#include "cs_domain.h"
#include "cs_restart.h"
| void | cs_ale_allocate (void) |
| | Allocation of ialtyb and impale for the ALE structure. More...
| void | cs_ale_update_mesh_quantities (cs_real_t *min_vol, cs_real_t *max_vol, cs_real_t *tot_vol) |
| | Compute cell and face centers of gravity, cell volumes and update bad cells. More...
| void | cs_ale_project_displacement (const int ale_bc_type[], const cs_real_3_t *meshv, const cs_real_33_t gradm[], const cs_real_3_t *claale, const cs_real_33_t *clbale, const cs_real_t *dt, cs_real_3_t *disp_proj) |
| | Project the displacement on mesh vertices (solved on cell center). More...
| void | cs_ale_update_mesh (int itrale) |
| | Update mesh in the ALE framework. More...
| void | cs_ale_update_bcs (int *ale_bc_type, cs_real_3_t *b_fluid_vel) |
| | Update ALE BCs for required for the fluid. More...
| void | cs_ale_solve_mesh_velocity (int iterns) |
| | Solve a Poisson equation on the mesh velocity in ALE framework. More...
| void | cs_ale_activate (void) |
| | Activate the mesh velocity solving with CDO. More...
| bool | cs_ale_is_activated (void) |
| | Test if mesh velocity solving with CDO is activated. More...
| void | cs_ale_init_setup (cs_domain_t *domain) |
| | Setup the equations related to mesh deformation. More...
| void | cs_ale_setup_boundaries (const cs_domain_t *domain) |
| | Setup the equations solving the mesh velocity. More...
| void | cs_ale_finalize_setup (cs_domain_t *domain) |
| | Finalize the setup stage for the equation of the mesh velocity. More...
| void | cs_ale_destroy_all (void) |
| | Free the main structure related to the ALE mesh velocity solving. More...
| void | cs_ale_restart_read (cs_restart_t *r) |
| | Read ALE data from restart file. More...
| void | cs_ale_restart_write (cs_restart_t *r) |
| | Write ALE data from restart file. More...
◆ cs_ale_type_t
ALE computation type
| Enumerator |
| CS_ALE_NONE | no ALE
| CS_ALE_LEGACY | Mesh deformation computed with legacy operators
| CS_ALE_CDO | Mesh deformation computed with CDO
◆ cs_ale_activate()
| void cs_ale_activate |
void |
◆ cs_ale_allocate()
| void cs_ale_allocate |
void |
◆ cs_ale_destroy_all()
| void cs_ale_destroy_all |
void |
◆ cs_ale_finalize_setup()
- Parameters
◆ cs_ale_init_setup()
- Parameters
- Parameters
◆ cs_ale_is_activated()
| bool cs_ale_is_activated |
void |
- Returns
- true ifmesh velocity solving with CDO is requested, false otherwise
true if mesh velocity solving with CDO is requested, false otherwise
◆ cs_ale_project_displacement()
- Parameters
| [in] | ale_bc_type | Type of boundary for ALE |
| [in] | meshv | Mesh velocity |
| [in] | gradm | Mesh velocity gradient (du_i/dx_j : gradv[][i][j]) |
| [in] | claale | Boundary conditions A |
| [in] | clbale | Boundary conditions B |
| [in] | dt | Time step |
| [out] | disp_proj | Displacement projected on vertices |
◆ cs_ale_restart_read()
- Parameters
| [in,out] | r | associated restart file pointer |
◆ cs_ale_restart_write()
- Parameters
◆ cs_ale_setup_boundaries()
| void cs_ale_setup_boundaries |
const cs_domain_t * |
domain | ) |
- Parameters
◆ cs_ale_solve_mesh_velocity()
| void cs_ale_solve_mesh_velocity |
int |
iterns | ) |
It also updates the mesh displacement so that it can be used to update mass fluxes (due to mesh displacement).
- Parameters
◆ cs_ale_update_bcs()
| void cs_ale_update_bcs |
int * |
ale_bc_type, |
cs_real_3_t * |
b_fluid_vel |
- Parameters
| [out] | ale_bc_type | type of ALE bcs |
| [out] | b_fluid_vel | Fluid velocity at boundary faces |
◆ cs_ale_update_mesh()
| void cs_ale_update_mesh |
int |
itrale | ) |
- Parameters
| [in] | itrale | number of the current ALE iteration |
◆ cs_ale_update_mesh_quantities()
- Parameters
| [out] | min_vol | Minimum cell volume |
| [out] | max_vol | Maximum cell volume |
| [out] | tot_vol | Total cell volume |
◆ cs_glob_ale
◆ cs_glob_ale_data
◆ cs_glob_ale_n_ini_f
Number of sub-iterations for fluid flow initialization
◆ cs_glob_ale_need_init
| int cs_glob_ale_need_init |
extern |
Indicate whether an iteration to initialize ALE is required
