#include "cs_defs.h"#include <assert.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include <mpi.h>#include "bft_mem.h"#include "bft_error.h"#include "bft_printf.h"#include "cs_base.h"#include "fvm_nodal.h"#include "ple_locator.h"#include "cs_io.h"#include "cs_coupling.h"#include "cs_mesh.h"#include "cs_mesh_connect.h"#include "cs_mesh_location.h"#include "cs_mesh_quantities.h"#include "cs_parall.h"#include "cs_preprocessor_data.h"#include "cs_timer.h"#include "cs_timer_stats.h"#include "cs_restart.h"#include "cs_restart_map.h"
Include dependency graph for cs_restart_map.c:Functions | |
| void | cs_restart_map_set_mesh_input (const char *mesh_path) |
| Indicate restart files should be mapped to a given mesh input. More... | |
| void | cs_restart_map_set_options (float tolerance_base, float tolerance_fraction) |
| Set options relative to restart file mapping to a given mesh input. More... | |
| void | cs_restart_map_build (void) |
| Build mapping of restart files to different mesh if defined. More... | |
| void | cs_restart_map_free (void) |
| Free restart file mapping to different mesh. More... | |
| void cs_restart_map_build | ( | void | ) |
| void cs_restart_map_free | ( | void | ) |
Revert restart reading to default behavior.
| void cs_restart_map_set_mesh_input | ( | const char * | mesh_path | ) |
| [in] | mesh_path | path to mesh input |
| void cs_restart_map_set_options | ( | float | tolerance_base, |
| float | tolerance_fraction | ||
| [in] | tolerance_base | associated base tolerance (used for bounding box check only, not for location test) |
| [in] | tolerance_fraction | associated fraction of element bounding boxes added to tolerance |
