#include "cs_defs.h"#include "bft_mem.h"#include "bft_printf.h"#include "cs_array.h"#include "cs_base.h"#include "cs_boundary.h"#include "cs_boundary_conditions_set_coeffs.h"#include "cs_boundary_zone.h"#include "cs_cell_to_vertex.h"#include "cs_cdo_quantities.h"#include "cs_cdo_connect.h"#include "cs_cdo_main.h"#include "cs_convection_diffusion.h"#include "cs_domain.h"#include "cs_domain_setup.h"#include "cs_equation.h"#include "cs_equation_iterative_solve.h"#include "cs_face_viscosity.h"#include "cs_field.h"#include "cs_field_default.h"#include "cs_field_pointer.h"#include "cs_field_operator.h"#include "cs_gui_mobile_mesh.h"#include "cs_interface.h"#include "cs_log.h"#include "cs_physical_constants.h"#include "cs_math.h"#include "cs_mesh.h"#include "cs_mesh_quantities.h"#include "cs_mesh_bad_cells.h"#include "cs_parall.h"#include "cs_restart.h"#include "cs_restart_default.h"#include "cs_time_step.h"#include "cs_ale.h"
Include dependency graph for cs_ale.c:Functions | |
| void | cs_f_ale_get_pointers (int **iale) |
| void | cs_ale_allocate (void) |
| Allocation of ialtyb and impale for the ALE structure. More... | |
| void | cs_ale_update_mesh_quantities (cs_real_t *min_vol, cs_real_t *max_vol, cs_real_t *tot_vol) |
| Compute cell and face centers of gravity, cell volumes and update bad cells. More... | |
| void | cs_ale_project_displacement (const int ale_bc_type[], const cs_real_3_t *meshv, const cs_real_33_t gradm[], const cs_real_3_t *claale, const cs_real_33_t *clbale, const cs_real_t *dt, cs_real_3_t *disp_proj) |
| Project the displacement on mesh vertices (solved on cell center). More... | |
| void | cs_ale_update_mesh (int itrale) |
| Update mesh in the ALE framework. More... | |
| void | cs_ale_update_bcs (int *ale_bc_type, cs_real_3_t *b_fluid_vel) |
| Update ALE BCs for required for the fluid. More... | |
| void | cs_ale_solve_mesh_velocity (int iterns) |
| Solve a Poisson equation on the mesh velocity in ALE framework. More... | |
| void | cs_ale_activate (void) |
| Activate the mesh velocity solving with CDO. More... | |
| bool | cs_ale_is_activated (void) |
| Test if mesh velocity solving with CDO is activated. More... | |
| void | cs_ale_init_setup (cs_domain_t *domain) |
| Setup the equations solving the mesh velocity. More... | |
| void | cs_ale_setup_boundaries (const cs_domain_t *domain) |
| void | cs_ale_finalize_setup (cs_domain_t *domain) |
| Finalize the setup stage for the equation of the mesh velocity. More... | |
| void | cs_ale_destroy_all (void) |
| Free the main structure related to the ALE mesh velocity solving. More... | |
| void | cs_ale_restart_read (cs_restart_t *r) |
| Read ALE data from restart file. More... | |
| void | cs_ale_restart_write (cs_restart_t *r) |
| Write ALE data from restart file. More... | |
| static cs_ale_data_t | _cs_glob_ale_data |
| cs_ale_type_t | cs_glob_ale = 0 |
| cs_ale_data_t * | cs_glob_ale_data = &_cs_glob_ale_data |
| void cs_ale_activate | ( | void | ) |
| void cs_ale_allocate | ( | void | ) |
| void cs_ale_destroy_all | ( | void | ) |
| void cs_ale_finalize_setup | ( | cs_domain_t * | domain | ) |
| void cs_ale_init_setup | ( | cs_domain_t * | domain | ) |
Setup the equations related to mesh deformation.
| bool cs_ale_is_activated | ( | void | ) |
| void cs_ale_project_displacement | ( | const int | ale_bc_type[], |
| const cs_real_3_t * | meshv, | ||
| const cs_real_33_t | gradm[], | ||
| const cs_real_3_t * | claale, | ||
| const cs_real_33_t * | clbale, | ||
| const cs_real_t * | dt, | ||
| cs_real_3_t * | disp_proj | ||
| [in] | ale_bc_type | Type of boundary for ALE |
| [in] | meshv | Mesh velocity |
| [in] | gradm | Mesh velocity gradient (du_i/dx_j : gradv[][i][j]) |
| [in] | claale | Boundary conditions A |
| [in] | clbale | Boundary conditions B |
| [in] | dt | Time step |
| [out] | disp_proj | Displacement projected on vertices |
| void cs_ale_restart_read | ( | cs_restart_t * | r | ) |
| [in,out] | r | associated restart file pointer |
| void cs_ale_restart_write | ( | cs_restart_t * | r | ) |
| void cs_ale_setup_boundaries | ( | const cs_domain_t * | domain | ) |
| [in] | domain | pointer to a cs_domain_t structure |
| void cs_ale_solve_mesh_velocity | ( | int | iterns | ) |
It also updates the mesh displacement so that it can be used to update mass fluxes (due to mesh displacement).
| void cs_ale_update_bcs | ( | int * | ale_bc_type, |
| cs_real_3_t * | b_fluid_vel | ||
| [out] | ale_bc_type | type of ALE bcs |
| [out] | b_fluid_vel | Fluid velocity at boundary faces |
| void cs_ale_update_mesh | ( | int | itrale | ) |
| [in] | itrale | number of the current ALE iteration |
| void cs_ale_update_mesh_quantities | ( | cs_real_t * | min_vol, |
| cs_real_t * | max_vol, | ||
| cs_real_t * | tot_vol | ||
| [out] | min_vol | Minimum cell volume |
| [out] | max_vol | Maximum cell volume |
| [out] | tot_vol | Total cell volume |
| void cs_f_ale_get_pointers | ( | int ** | iale | ) |
static |
| cs_ale_type_t cs_glob_ale = 0 |
| cs_ale_data_t* cs_glob_ale_data = &_cs_glob_ale_data |
