7.2
cs_timer_stats.h
1 #ifndef __CS_TIMER_STATS_H__
2 #define __CS_TIMER_STATS_H__
5  * Application timer statistics and graphs
31  * Local headers
34 #include "cs_defs.h"
35 #include "cs_timer.h"
36 #include "cs_time_plot.h"
43  * Public types
45
47  * Public function prototypes
49
50 /*----------------------------------------------------------------------------*/
58 /*----------------------------------------------------------------------------*/
59
60 void
62
63 /*----------------------------------------------------------------------------*/
67 /*----------------------------------------------------------------------------*/
68
69 void
71
81 /*----------------------------------------------------------------------------*/
82
83 void
85
86 /*----------------------------------------------------------------------------*/
100 /*----------------------------------------------------------------------------*/
101
102 void
104  int frequency,
105  int n_buffer_steps,
106  double flush_wtime);
107
108 /*----------------------------------------------------------------------------*/
113
114 void
116
117 /*----------------------------------------------------------------------------*/
128
129 int
130 cs_timer_stats_create(const char *parent_name,
131  const char *name,
132  const char *label);
133
144 /*----------------------------------------------------------------------------*/
145
146 int
147 cs_timer_stats_id_by_name(const char *name);
148
149 /*----------------------------------------------------------------------------*/
162 /*----------------------------------------------------------------------------*/
163
164 void
166  int plot);
167
168 /*----------------------------------------------------------------------------*/
176 /*----------------------------------------------------------------------------*/
177
178 int
180
181 /*----------------------------------------------------------------------------*/
193 /*----------------------------------------------------------------------------*/
194
195 void
196 cs_timer_stats_start(int id);
197
198 /*----------------------------------------------------------------------------*/
206 /*----------------------------------------------------------------------------*/
207
208 void
209 cs_timer_stats_stop(int id);
210
211 /*----------------------------------------------------------------------------*/
221 /*----------------------------------------------------------------------------*/
222
223 int
224 cs_timer_stats_switch(int id);
225
226 /*----------------------------------------------------------------------------*/
237 /*----------------------------------------------------------------------------*/
238
239 void
241  const cs_timer_t *t0,
242  const cs_timer_t *t1);
243
244 /*----------------------------------------------------------------------------*/
253
254 void
256
257 /*----------------------------------------------------------------------------*/
258
260
261 #endif /* __CS_TIMER_STATS_H__ */
int cs_timer_stats_create(const char *parent_name, const char *name, const char *label)
Create a timer statistics structure.
Definition: cs_timer_stats.c:456
void cs_timer_stats_add_diff(int id, const cs_timer_t *t0, const cs_timer_t *t1)
Add a timing range to an inactive timer.
Definition: cs_timer_stats.c:774
int cs_timer_stats_is_active(int id)
indicate if a timer for a given statistic is currently active.
Definition: cs_timer_stats.c:598
Definition: cs_timer.h:46
void cs_timer_stats_start(int id)
Start a timer for a given statistic.
Definition: cs_timer_stats.c:624
void cs_timer_stats_stop(int id)
Stop a timer for a given statistic.
Definition: cs_timer_stats.c:669
void cs_timer_stats_set_start_time(int time_id)
Set a start time for time stats.
Definition: cs_timer_stats.c:362
void cs_timer_stats_increment_time_step(void)
Increment time step for timer statistics.
Definition: cs_timer_stats.c:406
real(c_double), pointer, save t0
reference temperature.
Definition: cstphy.f90:215
cs_time_plot_format_t
Definition: cs_time_plot.h:56
void cs_timer_stats_finalize(void)
Finalize timer statistics handling.
Definition: cs_timer_stats.c:325
void cs_timer_stats_set_plot(int id, int plot)
Enable or disable plotting for a timer statistic.
Definition: cs_timer_stats.c:578
void cs_timer_stats_initialize(void)
Initialize timer statistics handling.
Definition: cs_timer_stats.c:297
int cs_timer_stats_switch(int id)
Start a timer for a given statistic, stopping previous timers of the same type which are not a parent...
Definition: cs_timer_stats.c:707
char * label
Definition: keywords.h:71
void cs_timer_stats_define_defaults(void)
Define default timer statistics.
Definition: cs_timer_stats.c:797
void cs_timer_stats_set_plot_options(cs_time_plot_format_t format, int frequency, int n_buffer_steps, double flush_wtime)
Set global timer statistics plot options.
Definition: cs_timer_stats.c:387
int cs_timer_stats_id_by_name(const char *name)
Return the id of a defined statistic based on its name.
Definition: cs_timer_stats.c:557
