#include "cs_defs.h"#include <assert.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include <math.h>#include "bft_mem.h"#include "bft_error.h"#include "bft_printf.h"#include "cs_assert.h"#include "cs_field.h"#include "cs_field_pointer.h"#include "cs_function.h"#include "cs_gradient.h"#include "cs_log.h"#include "cs_mesh.h"#include "cs_parall.h"#include "cs_parameters.h"#include "cs_mesh_location.h"#include "cs_time_step.h"#include "cs_wall_functions.h"#include "cs_turbulence_model.h"#include "cs_math.h"#include "cs_log_iteration.h"
Include dependency graph for cs_turbulence_model.c:Functions | |
| void | cs_turb_model_init (void) |
| Initialize turbulence model structures. More... | |
| void | cs_set_type_order_turbulence_model (void) |
| Initialize type and order members of turbulence model structure. More... | |
| cs_turb_model_t * | cs_get_glob_turb_model (void) |
| Provide write access to turbulence model structure. More... | |
| void | cs_set_glob_turb_model (void) |
| Set global pointer to turbulence model structure. More... | |
| void | cs_turb_compute_constants (void) |
| Compute turbulence model constants, some of which may depend on the model choice. More... | |
| cs_turb_ref_values_t * | cs_get_glob_turb_ref_values (void) |
| Provide access to cs_glob_turb_ref_values. More... | |
| cs_turb_rans_model_t * | cs_get_glob_turb_rans_model (void) |
| Provide access to cs_glob_turb_rans_model. More... | |
| cs_turb_les_model_t * | cs_get_glob_turb_les_model (void) |
| Provide access to cs_glob_turb_les_model. More... | |
| cs_turb_hybrid_model_t * | cs_get_glob_turb_hybrid_model (void) |
| Provide access to cs_glob_turb_hybrid_model. More... | |
| void | cs_turb_model_log_setup (void) |
| Print the turbulence model parameters to setup.log. More... | |
| void | cs_turb_constants_log_setup (void) |
| Print the turbulent constants to setup.log. More... | |
| void | cs_clip_turbulent_fluxes (int flux_id, int variance_id) |
| Clipping for the turbulence flux vector. More... | |
| void | cs_turbulence_function_k (int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals) |
| Return or estimate the value of the turbulent kinetic energy over specified elements. More... | |
| void | cs_turbulence_function_eps (int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals) |
| Return or estimate the value of the turbulent dissipation over specified elements. More... | |
| void | cs_turbulence_function_rij (int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals) |
| Return or estimate the value of the Reynolds stresses over specified elements. More... | |
| double | cs_turb_xkappa = 0.42 |
| double | cs_turb_vdriest = 25.6 |
| double | cs_turb_cstlog = 5.2 |
| double | cs_turb_cstlog_rough = 8.5 |
| double | cs_turb_cstlog_alpha |
| double | cs_turb_apow = 8.3 |
| double | cs_turb_bpow = 1.0/7.0 |
| double | cs_turb_dpow = -1. |
| double | cs_turb_cmu = 0.09 |
| double | cs_turb_cmu025 = 0.547722557 |
| double | cs_turb_ce1 = 1.44 |
| double | cs_turb_ce2 = 1.92 |
| double | cs_turb_ce4 = 1.20 |
| double | cs_turb_crij1 = 1.80 |
| double | cs_turb_crij2 = 0.60 |
| double | cs_turb_crij3 = 0.55 |
| double | cs_turb_crijp1 = 0.50 |
