Module for calculation options. More...
Modules | |
| module | optcal |
Functions/Subroutines | |
| integer function | iscavr (iscal) |
| If scalar iscal represents the mean of the square of a scalar k, return k; otherwise, return 0. More... | |
| double precision function | visls0 (iscal) |
| subroutine | time_step_init |
| Initialize Fortran time step API. This maps Fortran pointers to global C structure members. More... | |
| subroutine | time_step_options_init |
| Initialize Fortran time step options API. This maps Fortran pointers to global C structure members. More... | |
| subroutine | thermal_model_init |
| Initialize Fortran thermal model API. This maps Fortran pointers to global C structure members. More... | |
| subroutine | turb_model_init |
| Initialize Fortran turbulence model API. This maps Fortran pointers to global C structure members. More... | |
| subroutine | wall_functions_init |
| Initialize Fortran wall functions API. This maps Fortran pointers to global C structure members. More... | |
| subroutine | turb_rans_model_init |
| Initialize Fortran RANS turbulence model API. This maps Fortran pointers to global C structure members. More... | |
| subroutine | turb_les_model_init |
| Initialize Fortran LES turbulence model API. This maps Fortran pointers to global C structure members. More... | |
| subroutine | turb_hybrid_model_init |
| Initialize Fortran hybrid turbulence model API. This maps Fortran pointers to global C structure members. More... | |
| subroutine | velocity_pressure_options_init |
| Initialize Fortran Stokes options API. This maps Fortran pointers to global C structure members. More... | |
| subroutine | space_disc_options_init |
| Initialize Fortran space discretisation options API. This maps Fortran pointers to global C structure members. More... | |
| subroutine | time_scheme_options_init |
| Initialize Fortran time scheme options API. This maps Fortran pointers to global C structure members. More... | |
| subroutine | restart_auxiliary_options_init |
| Initialize Fortran auxiliary options API. This maps Fortran pointers to global C structure members. More... | |
| subroutine | elec_option_init |
| Initialize Fortran ELEC options API. This maps Fortran pointers to global C structure members. More... | |
| integer(c_int), pointer, save | ischtp |
| time order of time stepping More... | |
| integer, save | istmpf |
| time order of the mass flux scheme The chosen value for istmpf will automatically determine the value given to the variable thetfl. More... | |
| integer(c_int), pointer, save | itpcol |
| Time scheme option: More... | |
| integer(c_int), pointer, save | nterup |
| number of iterations on the velocity-pressure coupling on Navier-Stokes (for the U/P inner iterations scheme) More... | |
| integer, save | isno2t |
| isno2t specifies the time scheme activated for the source terms of the momentum equation, apart from convection and diffusion (for instance: head loss, transposed gradient, ...). More... | |
| integer(c_int), pointer, save | isto2t |
| Time scheme for source terms of turbulence equations (see isto2t in cs_time_scheme_t). More... | |
| integer, save | initvi |
| initvi : =1 if total viscosity read from checkpoint file More... | |
| integer, save | initro |
| initro : =1 if density read from checkpoint file More... | |
| integer, save | initcp |
| initcp : =1 if specific heat read from checkpoint file More... | |
| double precision, save | thetsn |
-scheme for the source terms in the Navier-Stokes equations when the source term extrapolation has been activated (see isno2t), following the formula .The value of = thetsn is deduced from the value chosen for isno2t. Generally only the value 0.5 is used. More... | |
| real(c_double), pointer, save | thetst |
The value of (see thetst in cs_time_scheme_t). More... | |
| double precision, save | thetvi |
-scheme for the extrapolation of the physical property "total viscosity" when the extrapolation has been activated (see time_extrapolated key word), according to the formula .The value of = thetvi is deduced from the value chosen for time_extrapolated key word for the viscosity. Generally, only the value 0.5 is used. More... | |
| double precision, save | thetcp |
-scheme for the extrapolation of the physical property "specific heat" when the extrapolation has been activated (see time_extrapolated field key int), according to the formula .The value of = thetcp is deduced from the value chosen for the specific heat. Generally, only the value 0.5 is used. More... | |
| real(c_double), pointer, save | epsup |
| relative precision for the convergence test of the iterative process on velocity-pressure coupling (inner iterations) More... | |
