_size, | ||
| cs_real_t | var[] | ||
| [in] | location_id | mesh location id (cells or vertices) |
| [in] | writer_id | id of specified associated writer, or CS_POST_WRITER_ALL_ASSOCIATED for all |
| [in] | diag_block_size | block size for diagonal |
| [in,out] | var | variable values |
| void cs_sles_push | ( | int | f_id, |
ivar value, but specific solver options must still be set. In the future, a more consistent mechanism (using a zero ivar value or designing a cleaner method to handle those exceptional cases) is preferred. As such, only a stack depth of 1 is allowed.| [in] | f_id | associated field id, or < 0 |
| void cs_sles_set_allow_no_op | ( | cs_sles_t * | sles, |
| bool | allow_no_op | ||
| [in] | allow_no_op | true if immediate return is allowed, false if at least one iteration is required |
| void cs_sles_set_default_define | ( | cs_sles_define_t * | define_func | ) |
The provided function will be used to provide a definition when cs_sles_setup or cs_sles_solve is used for a system for which no matching call to cs_sles_define has been done.
| [in] | define_func | pointer to default definition function |
| void cs_sles_set_default_verbosity | ( | cs_sles_verbosity_t * | verbosity_func | ) |
The provided function will be used to define the verbosity when cs_sles_find_or_add is called.
| [in] | verbosity_func | pointer to default verbosity function |
| void cs_sles_set_epzero | ( | double | new_value | ) |
| void cs_sles_set_error_handler | ( | cs_sles_t * | sles, |
| cs_sles_error_handler_t * | error_handler_func | ||
The error will be called whenever convergence fails. To dissassociate the error handler, this function may be called with handler = NULL.
The association will only be successful if the matching solver has already been defined.
| [in] | error_handler_func | pointer to convergence error handler function |
| void cs_sles_set_post_output | ( | cs_sles_t * | sles, |
| int | writer_id | ||
This allows the output of the residual at the end of each solution series, using a single postprocessing writer. By default, no output is activated.
| [in] | writer_id | id of the writer |
| void cs_sles_set_verbosity | ( | cs_sles_t * | sles, |
| int | verbosity | ||
By default, the verbosity is set to 0, or the value returned by the function set with cs_sles_set_default_define().
| void cs_sles_setup | ( | cs_sles_t * | sles, |
| const cs_matrix_t * | a | ||
Use of this function is optional: if a cs_sles_solve is called for the same system before this function is called, the latter will be called automatically.
If no options were previously provided for the matching system, default options will be used.
| [in] | a | matrix |
| cs_sles_convergence_state_t cs_sles_solve | ( | cs_sles_t * | sles, |
| double | precision, | ||
| double | r_norm, | ||
| int * | n_iter, | ||
| double * | residual, | ||
| cs_real_t * | vx, | ||
| size_t | aux_size, | ||
| void * | aux_vectors | ||
Note that if cs_sles_setup was previously called for this system, and cs_sles_free has not been called since, the matrix provided should be the same. The optional separation between the two stages is intended to allow amortizing the cost of setup over multiple solutions.
| [in] | a | matrix |
| [in] | aux_size | size of aux_vectors (in bytes) |