| double | cs_turb_crijp2 = 0.30 |
| double | cs_turb_cssge2 = 1.83 |
| double | cs_turb_cssgs1 = 1.70 |
| double | cs_turb_cssgs2 = -1.05 |
| double | cs_turb_cssgr1 = 0.90 |
| double | cs_turb_cssgr2 = 0.80 |
| double | cs_turb_cssgr3 = 0.65 |
| double | cs_turb_cssgr4 = 0.625 |
| double | cs_turb_cssgr5 = 0.20 |
| double | cs_turb_cebms1 = 1.70 |
| double | cs_turb_cebms2 = 0. |
| double | cs_turb_cebmr1 = 0.90 |
| double | cs_turb_cebmr2 = 0.80 |
| double | cs_turb_cebmr3 = 0.65 |
| double | cs_turb_cebmr4 = 0.625 |
| double | cs_turb_cebmr5 = 0.20 |
| double | cs_turb_csrij |
| double | cs_turb_cebme2 = 1.83 |
| double | cs_turb_cebmmu = 0.22 |
| double | cs_turb_xcl = 0.122 |
| double | cs_turb_xa1 = 0.1 |
| double | cs_turb_xct = 6.0 |
| double | cs_turb_xceta = 80.0 |
| double | cs_turb_cpale1 = 1.44 |
| double | cs_turb_cpale2 = 1.83 |
| double | cs_turb_cpale3 = 2.3 |
| double | cs_turb_cpale4 = 0.4 |
| double | cs_turb_cpalc1 = 1.7 |
| double | cs_turb_cpalc2 = 0.9 |
| double | cs_turb_cpalct = 4.0 |
| double | cs_turb_cpalcl = 0.164 |
| double | cs_turb_cpalet = 75.0 |
| double | cs_turb_ckwsk1 = 1.0/0.85 |
| double | cs_turb_ckwsk2 = 1.0 |
| double | cs_turb_ckwsw1 = 2.0 |
| double | cs_turb_ckwsw2 = 1.0/0.856 |
| double | cs_turb_ckwbt1 = 0.075 |
| double | cs_turb_ckwbt2 = 0.0828 |
| double | cs_turb_ckwgm1 = -1. |
| double | cs_turb_ckwgm2 = -1. |
| double | cs_turb_ckwa1 = 0.31 |
| double | cs_turb_ckwc1 = 10.0 |
| double | cs_turb_cddes = 0.65 |
| double | cs_turb_csas = 0.11 |
| double | cs_turb_csas_eta2 = 3.51 |
| double | cs_turb_chtles_bt0 = 0.48 |
| double | cs_turb_csab1 = 0.1355 |
| double | cs_turb_csab2 = 0.622 |
| double | cs_turb_csasig = 2.0/3.0 |
| double | cs_turb_csav1 = 7.1 |
| double | cs_turb_csaw1 = -1. |
| double | cs_turb_csaw2 = 0.3 |
| double | cs_turb_csaw3 = 2.0 |
| double | cs_turb_cssr1 = 1.0 |
| double | cs_turb_cssr2 = 2.0 |
| double | cs_turb_cssr3 = 1.0 |
| double | cs_turb_ccaze2 = 1.83 |
| double | cs_turb_ccazsc = 0.119 |
| double | cs_turb_ccaza = 4.3 |
| double | cs_turb_ccazb = 5.130 |
| double | cs_turb_ccazc = 0.453 |
| double | cs_turb_ccazd = 0.682 |
| double | cs_turb_xlesfl = 2.0 |
| double | cs_turb_ales = 1.0 |
| double | cs_turb_bles = 1.0/3.0 |
| double | cs_turb_csmago = 0.065 |
| double | cs_turb_xlesfd = 1.5 |
| double | cs_turb_csmago_max = -1. |
| double | cs_turb_csmago_min = 0. |
| double | cs_turb_cdries = 26.0 |
| double | cs_turb_cv2fa1 = 0.05 |
| double | cs_turb_cv2fe2 = 1.85 |
| double | cs_turb_cv2fc1 = 1.4 |
| double | cs_turb_cv2fc2 = 0.3 |
| double | cs_turb_cv2fct = 6.0 |
| double | cs_turb_cv2fcl = 0.25 |
| double | cs_turb_cv2fet = 110.0 |
| double | cs_turb_cnl1 = 0.8 |
| double | cs_turb_cnl2 = 11. |
| double | cs_turb_cnl3 = 4.5 |
| double | cs_turb_cnl4 = 1e3 |
| double | cs_turb_cnl5 = 1. |
| double | cs_turb_cwale = 0.25 |
| double | cs_turb_xiafm = 0.7 |
| double | cs_turb_etaafm = 0.4 |
| double | cs_turb_c1trit = 4.15 |
| double | cs_turb_c2trit = 0.55 |
| double | cs_turb_c3trit = 0.5 |
| double | cs_turb_c4trit = 0. |
| double | cs_turb_cthafm = 0.236 |
| double | cs_turb_cthdfm = 0.31 |
Base turbulence model data.
