7.2
cs_coupling.h
1 #ifndef __CS_COUPLING_H__
2 #define __CS_COUPLING_H__
5  * Common functionnality for various coupling types.
35  * PLE library headers
38 #include <ple_coupling.h>
40 /*----------------------------------------------------------------------------
41  * Local headers
42  *----------------------------------------------------------------------------*/
44 #include "cs_base.h"
45
46 /*----------------------------------------------------------------------------*/
49
50 /*=============================================================================
51  * Macro definitions
53
55  * Type definitions
57
58 /*=============================================================================
59  * Global variable definitions
61
62 /*============================================================================
63  * Public function prototypes for Fortran API
64  *============================================================================*/
65
66 /*----------------------------------------------------------------------------
67  * Synchronize with applications in the same PLE coupling group.
68  *
69  * This function should be called before starting a new time step. The
70  * current time step id is that of the last finished time step, or 0 at
71  * initialization.
72  *
73  * Fortran Interface:
74  *
75  * subroutine cplsyn (ntcmabs, ntcabs, dtref)
76  * *****************
77  *
78  * integer ntmabs : <-> : maximum iteration number
79  * integer ntcabs : <-- : current iteration number
80  * double precision dtref : <-> : reference time step value
81  *----------------------------------------------------------------------------*/
82
83 void CS_PROCF(cplsyn, CPLSYN)
84 (
85  int *ntmabs,
86  const int *ntcabs,
88  );
89
90 /*----------------------------------------------------------------------------
91  * Indicate if there are synchronized applications in the same
92  * PLE coupling group.
93  *
94  * Fortran Interface:
95  *
96  * subroutine cplact (isync)
97  * *****************
98  *
99  * integer isync : <-- : 1 if synchronized, 0 otherwise
100  *----------------------------------------------------------------------------*/
101
102 void CS_PROCF(cplact, CPLACT)
103 (
104  int *isync
105 );
106
107 /*============================================================================
108  * Public function prototypes
109  *============================================================================*/
110
111 #if defined(HAVE_MPI)
112
113 /*----------------------------------------------------------------------------
114  * Discover other applications in the same MPI root communicator.
115  *
116  * parameters:
117  * app_name <-- name of this instance of code_saturne.
118  * forced_app_type <-- name of app type, or NULL
119  *----------------------------------------------------------------------------*/
120
121 void
122 cs_coupling_discover_mpi_apps(const char *app_name,
123  const char *forced_app_type);
124
125 /*----------------------------------------------------------------------------
126  * Finalize MPI coupling helper structures.
127  *----------------------------------------------------------------------------*/
128
129 void
131
132 /*----------------------------------------------------------------------------
133  * Return info on other applications in the same MPI root communicator.
134  *
135  * returns:
136  * info on other applications structure.
137  *----------------------------------------------------------------------------*/
138
139 const ple_coupling_mpi_set_t *
141
142 #endif /* HAVE_MPI */
143
144 /*----------------------------------------------------------------------------
145  * Return the optional synchronization flag for external couplings.
146  *
147  * See cs_coupling_set_sync_flag() for details.
148  *
149  * returns:
150  * synchronization flag to apply to couplings
151  *----------------------------------------------------------------------------*/
152
153 int
155
156 /*----------------------------------------------------------------------------
157  * Define an optional synchronization flag for external couplings.
158  *
159  * This flag is used by all couplings based on the PLE (Parallel Location
160  * and Exchange) group synchronization mechanism, which include couplings
161  * with SYRTHES, code_saturne, and neptune_cfd.
162  *
163  * It is defined by a mask, so for example flags f1, f2, and f3 may be
164  * combined using the "f1 | f2 | f2" syntax.
165  *
166  * Note also that for code_saturne, in the case of a variable time step,
167  * the reference time step is synchronized at the beginning of each
168  * iteration, but the actual time step is recomputed later.
169  *
170  * Possible flags are:
171  * PLE_COUPLING_TS_MIN Use smallest time step
172  * PLE_COUPLING_TS_LEADER Prescribe time step for the group
173  * (only one member may set this flag)
174  * PLE_COUPLING_UNSTEADY Inform others that this instance is
175  * using an unsteady solution approach
176  * PLE_COUPLING_STEADY Inform others that this instance is
177  * using a steady solution approach
178  * PLE_COUPLING_USER_1 User definable flag
179  * PLE_COUPLING_USER_2 User definable flag
180  * PLE_COUPLING_USER_3 User definable flag
181  * PLE_COUPLING_USER_4 User definable flag
182  *
183  * To force stopping, PLE_COUPLING_STOP may be set. In this case,
184  * the calculation will stop at the first synchronization, even if
185  * this function is called again with another flag.
