1 #ifndef __CS_CDO_CONNECT_H__
2 #define __CS_CDO_CONNECT_H__
53 #define CS_TRIANGLE_CASE 3
173 const cs_lnum_t _2e0 = 2*f2e_ids[start_idx],
174 _2e1 = 2*f2e_ids[start_idx+1];
178 *v1 = e2v_ids[_2e0+1];
179 *v2 = ((tmp != *v0) && (tmp != *v1)) ? tmp : e2v_ids[_2e1+1];
void cs_cdo_connect_dump(const cs_cdo_connect_t *connect)
Dump a cs_cdo_connect_t structure for debugging purpose.
Definition: cs_cdo_connect.c:1487
void cs_cdo_connect_allocate_cw_buffer(const cs_cdo_connect_t *connect)
Allocate and initialize the cell-wise buffer(s)
Definition: cs_cdo_connect.c:1280
void cs_cdo_connect_assign_vtx_ifs_rs(const cs_mesh_t *mesh, int n_vtx_dofs, bool interlaced, cs_interface_set_t **p_ifs, cs_range_set_t **p_rs)
Allocate and define a cs_range_set_t structure and a cs_interface_set_t structure for schemes with Do...
Definition: cs_cdo_connect.c:1384
void cs_cdo_connect_assign_face_ifs_rs(const cs_mesh_t *mesh, cs_lnum_t n_faces, int n_face_dofs, cs_interface_set_t **p_ifs, cs_range_set_t **p_rs)
void cs_cdo_connect_discrete_curl(const cs_cdo_connect_t *connect, const cs_real_t *edge_values, cs_real_t **p_curl_values)
Compute the discrete curl operator across each primal faces. From an edge-based array (seen as circul...
Definition: cs_cdo_connect.c:1445
cs_cdo_connect_t * cs_cdo_connect_free(const cs_mesh_t *mesh, cs_cdo_connect_t *connect)
Destroy a cs_cdo_connect_t structure.
Definition: cs_cdo_connect.c:1111
void cs_cdo_connect_log_summary(const cs_cdo_connect_t *connect, cs_flag_t eb_scheme_flag, cs_flag_t vb_scheme_flag, cs_flag_t vcb_scheme_flag)
Summary of the connectivity information.
Definition: cs_cdo_connect.c:1168
cs_cdo_connect_t * cs_cdo_connect_build(cs_mesh_t *mesh, cs_flag_t eb_scheme_flag, cs_flag_t fb_scheme_flag, cs_flag_t cb_scheme_flag, cs_flag_t vb_scheme_flag, cs_flag_t vcb_scheme_flag, cs_flag_t hho_scheme_flag)
Allocate and define a new cs_cdo_connect_t structure Range sets and interface sets are allocated and ...
Definition: cs_cdo_connect.c:934
void cs_cdo_connect_free_cw_buffer(void)
Free the cell-wise buffer(s)
Definition: cs_cdo_connect.c:1318
static void cs_connect_get_next_3_vertices(const cs_lnum_t *f2e_ids, const cs_lnum_t *e2v_ids, const cs_lnum_t start_idx, cs_lnum_t *v0, cs_lnum_t *v1, cs_lnum_t *v2)
Get the next three vertices in a row from a face to edge connectivity and a edge to vertex connectivi...
Definition: cs_cdo_connect.h:166
long long cs_cdo_connect_get_time_perfo(void)
Retrieve the time elapsed to build the cs_cdo_connect_t structure.
Definition: cs_cdo_connect.c:1365
double * cs_cdo_connect_get_cw_buffer(int thr_id)
Retrieve the cell-wise buffer associated to the current thread. Use cs_get_thread_id when the thread ...
Definition: cs_cdo_connect.c:1350
cs_interface_set_t * cs_cdo_connect_define_face_interface(const cs_mesh_t *mesh)
Create and define a new cs_interface_set_t structure on faces.
Definition: cs_defs.h:514
Definition: cs_defs.h:319
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:298
Definition: cs_defs.h:515
Definition: cs_defs.h:313
unsigned short int cs_flag_t
Definition: cs_defs.h:321
Definition: cs_interface.h:61
fvm_element_t
Definition: fvm_defs.h:48
cs_lnum_t v_max_cell_range
Definition: cs_cdo_connect.h:124
cs_gnum_t n_g_edges
int n_max_v2fc
Definition: cs_cdo_connect.h:132
cs_flag_t * cell_flag
Definition: cs_cdo_connect.h:114
int n_max_fbyc
Definition: cs_cdo_connect.h:130
cs_adjacency_t * v2v
Definition: cs_cdo_connect.h:137
cs_interface_set_t * vtx_ifs
Definition: cs_cdo_connect.h:72
int n_max_ebyc
Definition: cs_cdo_connect.h:129
int n_max_vbyc
Definition: cs_cdo_connect.h:128
cs_adjacency_t * c2f
Definition: cs_cdo_connect.h:115
int n_max_v2ec
Definition: cs_cdo_connect.h:133
int n_max_vbyf
Definition: cs_cdo_connect.h:131
cs_range_set_t * face_rset
Definition: cs_cdo_connect.h:104
cs_range_set_t * edge_rset
Definition: cs_cdo_connect.h:86
cs_lnum_t e_max_cell_range
Definition: cs_cdo_connect.h:123
cs_lnum_t n_cells_with_ghosts
Definition: cs_cdo_connect.h:111
cs_lnum_t n_cells
Definition: cs_cdo_connect.h:110
cs_range_set_t * vtx_rset
Definition: cs_cdo_connect.h:71
cs_adjacency_t * c2v
Definition: cs_cdo_connect.h:117
cs_adjacency_t * e2v
Definition: cs_cdo_connect.h:81
cs_lnum_t n_vertices
Definition: cs_cdo_connect.h:66
cs_adjacency_t * f2e
Definition: cs_cdo_connect.h:95
cs_adjacency_t * e2e
Definition: cs_cdo_connect.h:139
fvm_element_t * cell_type
Definition: cs_cdo_connect.h:113
cs_lnum_t n_edges
Definition: cs_cdo_connect.h:78
cs_interface_set_t * face_ifs
Definition: cs_cdo_connect.h:105
cs_adjacency_t * if2v
Definition: cs_cdo_connect.h:98
cs_adjacency_t * f2c
Definition: cs_cdo_connect.h:94
cs_adjacency_t * c2e
Definition: cs_cdo_connect.h:116
cs_interface_set_t * edge_ifs
Definition: cs_cdo_connect.h:87
cs_adjacency_t * bf2v
Definition: cs_cdo_connect.h:96
cs_adjacency_t * f2f
Definition: cs_cdo_connect.h:138
Definition: cs_range_set.h:57
