Main functions dedicated to soil management in groundwater flows when using CDO schemes. More...
#include <assert.h>#include <ctype.h>#include <float.h>#include <math.h>#include <stdlib.h>#include <string.h>#include <bft_mem.h>#include <bft_printf.h>#include "cs_field.h"#include "cs_gwf_priv.h"#include "cs_hodge.h"#include "cs_log.h"#include "cs_math.h"#include "cs_mesh_location.h"#include "cs_parall.h"#include "cs_param_types.h"#include "cs_physical_constants.h"#include "cs_post.h"#include "cs_prototypes.h"#include "cs_reco.h"#include "cs_volume_zone.h"#include "cs_gwf_soil.h"
Include dependency graph for cs_gwf_soil.c:Macros | |
| #define | CS_GWF_SOIL_DBG 0 |
| int | cs_gwf_get_n_soils (void) |
| Get the number of allocated soils. More... | |
| cs_gwf_soil_t * | cs_gwf_soil_by_id (int id) |
| Retrieve a soil structure from its id. More... | |
| cs_gwf_soil_t * | cs_gwf_soil_by_name (const char *name) |
| Retrieve a soil structure from its name. More... | |
| cs_real_t | cs_gwf_soil_get_saturated_moisture (int soil_id) |
| Get the saturated moisture for the given soil id. More... | |
| int | cs_gwf_soil_get_permeability_max_dim (void) |
| Retrieve the max dim (aniso=9; iso=1) for the absolute permeability associated to each soil. More... | |
| bool | cs_gwf_soil_all_are_saturated (void) |
| Check if all soils have been set as CS_GWF_SOIL_SATURATED. More... | |
| void | cs_gwf_soil_check (void) |
| Check that at least one soil has been defined and the model of soil exists. Raise an error if a problem is encoutered. More... | |
| cs_gwf_soil_t * | cs_gwf_soil_create (const cs_zone_t *zone, cs_gwf_model_type_t hydraulic_model, cs_gwf_soil_model_t model, cs_property_type_t perm_type, double k_abs[3][3], double porosity, double bulk_density, void *hydraulic_context) |
| Create a new cs_gwf_soil_t structure and add it to the array of soils. An initialization by default of all members is performed. More... | |
| void | cs_gwf_build_cell2soil (cs_lnum_t n_cells) |
| Build an array storing the associated soil for each cell. More... | |
| const short int * | cs_gwf_get_cell2soil (void) |
| Get the array storing the associated soil for each cell. More... | |
| void | cs_gwf_soil_free_all (void) |
| Free all cs_gwf_soil_t structures. More... | |
| void | cs_gwf_soil_log_setup (void) |
| Summary of the settings related to all cs_gwf_soil_t structures. More... | |
| void | cs_gwf_soil_set_genuchten_param (cs_gwf_soil_t *soil, double theta_r, double alpha, double n, double L) |
| Set a soil defined by a Van Genuchten-Mualen model. More... | |
| void | cs_gwf_soil_set_user (cs_gwf_soil_t *soil, void *param, cs_gwf_soil_update_t *update_func, cs_gwf_soil_free_param_t *free_param_func) |
| Set a soil defined by a user-defined model. More... | |
| void | cs_gwf_soil_set_shared_properties (cs_property_t *abs_permeability, cs_property_t *soil_porosity) |
| Set the definition of the soil porosity and absolute porosity (which are properties always defined). This relies on the definition of each soil. More... | |
| void | cs_gwf_soil_saturated_set_property (cs_property_t *moisture_content) |
| void | cs_gwf_soil_tpf_set_property (cs_gwf_two_phase_t *mc) |
| Set the definition of some property(ies) in specific situations for the two-phase flow models This relies on the definition of each soil. More... | |
| void | cs_gwf_soil_update (cs_real_t time_eval, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant) |
| Update the soil properties. More... | |
| void | cs_gwf_soil_iso_update_mtpf_terms (cs_gwf_two_phase_t *mc) |
| Update arrays associated to the definition of terms involved in the miscible two-phase flow model. Case of an isotropic absolute permeability. More... | |
| void | cs_gwf_soil_iso_update_itpf_terms (cs_gwf_two_phase_t *mc) |
| Update arrays associated to the definition of terms involved in the immiscible two-phase flow model. Case of an isotropic absolute permeability. More... | |
| void | cs_gwf_soil_iso_update_itpf_terms_incr (const cs_time_step_t *ts, cs_gwf_two_phase_t *mc) |
| Update arrays associated to the definition of terms involved in the immiscible two-phase flow model. Case of an isotropic absolute permeability and an incremental solve. More... | |
