#include <ctype.h>
#include "cs_array.h"
#include "cs_field_pointer.h"
#include "cs_gradient.h"
#include "cs_halo.h"
#include "cs_halo_perio.h"
#include "cs_les_inflow.h"
#include "cs_map.h"
#include "cs_math.h"
#include "cs_mesh_location.h"
#include "cs_random.h"
#include "cs_time_step.h"
#include "cs_volume_zone.h"
#include "cs_restart_default.h"
void | cs_restart_read_field_info (cs_restart_t *r, cs_map_name_to_id_t **old_field_map) |
Read field metadata from checkpoint. More... | |
void | cs_restart_write_field_info (cs_restart_t *r) |
Write field metadata to main checkpoint. More... | |
void | cs_restart_read_variables (cs_restart_t *r, const cs_map_name_to_id_t *old_field_map, int t_id_flag, int read_flag[]) |
Read variables from checkpoint. More... | |
void | cs_restart_write_variables (cs_restart_t *r, int t_id_flag, int write_flag[]) |
Write variables to checkpoint. More... | |
void | cs_restart_read_linked_fields (cs_restart_t *r, const cs_map_name_to_id_t *old_field_map, const char *key, int read_flag[]) |
Read fields depending on others from checkpoint. More... | |
int | cs_restart_write_linked_fields (cs_restart_t *r, const char *key, int write_flag[]) |
Write fields depending on others to checkpoint. More... | |
void | cs_restart_read_bc_coeffs (cs_restart_t *r) |
Read boundary condition coefficients for all fields from checkpoint. More... | |
void | cs_restart_write_bc_coeffs (cs_restart_t *r) |
Write boundary condition coefficients for all fields to checkpoint. More... | |
int | cs_restart_read_field_vals (cs_restart_t *r, int f_id, int t_id) |
Read field values from checkpoint. More... | |
void | cs_restart_write_field_vals (cs_restart_t *r, int f_id, int t_id) |
Write field values to checkpoint. More... | |
void | cs_restart_read_time_step_info (cs_restart_t *r) |
Read restart time step info. More... | |
void | cs_restart_write_fields (cs_restart_t *r, cs_restart_file_t r_id) |
Loop over all fields and save them in the restart file which id is passed in argument if it matches their "restart_file" key value. More... | |
void | cs_restart_read_fields (cs_restart_t *r, cs_restart_file_t r_id) |
Loop over all fields and read them in the restart file which id is passed in argument if it matches their "restart_file" key value. More... | |
Checkpoint/restart handling for default application.
void cs_restart_read_bc_coeffs | ( | cs_restart_t * | r | ) |
[in,out] | r | associated restart file pointer |
void cs_restart_read_field_info | ( | cs_restart_t * | r, |
cs_map_name_to_id_t ** | old_field_map | ||
Old ids associated to each field are determined for future use. Note that when reading legacy files (code_saturne version 3.3 and below), the old id will actually be the old scalar id (-1 for others).
[out] | old_field_map | name to id map of fields in restart file |
int cs_restart_read_field_vals | ( | cs_restart_t * | r, |
int | f_id, | ||
int | t_id | ||
If the values are not found using the default rules based on the field's name, its name itself, or a "restart_rename" keyed string value, an old name may be used for compatibility with older files. For cell-based fields, the old name base is appended automatically with "_ce_phase01", except for scalars, where the name uses a different scheme, based on "scalaire_ce_%04" % s_num;
[in] | f_id | field id |
[in] | t_id | time id (0 for current, 1 for previous, ...) |
void cs_restart_read_fields | ( | cs_restart_t * | r, |
cs_restart_file_t | r_id | ||
[in] | r_id | value of the key "restart_file" |
void cs_restart_read_linked_fields | ( | cs_restart_t * | r, |
const cs_map_name_to_id_t * | old_field_map, | ||
const char * | key, | ||
int | read_flag[] | ||
Old ids associate to each field are determined for future use. Note that when reading legacy files (code_saturne version 3.3 and below), the old id will actually be the old scalar id (-1 for others).
[in] | old_field_map | name to id map of fields in restart file |
[in] | key | key for field association |
[in,out] | read_flag | optional flag to track fields read, or NULL; set to sum of 2^time_id for fields read, -1 for fields failed to read (size: n_fields) |
void cs_restart_read_time_step_info | ( | cs_restart_t * | r | ) |
void cs_restart_read_variables | ( | cs_restart_t * | r, |
int | t_id_flag, | ||
[in] | t_id_flag | -1: all time values; 0: current values; > 0: previous values |
[in,out] | read_flag | optional flag to track fields read, or NULL; set to sum of 2^time_id for fields read (size: n_fields) |
void cs_restart_write_bc_coeffs | ( | cs_restart_t * | r | ) |
void cs_restart_write_field_info | ( | cs_restart_t * | r | ) |
void cs_restart_write_field_vals | ( | cs_restart_t * | r, |
int | f_id, | ||
int | t_id | ||
void cs_restart_write_fields | ( | cs_restart_t * | r, |
int cs_restart_write_linked_fields | ( | cs_restart_t * | r, |
int | write_flag[] | ||
[in,out] | write_flag | optional flag to track fields written, or NULL; set to sum of 2^time_id for fields written (size: n_fields) |
void cs_restart_write_variables | ( | cs_restart_t * | r, |
