7.3
Time step options and variables
+ Collaboration diagram for Time step options and variables:
integer(c_int), pointer, save ntpabs
 Absolute time step number for previous calculation. More...
integer(c_int), pointer, save ntcabs
 Current absolute time step number. In case of restart, this is equal to ntpabs + number of new iterations. More...
integer(c_int), pointer, save ntmabs
 Maximum absolute time step number. More...
integer(c_int), pointer, save ntinit
 Number of time steps for initalization (for all steps between 0 and ntinit, pressure is re-set to 0 before prediction correction). More...
real(c_double), pointer, save ttpabs
 Absolute time value for previous calculation. More...
real(c_double), pointer, save ttcabs
 Current absolute time. More...
real(c_double), pointer, save ttmabs
 Maximum absolute time. More...
integer(c_int), pointer, save iptlro
 Clip the time step with respect to the buoyant effects. More...
integer(c_int), pointer, save idtvar
 option for a variable time step More...
real(c_double), pointer, save dtref
 Reference time step. More...
real(c_double), pointer, save coumax
 maximum Courant number (when idtvar is different from 0) More...
real(c_double), pointer, save cflmmx
 maximum Courant number for the continuity equation in compressible model More...
real(c_double), pointer, save foumax
 maximum Fourier number (when idtvar is different from 0) More...
real(c_double), pointer, save varrdt
 maximum allowed relative increase in the calculated time step value between two successive time steps (to ensure stability, any decrease in the time step is immediate and without limit).
Useful when idtvar is different from 0. More...
real(c_double), pointer, save dtmin
 lower limit for the calculated time step when idtvar is different from 0.
Take dtmin = min (ld/ud, sqrt(lt/(gdelta rho/rho)), ...) More...
real(c_double), pointer, save dtmax
 upper limit for the calculated time step when idtvar is different from 0.
Take dtmax = max (ld/ud, sqrt(lt/(gdelta rho/rho)), ...) More...
real(c_double), pointer, save relxst
 relaxation coefficient for the steady algorithm relxst = 1 : no relaxation. More...
◆ cflmmx
◆ coumax
◆ dtmax
◆ dtmin
◆ dtref
This is the time step value used in the case of a calculation run with a uniform and constant time step, i.e. idtvar =0 (restart calculation or not). It is the value used to initialize the time step in the case of an initial calculation run with a non-constant time step(idtvar=1 or 2). It is also the value used to initialise the time step in the case of a restart calculation in which the type of time step has been changed (for instance, idtvar=1 in the new calculation and idtvar = 0 or 2 in the previous calculation).
See Time step modification for examples.
◆ foumax
◆ idtvar
  • -1: steady algorithm
  • 0: constant time step
  • 1: time step constant in space but variable in time
  • 2: variable time step in space and in time If the numerical scheme is a second-order in time, only the option 0 is allowed.
◆ iptlro
When density gradients and gravity are present, a local thermal time step can be calculated, based on the Brunt-Vaisala frequency. In numerical simulations, it is usually wise for the time step to be lower than this limit, otherwise numerical instabilities may appear.
iptlro indicates whether the time step should be limited to the local thermal time step (=1) or not (=0).
When iptlro=1, the log shows the number of cells where the time step has been clipped due to the thermal criterion, as well as the maximum ratio between the time step and the maximum thermal time step. If idtvar=0, since the time step is fixed and cannot be clipped, this ratio can be greater than 1. When idtvar > 0, this ratio will be less than 1, except if the constraint dtmin has prevented the code from reaching a sufficiently low value for dt. Useful when density gradients and gravity are present.
◆ ntcabs
◆ ntinit
◆ ntmabs
For the restart calculations, ntmabs takes into account the number of time steps of the previous calculations. For instance, after a first calculation of 3 time steps, a restart file of 2 time steps is realised by setting ntmabs = 3+2 = 5
◆ ntpabs
In the case of a restart calculation, ntpabs is read from the restart file. Otherwise, it is initialised to 0 ntpabs is initialised automatically by the code, its value is not to be modified by the user.
◆ relxst
◆ ttcabs
For the restart calculations, ttcabs takes into account the physical time of the previous calculations.
If the time step is uniform (idtvar = 0 or 1), ttcabs increases of dt (value of the time step) at each iteration. If the time step is non-uniform (idtvar=2), ttcabs increases of dtref at each time step.
ttcabs} is initialised and updated automatically by the code, its value is not to be modified by the user.
◆ ttmabs
◆ ttpabs
In the case of a restart calculation, ttpabs is read from the restart file. Otherwise it is initialised to 0.
ttpabs is initialised automatically by the code, its value is not to be modified by the user.
◆ varrdt