| void | cs_gwf_soil_iso_update_itpf_terms_incr_submesh (const cs_time_step_t *ts, const cs_cdo_connect_t *connect, cs_gwf_two_phase_t *mc) |
| Update arrays associated to the definition of terms involved in the immiscible two-phase flow model. Case of an isotropic absolute permeability with an incremental solve and a liquid saturation defined on a submesh. More... | |
| #define CS_GWF_SOIL_DBG 0 |
| void cs_gwf_build_cell2soil | ( | cs_lnum_t | n_cells | ) |
| const short int* cs_gwf_get_cell2soil | ( | void | ) |
| int cs_gwf_get_n_soils | ( | void | ) |
| bool cs_gwf_soil_all_are_saturated | ( | void | ) |
| cs_gwf_soil_t* cs_gwf_soil_by_id | ( | int | id | ) |
| [in] | id | id to look for |
| cs_gwf_soil_t* cs_gwf_soil_by_name | ( | const char * | name | ) |
| [in] | name | name to look for |
| void cs_gwf_soil_check | ( | void | ) |
| cs_gwf_soil_t* cs_gwf_soil_create | ( | const cs_zone_t * | zone, |
| cs_gwf_model_type_t | hydraulic_model, | ||
| cs_gwf_soil_model_t | model, | ||
| cs_property_type_t | perm_type, | ||
| double | k_abs[3][3], | ||
| double | porosity, | ||
| double | bulk_density, | ||
| void * | hydraulic_context | ||
| [in] | zone | pointer to a volume zone structure |
| [in] | hydraulic_model | main hydraulic model for the module |
| [in] | model | type of model for the soil behavior |
| [in] | perm_type | type of permeability (iso/anisotropic) |
| [in] | k_abs | absolute (intrisic) permeability |
| [in] | porosity | porosity or max. moisture content |
| [in] | bulk_density | value of the mass density |
| [in] | hydraulic_context | pointer to the context structure |
| void cs_gwf_soil_free_all | ( | void | ) |
| int cs_gwf_soil_get_permeability_max_dim | ( | void | ) |
| cs_real_t cs_gwf_soil_get_saturated_moisture | ( | int | soil_id | ) |
| [in] | soil_id | id of the requested soil |
| void cs_gwf_soil_iso_update_itpf_terms | ( | cs_gwf_two_phase_t * | mc | ) |
| [in,out] | mc | pointer to the model context to update |
| void cs_gwf_soil_iso_update_itpf_terms_incr | ( | const cs_time_step_t * | ts, |
| cs_gwf_two_phase_t * | mc | ||
| void cs_gwf_soil_iso_update_itpf_terms_incr_submesh | ( | const cs_time_step_t * | ts, |
| void cs_gwf_soil_iso_update_mtpf_terms | ( | cs_gwf_two_phase_t * | mc | ) |
| void cs_gwf_soil_log_setup | ( | void | ) |
| void cs_gwf_soil_saturated_set_property | ( | cs_property_t * | moisture_content | ) |
| [in,out] | moisture_content | pointer to a cs_property_t structure |
| void cs_gwf_soil_set_genuchten_param | ( | cs_gwf_soil_t * | soil, |
| double | theta_r, | ||
| double | alpha, | ||
| double | n, | ||
| double | L | ||
The (effective) liquid saturation (also called moisture content) follows the identity S_l,eff = (S_l - theta_r)/(theta_s - theta_r) = (1 + |alpha . h|^n)^(-m)
The isotropic relative permeability is defined as: k_r = S_l,eff^L * (1 - (1 - S_l,eff^(1/m))^m))^2 where m = 1 - 1/n
| [in,out] | soil | pointer to a cs_gwf_soil_t structure |
| [in] | theta_r | residual moisture |
| [in] | alpha | scale parameter (in m^-1) |
| [in] | n | shape parameter |
| [in] | L | turtuosity parameter |
| void cs_gwf_soil_set_shared_properties | ( | cs_property_t * | abs_permeability, |
| cs_property_t * | soil_porosity | ||
| [in,out] | abs_permeability | pointer to a cs_property_t structure |
| [in,out] | soil_porosity | pointer to a cs_property_t structure |
| void cs_gwf_soil_set_user | ( | cs_gwf_soil_t * | soil, |
| void * | param, | ||
| cs_gwf_soil_update_t * | update_func, | ||
| cs_gwf_soil_free_param_t * | free_param_func | ||
Set a soil defined by a user-defined hydraulic model.
| [in] | param | pointer to a structure cast on-the-fly |
| [in] | update_func | function pointer to update propoerties |
| [in] | free_param_func | function pointer to free the param struct. |
| void cs_gwf_soil_tpf_set_property | ( | cs_gwf_two_phase_t * | mc | ) |
| [in,out] | mc | pointer to the model context structure |
| void cs_gwf_soil_update | ( | cs_real_t | time_eval, |
| [in] | time_eval | time at which one evaluates properties |
| [in] | connect | pointer to the cdo connectivity |
| [in] | quant | pointer to the cdo quantities |