| void cs_clip_turbulent_fluxes | ( | int | flux_id, |
| int | variance_id | ||
| [in] | flux_id | turbulent flux index |
| [in] | variance_id | scalar variance index |
| cs_turb_hybrid_model_t* cs_get_glob_turb_hybrid_model | ( | void | ) |
needed to initialize structure with GUI
| cs_turb_les_model_t* cs_get_glob_turb_les_model | ( | void | ) |
| cs_turb_model_t* cs_get_glob_turb_model | ( | void | ) |
| cs_turb_rans_model_t* cs_get_glob_turb_rans_model | ( | void | ) |
| cs_turb_ref_values_t* cs_get_glob_turb_ref_values | ( | void | ) |
| void cs_set_glob_turb_model | ( | void | ) |
This global pointer provides a read-only access to the structure.
| void cs_set_type_order_turbulence_model | ( | void | ) |
| void cs_turb_compute_constants | ( | void | ) |
| void cs_turb_constants_log_setup | ( | void | ) |
| void cs_turb_model_init | ( | void | ) |
| void cs_turb_model_log_setup | ( | void | ) |
| void cs_turbulence_function_eps | ( | int | location_id, |
| cs_lnum_t | n_elts, | ||
| void * | input, | ||
| void * | vals | ||
Returned values are zero for turbulence models other than RANS.
This function matches the cs_eval_at_location_t function profile.
| [in] | location_id | base associated mesh location id |
| [in] | n_elts | number of associated elements |
| [in] | elt_ids | ids of associated elements, or NULL if no filtering is required |
| [in,out] | input | ignored |
| [in,out] | vals | pointer to output values (size: n_elts*dimension) |
| void cs_turbulence_function_k | ( | int | location_id, |
| void * | vals | ||
| void cs_turbulence_function_rij | ( | int | location_id, |
| void * | vals | ||
| double cs_turb_ales = 1.0 |
Constant used to define, for each cell
, the width of the (implicit) filter:
Useful if and only if iturb = 40 or 41.
| double cs_turb_apow = 8.3 |
Werner and Wengle coefficient
| double cs_turb_bles = 1.0/3.0 |
| double cs_turb_bpow = 1.0/7.0 |
| double cs_turb_c1trit = 4.15 |
Coefficient of turbulent DFM flow model.
| double cs_turb_c2trit = 0.55 |
| double cs_turb_c3trit = 0.5 |
| double cs_turb_c4trit = 0. |
| double cs_turb_ccaza = 4.3 |
Constants of the Cazalbou rotation/curvature correction.
| double cs_turb_ccazb = 5.130 |
| double cs_turb_ccazc = 0.453 |
| double cs_turb_ccazd = 0.682 |
| double cs_turb_ccaze2 = 1.83 |
| double cs_turb_ccazsc = 0.119 |
| double cs_turb_cddes = 0.65 |
Constant
for the
SST model. Useful if and only if iturb=60 (
SST) and hybrid_turb=1.
| double cs_turb_cdries = 26.0 |
Van Driest constant appearing in the van Driest damping function applied to the Smagorinsky constant:
.Useful if and only if iturb = 40 or 41.
| double cs_turb_ce1 = 1.44 |
Constant
for all the RANS turbulence models except for the v2f and the
models. Useful if and only if iturb= 20, 21, 30 or 31 (
or
| double cs_turb_ce2 = 1.92 |
Constant
for the
and
LRR models. Useful if and only if iturb = 20, 21 or 30 (
or
LRR).
| double cs_turb_ce4 = 1.20 |
Coefficient of interfacial coefficient in k-eps, used in Lagrange treatment.
