8.1
cs_log.h File Reference
#include "cs_timer.h"
#include "stdarg.h"
+ Include dependency graph for cs_log.h:
Enumerations
enum  cs_log_t { CS_LOG_DEFAULT , CS_LOG_SETUP , CS_LOG_PERFORMANCE , CS_LOG_N_TYPES }
void cs_log_default_activate (bool activate)
 Update "active" or "inactive" flag of default log. More...
bool cs_log_default_is_active (void)
size_t cs_log_strlen (const char *s)
 Count printable length of a character string. More...
void cs_log_strpad (char *dest, const char *src, size_t width, size_t destsize)
 Pad a string so that its printable length is the required length. More...
void cs_log_strpadl (char *dest, const char *src, size_t width, size_t destsize)
 Pad a string on the left so that its printable length is the required length. More...
void cs_log_binary_pp_int32 (int32_t code, char buf[33])
 Pretty-print int-32 based bit field to string. More...
int cs_log_vprintf (cs_log_t log, const char *format, va_list arg_ptr)
 Print log info to a given log type. More...
int cs_log_printf (cs_log_t log, const char *format,...)
int cs_log_printf_flush (cs_log_t log)
 Flush output of a log file. More...
void cs_log_separator (cs_log_t log)
 Print a separator line in a log file. More...
void cs_log_timer_array_header (cs_log_t log, int indent, const char *header_title, bool calls)
 Output timing data array header to a given log. More...
void cs_log_timer_array (cs_log_t log, int indent, int n_lines, const char *line_titles[], const unsigned calls[], const cs_timer_counter_t time_count[])
 Output timing data block to a given log. More...
int cs_glob_log_frequency
◆ cs_log_t
enum cs_log_t
Enumerator
CS_LOG_DEFAULT
CS_LOG_SETUP
CS_LOG_PERFORMANCE
CS_LOG_N_TYPES
◆ cs_log_binary_pp_int32()
void cs_log_binary_pp_int32 ( int32_t  code,
char  buf[33]
[in]codevalue to print
[out]bufoutput buffer (must be at least 33 bytes).
◆ cs_log_default_activate()
void cs_log_default_activate ( bool  activate)
This does not prevent output to the log file, but the flag can be queried using cs_log_default_is_active, so in most cases, this status should be checked before logging output
[in]activatetrue to activate, false to deactivate.
◆ cs_log_default_is_active()
bool cs_log_default_is_active ( void  )
This does not prevent output to the log file, but the flag can be queried using \
true if active, false otherwise.
◆ cs_log_printf()
int cs_log_printf ( cs_log_t  log,
const char *  format,
The format and variable arguments are similar to those of the printf() type functions.
In parallel, output is only handled by rank 0.
[in]loglog file type
[in]formatformat string, as printf() and family.
[in]...variable arguments based on format string.
number of characters printed, not counting the trailing '\0' used to end output strings
◆ cs_log_printf_flush()
int cs_log_printf_flush ( cs_log_t  log)
If the argument is set to CS_LOG_N_TYPES, all log files are flushed.
0 upon successful completion 0 is returned. Otherwise, EOF is returned and errno is set to indicate the error.
◆ cs_log_separator()
void cs_log_separator ( cs_log_t  log)
◆ cs_log_strlen()
size_t cs_log_strlen ( const char *  str)
This should also include UTF-8 strings.
[in]strpointer to printable string
printable length of character string.
◆ cs_log_strpad()
void cs_log_strpad ( char *  dest,
const char *  src,
size_t  width,
size_t  destsize
This allows pretty-printing with UTF-8 strings, whose actual length may be larger than their printable length in the presence of multibyte characters.
If either the printable length of the string is longer than the target width or the actual length is long than the destination buffer's size, it is truncated.
[out]destpointer to destination buffer
[in]srcpointer to printable string
[in]widthdesired printed length
[in]destsizedestination buffer size
◆ cs_log_strpadl()
void cs_log_strpadl ( char *  dest,
const char *  src,
size_t  width,
size_t  destsize
◆ cs_log_timer_array()
void cs_log_timer_array ( cs_log_t  log,
int  indent,
int  n_lines,
const char *  line_titles[],
If the optional array of call counters is used, only lines with a number of calls greater than 0 are logged.
[in]indentindentation before first column
[in]n_linesnumber of lines in array, excluding header
[in]line_titlesarray of titles for data lines
[in]callsoptional array of call counters, or NULL
[in]time_countarray of time counters
◆ cs_log_timer_array_header()
void cs_log_timer_array_header ( cs_log_t  log,
int  indent,
const char *  header_title,
bool  calls
[in]header_titletitle for optional header line
[in]callstrue if calls column is to be used
◆ cs_log_vprintf()
int cs_log_vprintf ( cs_log_t  log,
va_list  arg_ptr
The format and variable arguments are similar to those of the vprintf() type functions.
[in]arg_ptrvariable arguments list pointer
◆ cs_glob_log_frequency
extern
