1 #ifndef __CS_RESTART_DEFAULT_H__
2 #define __CS_RESTART_DEFAULT_H__
Definition: cs_defs.h:514
Definition: cs_defs.h:515
struct _cs_map_name_to_id_t cs_map_name_to_id_t
Definition: cs_map.h:48
Definition: cs_restart.h:95
void cs_restart_read_variables(cs_restart_t *r, const cs_map_name_to_id_t *old_field_map, int t_id_flag, int read_flag[])
Read variables from checkpoint.
Definition: cs_restart_default.c:1954
void cs_restart_write_notebook_variables(cs_restart_t *r)
Write notebook parameters to main checkpoint.
Definition: cs_restart_default.c:2286
void cs_restart_read_field_info(cs_restart_t *r, cs_map_name_to_id_t **old_field_map)
Read field metadata from checkpoint.
Definition: cs_restart_default.c:1732
void cs_restart_read_notebook_variables(cs_restart_t *r)
Read notebook parameters from main checkpoint.
Definition: cs_restart_default.c:2223
cs_restart_file_t
Definition: cs_restart_default.h:54
@ CS_RESTART_MAIN
Definition: cs_restart_default.h:57
@ CS_RESTART_AUXILIARY
Definition: cs_restart_default.h:58
@ CS_RESTART_LES_INFLOW
Definition: cs_restart_default.h:66
@ CS_RESTART_N_RESTART_FILES
Definition: cs_restart_default.h:67
@ CS_RESTART_1D_WALL_THERMAL
Definition: cs_restart_default.h:64
@ CS_RESTART_LAGR_STAT
Definition: cs_restart_default.h:62
@ CS_RESTART_DISABLED
Definition: cs_restart_default.h:56
@ CS_RESTART_RAD_TRANSFER
Definition: cs_restart_default.h:59
@ CS_RESTART_LAGR
Definition: cs_restart_default.h:61
void cs_restart_read_fields(cs_restart_t *r, cs_restart_file_t r_id)
Loop over all fields and read them in the restart file which id is passed in argument if it matches t...
Definition: cs_restart_default.c:3171
void cs_restart_write_bc_coeffs(cs_restart_t *r)
Write boundary condition coefficients for all fields to checkpoint.
Definition: cs_restart_default.c:2766
void cs_restart_read_linked_fields(cs_restart_t *r, const cs_map_name_to_id_t *old_field_map, const char *key, int read_flag[])
Read fields depending on others from checkpoint.
Definition: cs_restart_default.c:2342
void cs_restart_write_field_vals(cs_restart_t *r, int f_id, int t_id)
Write field values to checkpoint.
Definition: cs_restart_default.c:3045
void cs_restart_read_bc_coeffs(cs_restart_t *r)
Read boundary condition coefficients for all fields from checkpoint.
Definition: cs_restart_default.c:2610
void cs_restart_write_variables(cs_restart_t *r, int t_id_flag, int write_flag[])
Write variables to checkpoint.
Definition: cs_restart_default.c:2104
void cs_restart_read_time_step_info(cs_restart_t *r)
Read restart time step info.
Definition: cs_restart_default.c:3071
int cs_restart_read_field_vals(cs_restart_t *r, int f_id, int t_id)
Read field values from checkpoint.
Definition: cs_restart_default.c:2880
int cs_restart_write_linked_fields(cs_restart_t *r, const char *key, int write_flag[])
Write fields depending on others to checkpoint.
Definition: cs_restart_default.c:2516
void cs_restart_write_fields(cs_restart_t *r, cs_restart_file_t r_id)
Loop over all fields and save them in the restart file which id is passed in argument if it matches t...
Definition: cs_restart_default.c:3146
void cs_restart_write_field_info(cs_restart_t *r)
Write field metadata to main checkpoint.
Definition: cs_restart_default.c:1872