| real(c_double), pointer, save | xnrmu |
norm of the increment of the iterative process on velocity-pressure coupling (inner iterations) More... | |
| real(c_double), pointer, save | xnrmu0 |
norm of (used by velocity-pressure inner iterations) More... | |
| integer(c_int), pointer, save | iflxmw |
| integer(c_int), pointer, save | imrgra |
| type of gradient reconstruction More... | |
| integer(c_int), pointer, save | imvisf |
| face viscosity field interpolation More... | |
| integer, save | isuite |
| Indicator of a calculation restart (=1) or not (=0). This value is set automatically by the code; depending on whether a restart directory is present, and should not be modified by the user. More... | |
| integer(c_int), pointer, save | ileaux |
| Indicates the reading (=1) or not (=0) of the auxiliary calculation restart file Useful only in the case of a calculation restart. More... | |
| integer(c_int), pointer, save | iecaux |
| Indicates the writing (=1) or not (=0) of the auxiliary calculation restart file. More... | |
| integer, save | isuit1 |
| integer(c_int), pointer, save | ntpabs |
| Absolute time step number for previous calculation. More... | |
| integer(c_int), pointer, save | ntcabs |
| Current absolute time step number. In case of restart, this is equal to ntpabs + number of new iterations. More... | |
| integer(c_int), pointer, save | ntmabs |
| Maximum absolute time step number. More... | |
| integer(c_int), pointer, save | ntinit |
| Number of time steps for initalization (for all steps between 0 and ntinit, pressure is re-set to 0 before prediction correction). More... | |
| real(c_double), pointer, save | ttpabs |
| Absolute time value for previous calculation. More... | |
| real(c_double), pointer, save | ttcabs |
| Current absolute time. More... | |
| real(c_double), pointer, save | ttmabs |
| Maximum absolute time. More... | |
| integer(c_int), pointer, save | iptlro |
| Clip the time step with respect to the buoyant effects. More... | |
| integer(c_int), pointer, save | idtvar |
| option for a variable time step More... | |
| real(c_double), pointer, save | dtref |
| Reference time step. More... | |
| real(c_double), pointer, save | coumax |
| maximum Courant number (when idtvar is different from 0) More... | |
| real(c_double), pointer, save | cflmmx |
| maximum Courant number for the continuity equation in compressible model More... | |
| real(c_double), pointer, save | foumax |
| maximum Fourier number (when idtvar is different from 0) More... | |
| real(c_double), pointer, save | varrdt |
| maximum allowed relative increase in the calculated time step value between two successive time steps (to ensure stability, any decrease in the time step is immediate and without limit). Useful when idtvar is different from 0. More... | |
| real(c_double), pointer, save | dtmin |
| lower limit for the calculated time step when idtvar is different from 0. Take dtmin = min (ld/ud, sqrt(lt/(gdelta rho/rho)), ...) More... | |
| real(c_double), pointer, save | dtmax |
| upper limit for the calculated time step when idtvar is different from 0. Take dtmax = max (ld/ud, sqrt(lt/(gdelta rho/rho)), ...) More... | |
| real(c_double), pointer, save | relxst |
| relaxation coefficient for the steady algorithm relxst = 1 : no relaxation. More... | |
| integer(c_int), pointer, save | itherm |
| thermal model More... | |
| integer(c_int), pointer, save | itpscl |
| Temperature scale. More... | |
| integer(c_int), pointer, save | iscalt |
| Index of the thermal scalar (temperature, energy or enthalpy) More... | |
| integer(c_int), pointer, save | iturb |
| integer(c_int), pointer, save | itytur |
| Class of turbulence model (integer value iturb/10) More... | |
| integer(c_int), pointer, save | hybrid_turb |
| Activation of Hybrid RANS/LES model (only valid for iturb equal to 60 or 51) More... | |
| integer(c_int), pointer, save | irccor |
| Activation of rotation/curvature correction for eddy viscosity turbulence models. More... | |
| integer(c_int), pointer, save | itycor |
| Type of rotation/curvature correction for eddy viscosity turbulence models. More... | |
| integer(c_int), pointer, save | idirsm |
| Turbulent diffusion model for second moment closure. More... | |
| integer(c_int), pointer, save | iwallf |
| Wall functions Indicates the type of wall function used for the velocity boundary conditions on a frictional wall. More... | |
| integer(c_int), pointer, save | iwalfs |
| Wall functions for scalar. More... | |
| integer(c_int), pointer, save | iclkep |
Indicates the clipping method used for and , for the and v2f models. More... | |