Constant
for the interfacial term (Lagrangian module) in case of two-way coupling. Useful in case of Lagrangian modelling, in
and
with two-way coupling.
| double cs_turb_cebme2 = 1.83 |
Constant of the Rij-epsilon EBRSM.
| double cs_turb_cebmmu = 0.22 |
| double cs_turb_cebmr1 = 0.90 |
| double cs_turb_cebmr2 = 0.80 |
| double cs_turb_cebmr3 = 0.65 |
| double cs_turb_cebmr4 = 0.625 |
| double cs_turb_cebmr5 = 0.20 |
| double cs_turb_cebms1 = 1.70 |
| double cs_turb_cebms2 = 0. |
| double cs_turb_chtles_bt0 = 0.48 |
| double cs_turb_ckwa1 = 0.31 |
Specific constant of k-omega SST. Constant
for the
SST).
| double cs_turb_ckwbt1 = 0.075 |
Constant
for the
SST).
| double cs_turb_ckwbt2 = 0.0828 |
Constant
for the
SST).
| double cs_turb_ckwc1 = 10.0 |
Constant
for the
SST). Specific constant of k-omega SST.
| double cs_turb_ckwgm1 = -1. |
. Constant
for the
SST).
is calculated before the call to usipsu. Hence, if
or
is modified in usipsu, cs_turb_ckwgm1 must also be modified in accordance. | double cs_turb_ckwgm2 = -1. |
. Constant
for the
SST).
or
is modified in usipsu, cs_turb_ckwgm2 must also be modified in accordance. | double cs_turb_ckwsk1 = 1.0/0.85 |
Constant
for the
SST model. Useful if and only if iturb=60.
| double cs_turb_ckwsk2 = 1.0 |
Constant
for the
| double cs_turb_ckwsw1 = 2.0 |
Constant
for the
SST).
| double cs_turb_ckwsw2 = 1.0/0.856 |
Constant
for the
SST).
| double cs_turb_cmu = 0.09 |
Constant
for all the RANS turbulence models except for the Warning: different value for v2f models. Useful if and only if iturb = 20, 21, 30, 31, 50, 51 or 60 (
or
| double cs_turb_cmu025 = 0.547722557 |
| double cs_turb_cnl1 = 0.8 |
Constants for the Baglietto et al. quadratic k-epsilon model. Useful if and only if iturb = CS_TURB_K_EPSILON_QUAD
| double cs_turb_cnl2 = 11. |
| double cs_turb_cnl3 = 4.5 |
| double cs_turb_cnl4 = 1e3 |
| double cs_turb_cnl5 = 1. |
| double cs_turb_cpalc1 = 1.7 |
Specific constant of v2f "BL-v2k" (or phi-alpha).
| double cs_turb_cpalc2 = 0.9 |
| double cs_turb_cpalcl = 0.164 |
| double cs_turb_cpalct = 4.0 |
| double cs_turb_cpale1 = 1.44 |
| double cs_turb_cpale2 = 1.83 |
| double cs_turb_cpale3 = 2.3 |
| double cs_turb_cpale4 = 0.4 |
| double cs_turb_cpalet = 75.0 |
| double cs_turb_crij1 = 1.80 |
Constant
for the
LRR model. Useful if and only if iturb=30 (
LRR).
| double cs_turb_crij2 = 0.60 |
| double cs_turb_crij3 = 0.55 |
Constant
for the
models. Value is 0.55 for SSG and LRR, 0.6 for EBRSM.
| double cs_turb_crijp1 = 0.50 |
Constant
for the
LRR model, corresponding to the wall echo terms. Useful if and only if iturb=30 and cs_turb_rans_model_t::irijec=1 (
LRR).
| double cs_turb_crijp2 = 0.30 |
Constant
for the
LRR).
| double cs_turb_csab1 = 0.1355 |
Specific constant of Spalart-Allmaras.
| double cs_turb_csab2 = 0.622 |
| double cs_turb_csas = 0.11 |
Constant
for the hybrid
SST) and hybrid_turb=3.
| double cs_turb_csas_eta2 = 3.51 |
constant
for the hybrid
| double cs_turb_csasig = 2.0/3.0 |
| double cs_turb_csav1 = 7.1 |
| double cs_turb_csaw1 = -1. |
| double cs_turb_csaw2 = 0.3 |
| double cs_turb_csaw3 = 2.0 |
| double cs_turb_csmago = 0.065 |
Smagorinsky constant used in the Smagorinsky model for LES. The sub-grid scale viscosity is calculated by
where
is the width of the filter and
the filtered strain rate.