186  *
187  * parameters:
188  * flag <-- synchronization flag to apply to couplings
189  *----------------------------------------------------------------------------*/
190
191 void
192 cs_coupling_set_sync_flag(int flag);
193
194 /*----------------------------------------------------------------------------
195  * Return the time step multiplier for external couplings.
196  *
197  * See cs_coupling_set_ts_multiplier() for details.
198  *
199  * returns:
200  * time step multiplier for external couplings
201  *----------------------------------------------------------------------------*/
202
203 double
205
206 /*----------------------------------------------------------------------------
207  * Define a time step multiplier for external couplings.
208  *
209  * The apparent time step for the current instance times (as viewed by
210  * coupled codes) is equal to the true time step times this multiplier.
211  *
212  * If the synchronization flag contains "time step min" (PLE_COUPLING_TS_MIN),
213  * the apparent time step is used to determine which code has the smallest
214  * time step.
215  *
216  * parameters:
217  * m <-- time step multipier to aply to couplings
218  *----------------------------------------------------------------------------*/
219
220 void
222
223 /*----------------------------------------------------------------------------
224  * Synchronize with applications in the same PLE coupling group.
225  *
226  * This function should be called before starting a new time step. The
227  * current time step id is that of the last finished time step, or 0 at
228  * initialization.
229  *
230  * Default synchronization flags indicating a new iteration or end of
231  * calculation are set automatically, but the user may set additional flags
232  * to this function if necessary.
233  *
234  * parameters:
235  * flags <-- optional additional synchronization flags
236  * current_ts_id <-- current time step id
237  * max_ts_id <-> maximum time step id
238  * ts <-> suggested time step value
239  *----------------------------------------------------------------------------*/
240
241 void
242 cs_coupling_sync_apps(int flags,
243  int current_ts_id,
244  int *max_ts_id,
245  double *ts);
246
247 /*----------------------------------------------------------------------------
248  * Indicate is synchronization with applications in the same
249  * PLE group is active.
250  *
251  * return:
252  * true if synchronization is required, false otherwise
253  *----------------------------------------------------------------------------*/
254
255 bool
257
258 /*----------------------------------------------------------------------------
259  * Compute extents of a mesh representation
260  *
261  * parameters:
262  * mesh <-- pointer to mesh representation structure
263  * n_max_extents <-- maximum number of sub-extents (such as element extents)
264  * to compute, or -1 to query
265  * tolerance <-- addition to local extents of each element:
266  * extent = base_extent * (1 + tolerance)
267  * extents <-> extents associated with mesh:
268  * x_min, y_min, ..., x_max, y_max, ... (size: 2*dim)
269  *
270  * returns:
271  * the number of extents computed
272  *----------------------------------------------------------------------------*/
273
275 cs_coupling_mesh_extents(const void *mesh,
276  ple_lnum_t n_max_extents,
277  double tolerance,
278  double extents[]);
279
280 /*----------------------------------------------------------------------------
281  * Find elements in a given mesh containing points: updates the
282  * location[] and distance[] arrays associated with a set of points
283  * for points that are in an element of this mesh, or closer to one
284  * than to previously encountered elements.
285  *
286  * Location is relative to the id of a given element + 1 in
287  * concatenated sections of same element dimension.
288  *
289  * parameters:
290  * mesh <-- pointer to mesh representation structure
291  * tolerance_base <-- associated base tolerance (used for bounding
292  * box check only, not for location test)
293  * tolerance_fraction <-- associated fraction of element bounding boxes
294  * added to tolerance
295  * n_points <-- number of points to locate
296  * point_coords <-- point coordinates
297  * point_tag <-- optional point tag (size: n_points)
298  * location <-> number of element containing or closest to each
299  * point (size: n_points)
300  * distance <-> distance from point to element indicated by
301  * location[]: < 0 if unlocated, 0 - 1 if inside,
302  * and > 1 if outside a volume element, or absolute
303  * distance to a surface element (size: n_points)
304  *----------------------------------------------------------------------------*/
305
306 void
307 cs_coupling_point_in_mesh(const void *mesh,
308  float tolerance_base,
309  float tolerance_fraction,
310  ple_lnum_t n_points,
311  const ple_coord_t point_coords[],
312  const int point_tag[],
313  ple_lnum_t location[],
314  float distance[]);
315
316 /*----------------------------------------------------------------------------
317  * Find elements in a given mesh containing points: updates the
318  * location[] and distance[] arrays associated with a set of points
319  * for points that are in an element of this mesh, or closer to one
320  * than to previously encountered elements.