| integer(c_int), pointer, save | igrhok |
Indicates if the term is taken into account in the velocity equation. More... | |
| integer(c_int), pointer, save | igrake |
Indicates if the terms related to gravity are taken into account in the equations of . More... | |
| integer(c_int), pointer, save | igrari |
| integer(c_int), pointer, save | ikecou |
Indicates if the coupling of the source terms of and or and is taken into account or not. More... | |
| integer(c_int), pointer, save | reinit_turb |
| Advanced re-init for EBRSM and k-omega models. More... | |
| integer(c_int), pointer, save | irijco |
Coupled solving of . More... | |
| integer(c_int), pointer, save | irijnu |
pseudo eddy viscosity in the matrix of momentum equation to partially implicit More... | |
| integer(c_int), pointer, save | irijrb |
accurate treatment of at the boundary (see condli) More... | |
| integer(c_int), pointer, save | irijec |
Indicates if the wall echo terms in LRR model are taken into account: More... | |
| integer(c_int), pointer, save | idifre |
whole treatment of the diagonal part of the diffusion tensor of and More... | |
| integer(c_int), pointer, save | iclsyr |
partial implicitation of symmetry BCs of More... | |
| integer(c_int), pointer, save | iclptr |
partial implicitation of wall BCs of More... | |
| integer(c_int), pointer, save | idries |
Activates or the van Driest wall-damping for the Smagorinsky constant (the Smagorinsky constant is multiplied by the damping function , where designates the non-dimensional distance to the nearest wall). More... | |
| integer(c_int), pointer, save | iicc |
| Applied or not the Internal Consistency Constraint (ICC) for the HTLES model, in order to recover the correct RANS behavior when the energy ratio is forced to one in the RANS region: More... | |
| integer(c_int), pointer, save | ishield |
Applied or not the two-fold shielding function ( of HTLES, to properly control the RANS-to-LES transition in the vicinity of the wall: More... | |
| integer, save | ikwcln |
| Wall boundary condition on omega in k-omega SST 0: Deprecated Neumann boundary condition 1: Dirichlet boundary condition consistent with Menter's original model: w_wall = 60*nu/(beta*d**2) More... | |
| integer(c_int), pointer, save | i_les_balance |
| Activates or not the LES balance module. More... | |
| integer, save | nvarcl |
| number of variable (deprecated, used only for compatibility) More... | |
| integer(c_int), pointer, save | ivisse |
Indicates whether the source terms in transposed gradient and velocity divergence should be taken into account in the momentum equation. In the compressible module, these terms also account for the volume viscosity (cf. viscv0 and iviscv) : More... | |
| integer(c_int), pointer, save | irevmc |
| Reconstruction of the velocity field with the updated pressure option. More... | |
| integer(c_int), pointer, save | iprco |
| Compute the pressure step thanks to the continuity equation. More... | |
| real(c_double), pointer, save | arak |
| Arakawa multiplicator for the Rhie and Chow filter (1 by default) More... | |
| integer(c_int), pointer, save | rcfact |
| Factor of the Rhie and Chow filter: More... | |
| integer(c_int), pointer, save | staggered |
| 1D staggered scheme option: More... | |
| integer(c_int), pointer, save | ipucou |
| indicates the algorithm for velocity-pressure coupling: More... | |
| integer(c_int), pointer, save | iccvfg |
| integer(c_int), pointer, save | idilat |
| Algorithm to take into account the density variation in time. More... | |
| integer, save | ipredfl |
| Option to switch on massflux prediction befor momentum solving to be fully conservative in momentum over time for variable density flows. This option is to be removed. More... | |
| real(c_double), pointer, save | epsdp |
| parameter of diagonal pressure strengthening More... | |
| integer, dimension(ntypmx), save | idebty |
| integer, dimension(ntypmx), save | ifinty |
| integer(c_int), pointer, save | itbrrb |
| accurate treatment of the wall temperature More... | |
| integer(c_int), pointer, save | iphydr |
| improve static pressure algorithm More... | |
| integer(c_int), pointer, save | igprij |
| integer(c_int), pointer, save | igpust |
| integer(c_int), pointer, save | iifren |
| indicates the presence of a Bernoulli boundary face (automatically computed) More... | |
| integer, save | ifrslb |
| number of the closest free standard outlet (or free inlet) face to xyzp0 More... | |
| integer, save | itbslb |
| max of ifrslb on all ranks, standard outlet face presence indicator More... | |
| integer(c_int), pointer, save | icalhy |