Useful if and only if iturb = 40.
| double cs_turb_csmago_max = -1. |
Maximum allowed value for the variable
appearing in the LES dynamic model. Any larger value yielded by the calculation procedure of the dynamic model will be clipped to
Useful if and only if iturb = 41.
| double cs_turb_csmago_min = 0. |
Minimum allowed value for the variable
appearing in the LES dynamic model. Any smaller value yielded by the calculation procedure of the dynamic model will be clipped to
| double cs_turb_csrij |
Constant
for the
LRR).
| double cs_turb_cssge2 = 1.83 |
Constant
for the
SSG model. Useful if and only if iturb=31 (
SSG).
| double cs_turb_cssgr1 = 0.90 |
Constant
for the
SSG).
| double cs_turb_cssgr2 = 0.80 |
Constant
for the
SSG).
| double cs_turb_cssgr3 = 0.65 |
Constant
for the
SSG).
| double cs_turb_cssgr4 = 0.625 |
constant
for the
SSG).
| double cs_turb_cssgr5 = 0.20 |
Constant
for the
SSG).
| double cs_turb_cssgs1 = 1.70 |
Constant
for the
SSG).
| double cs_turb_cssgs2 = -1.05 |
Constant
for the
SSG).
| double cs_turb_cssr1 = 1.0 |
Constant of the Spalart-Shur rotation/curvature correction.
| double cs_turb_cssr2 = 2.0 |
| double cs_turb_cssr3 = 1.0 |
| double cs_turb_cstlog = 5.2 |
Constant of logarithmic smooth law function:
Constant of the logarithmic wall function. Useful if and only if iturb >= 10 (mixing length,
, LES, v2f or
| double cs_turb_cstlog_alpha |
Constant
for logarithmic law function switching from rough to smooth:
, LES, v2f or
| double cs_turb_cstlog_rough = 8.5 |
Constant of logarithmic rough law function:
, LES, v2f or
| double cs_turb_cthafm = 0.236 |
Constant of GGDH and AFM on the thermal scalar.
| double cs_turb_cthdfm = 0.31 |
| double cs_turb_cv2fa1 = 0.05 |
Constant
for the v2f
-model. Useful if and only if iturb=50 (v2f
-model).
| double cs_turb_cv2fc1 = 1.4 |
Constant
for the v2f
-model).
| double cs_turb_cv2fc2 = 0.3 |
Constant
for the v2f
-model).
| double cs_turb_cv2fcl = 0.25 |
Constant
for the v2f
-model).
| double cs_turb_cv2fct = 6.0 |
Constant
for the v2f
-model).
| double cs_turb_cv2fe2 = 1.85 |
Constant
for the v2f
-model).
| double cs_turb_cv2fet = 110.0 |
Constant
for the v2f
-model).
| double cs_turb_cwale = 0.25 |
Constant of the WALE LES method.
| double cs_turb_dpow = -1. |
| double cs_turb_etaafm = 0.4 |
Coefficient of turbulent AFM flow model.
| double cs_turb_vdriest = 25.6 |
Van Driest constant. (= 25.6)
Useful if and only if cs_glob_wall_functions::iwallf = CS_WALL_F_2SCALES_VDRIEST. (Two scales log law at the wall using Van Driest mixing length expression).
| double cs_turb_xa1 = 0.1 |
Constant in the expression of Ce1' for the Rij-epsilon EBRSM.
| double cs_turb_xceta = 80.0 |
| double cs_turb_xcl = 0.122 |
| double cs_turb_xct = 6.0 |
| double cs_turb_xiafm = 0.7 |
| double cs_turb_xkappa = 0.42 |
Karman constant. (= 0.42)
Useful if and only if iturb >= 10. (mixing length,
, LES, v2f or
| double cs_turb_xlesfd = 1.5 |
Ratio between explicit and explicit filter width for a dynamic model. Constant used to define, for each cell
, the width of the explicit filter used in the framework of the LES dynamic model:
| double cs_turb_xlesfl = 2.0 |
Constant used in the definition of LES filtering diameter:
cs_turb_xlesfl is a constant used to define, for each cell