321  *
322  * Location is relative to parent element numbers.
323  *
324  * parameters:
325  * mesh <-- pointer to mesh representation structure
326  * tolerance_base <-- associated base tolerance (used for bounding
327  * box check only, not for location test)
328  * tolerance_fraction <-- associated fraction of element bounding boxes
329  * added to tolerance
330  * n_points <-- number of points to locate
331  * point_coords <-- point coordinates
332  * point_tag <-- optional point tag (size: n_points)
333  * location <-> number of element containing or closest to each
334  * point (size: n_points)
335  * distance <-> distance from point to element indicated by
336  * location[]: < 0 if unlocated, 0 - 1 if inside,
337  * and > 1 if outside a volume element, or absolute
338  * distance to a surface element (size: n_points)
339  *----------------------------------------------------------------------------*/
340
341 void
343  float tolerance_base,
344  float tolerance_fraction,
345  ple_lnum_t n_points,
346  const ple_coord_t point_coords[],
347  const int point_tag[],
348  ple_lnum_t location[],
349  float distance[]);
350
351 /*----------------------------------------------------------------------------*/
352
354
355 #endif /* __CS_COUPLING_H__ */
int cs_coupling_get_sync_flag(void)
Definition: cs_coupling.c:307
real(c_double), pointer, save dtref
Reference time step.
Definition: optcal.f90:396
integer(c_int), pointer, save ntmabs
Maximum absolute time step number.
Definition: optcal.f90:328
ple_lnum_t cs_coupling_mesh_extents(const void *mesh, ple_lnum_t n_max_extents, double tolerance, double extents[])
Compute extents of a mesh representation.
Definition: cs_coupling.c:642
void cplsyn(int *ntmabs, const int *ntcabs, cs_real_t *dtref)
Definition: cs_coupling.c:122
void cs_coupling_sync_apps(int flags, int current_ts_id, int *max_ts_id, double *ts)
Definition: cs_coupling.c:413
Definition: cs_defs.h:322
void cs_coupling_set_sync_flag(int flag)
Definition: cs_coupling.c:349
int ple_lnum_t
const ple_coupling_mpi_set_t * cs_coupling_get_mpi_apps(void)
Definition: cs_coupling.c:289
double ple_coord_t
void cs_coupling_point_in_mesh(const void *mesh, float tolerance_base, float tolerance_fraction, ple_lnum_t n_points, const ple_coord_t point_coords[], const int point_tag[], ple_lnum_t location[], float distance[])
Find elements in a given mesh containing points: updates the location[] and distance[] arrays associa...
Definition: cs_coupling.c:698
void cplact(int *isync)
Definition: cs_coupling.c:154
bool cs_coupling_is_sync_active(void)
Indicate is synchronization with applications in the same PLE group is active.
Definition: cs_coupling.c:579
void cs_coupling_point_in_mesh_p(const void *mesh, float tolerance_base, float tolerance_fraction, ple_lnum_t n_points, const ple_coord_t point_coords[], const int point_tag[], ple_lnum_t location[], float distance[])
Definition: cs_coupling.c:746
void cs_coupling_set_ts_multiplier(double m)
Definition: cs_coupling.c:388
integer(c_int), pointer, save ntcabs
Current absolute time step number. In case of restart, this is equal to ntpabs + number of new iterat...
Definition: optcal.f90:319
#define CS_PROCF(x, y)
Definition: cs_defs.h:524
double cs_coupling_get_ts_multiplier(void)
Definition: cs_coupling.c:367
void cs_coupling_discover_mpi_apps(const char *app_name, const char *forced_app_type)
Definition: cs_coupling.c:180
void cs_coupling_finalize(void)
Definition: cs_coupling.c:274
Definition: mesh.f90:26
