8.0
cs_halo_perio.h
1 #ifndef __CS_HALO_PERIO_H__
2 #define __CS_HALO_PERIO_H__
5  * Structure and function headers associated to periodicity
30 #include "cs_defs.h"
33  * Local headers
36 #include "cs_base.h"
37 #include "cs_halo.h"
38
44  * Type definitions
46
48  * Public function prototypes
50
51 /*----------------------------------------------------------------------------
52  * Apply transformation on coordinates.
53  *
54  * parameters:
55  * halo <-> halo associated with coordinates to synchronize
56  * sync_mode --> kind of halo treatment (standard or extended)
57  * coords --> coordinates on which transformation have to be done.
58  *----------------------------------------------------------------------------*/
59
60 void
62  cs_halo_type_t sync_mode,
63  cs_real_t *coords);
64
65 /*----------------------------------------------------------------------------
66  * Synchronize values for a real vector (interleaved) between periodic cells.
67  *
68  * parameters:
69  * halo <-> halo associated with variable to synchronize
70  * sync_mode --> type of halo treatment (standard or extended)
71  * var <-> vector to update
72  * incvar <-- specifies the increment for the elements of var
73  *----------------------------------------------------------------------------*/
74
75 void
77  cs_halo_type_t sync_mode,
78  cs_real_t var[],
79  int incvar);
80
81 /*----------------------------------------------------------------------------
82  * Synchronize values for a real tensor (interleaved) between periodic cells.
83  *
84  * parameters:
85  * halo <-> halo associated with variable to synchronize
86  * sync_mode --> kind of halo treatment (standard or extended)
87  * var <-> tensor to update
88  *----------------------------------------------------------------------------*/
89
90 void
92  cs_halo_type_t sync_mode,
93  cs_real_t var[]);
94
95 /*----------------------------------------------------------------------------
96  * Synchronize values for a real tensor (symmetric interleaved) between
97  * periodic cells.
98  *
99  * parameters:
100  * halo <-> halo associated with variable to synchronize
101  * sync_mode --> kind of halo treatment (standard or extended)
102  * var <-> symmetric tensor to update (6 values)
103  *----------------------------------------------------------------------------*/
104
105 void
107  cs_halo_type_t sync_mode,
108  cs_real_t var[]);
109
110 /*----------------------------------------------------------------------------
111  * Synchronize values for a real gradient of a tensor (symmetric interleaved)
112  * between periodic cells.
113  *
114  * parameters:
115  * halo <-> halo associated with variable to synchronize
116  * sync_mode <-- kind of halo treatment (standard or extended)
117  * var <-> symmetric tensor to update (6 values)
118  *----------------------------------------------------------------------------*/
119
120 void
122  cs_halo_type_t sync_mode,
123  cs_real_t var[]);
124
125 /*----------------------------------------------------------------------------*/
126
128
129 #endif /* __CS_HALO_PERIO_H__ */
130
Definition: cs_defs.h:509
Definition: cs_defs.h:319
cs_halo_type_t
Definition: cs_halo.h:56
void cs_halo_perio_sync_var_sym_tens(const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_real_t var[])
Definition: cs_halo_perio.c:573
void cs_halo_perio_sync_var_vect(const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_real_t var[], int incvar)
Definition: cs_halo_perio.c:434
void cs_halo_perio_sync_var_tens(const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_real_t var[])
Definition: cs_halo_perio.c:504
void cs_halo_perio_sync_coords(const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_real_t *coords)
Definition: cs_halo_perio.c:368
void cs_halo_perio_sync_var_sym_tens_grad(const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_real_t var[])
Definition: cs_halo_perio.c:642
Definition: cs_halo.h:77