| compute the hydrostatic pressure in order to compute the Dirichlet conditions on the pressure at outlets More... | |
| integer(c_int), pointer, save | irecmf |
| use interpolated face diffusion coefficient instead of cell diffusion coefficient for the mass flux reconstruction for the non-orthogonalities More... | |
| logical(c_bool), pointer, save | fluid_solid |
| Has a solid zone where dynamics must be killed? More... | |
| integer, save | itagms |
| choice the way to compute the wall temperature at the solid/fluid interface coupled with condensation to the metal mass structures wall More... | |
| integer, dimension(nestmx), save | iescal |
| iescal indicates the calculation mode for the error estimator iespre, iesder, iescor or iestot for the Navier-Stokes equation: More... | |
| integer(c_int), pointer, save | n_buoyant_scal |
| n_buoyant_scal is the number of buoyant scalar It will be zero if there is no buoyant scalar More... | |
| integer(c_int), pointer, save | iprcdo |
| Dicretization method for pressure. More... | |
| integer(c_int), pointer, save | ivofmt |
| VoF model (sum of masks defining VoF model and submodels). See defined masks in Masks used to specify Volume of Fluid models. More... | |
| integer(c_int), pointer, save | idrift |
| integer | vof_enabled |
| Volume of Fluid model. More... | |
| integer | vof_free_surface |
| Free surface model. More... | |
| integer | vof_merkle_mass_transfer |
| Mass transfer Merkle model for vaporization / condensation (cavitation) More... | |
| integer, save | ncpdct |
| Global head losses indicator (ie number of head loss zones) More... | |
| integer, save | nctsmt |
| Indicateur termes sources de masse global (ie somme sur les processeurs de ncetsm) More... | |
| integer, save | nftcdt |
| Global indicator of condensation source terms (ie. sum on the processors of nfbpcd) cells associated to the face with condensation phenomenon. More... | |
| integer(c_int), pointer, save | iporos |
| integer, save | ineedy |
| integer, save | imajdy |
| integer, save | icdpar |
Specifies the method used to calculate the distance to the wall y and the non-dimensional distance for all the cells of the calculation domain (when necessary): More... | |
| integer, dimension(nscamx), save | iscasp |
| iscasp(ii) : index of the ii^th species (0 if not a species) More... | |
| integer | drift_scalar_add_drift_flux |
| flag for computing the drift mass flux: (for coal classes for instance, only the first scalar of a class compute the drift flux of the class and the other scalars use it without recomputing it) More... | |
| integer | drift_scalar_thermophoresis |
| flag for activating thermophoresis for drift scalars More... | |
| integer | drift_scalar_turbophoresis |
| flag for activating turbophoresis for drift scalars More... | |
| integer | drift_scalar_electrophoresis |
| integer | drift_scalar_centrifugalforce |
| flag for activating the centrifugal force for drift scalars More... | |
| integer | drift_scalar_imposed_mass_flux |
| flag for activating imposed mass flux More... | |
| integer | drift_scalar_zero_bndy_flux |
| flag for seting the mass flux to zero at all boundaries More... | |
| integer | drift_scalar_zero_bndy_flux_at_walls |
| flag for seting the mass flux to zero at walls only More... | |
| integer | isotropic_diffusion |
| flag for isotropic diffusion More... | |
| integer | orthotropic_diffusion |
| flag for orthotropic diffusion More... | |
| integer | anisotropic_left_diffusion |
| flag for diffusion by a left-multiplied symmetric 3x3 tensor More... | |
| integer | anisotropic_right_diffusion |
| integer | anisotropic_diffusion |
| flag for diffusion by a symmetric 3x3 tensor More... | |
| integer(c_int), pointer, save | ngazge |
| ngazge : number of species for electric arc More... | |
| integer(c_int), pointer, save | ielcor |
| ielcor : 0 : electric arc scaling desactivate 1 : electric arc scaling activate More... | |
| real(c_double), pointer, save | pot_diff |
| pot_diff : potential between electrods More... | |
| real(c_double), pointer, save | coejou |
| coejou : scaling coefficient More... | |
| real(c_double), pointer, save | elcou |
| elcou : current More... | |
| real(c_double), pointer, save | couimp |
| pot_diff : imposed value for current More... | |
| integer(c_int), pointer, save | irestrike |
| irestrike : 0 : restrike mode off 1 : restrike mode on More... | |
| real(c_double), pointer, save | restrike_point_x |
| restrike_point : coordinate of restrike point More... | |
| real(c_double), pointer, save | restrike_point_y |
| real(c_double), pointer, save | restrike_point_z |
| integer(c_int), pointer, save | ntdcla |
| ntdcla : start iteration for restrike More... | |
