7.2
cs_gwf_priv.h
1 #ifndef __CS_GWF_PRIV_H__
2 #define __CS_GWF_PRIV_H__
5  * Structures/types related to the groundwater flow module
29  * Local headers
32 #include "cs_advection_field.h"
33 #include "cs_equation_system.h"
34 #include "cs_gwf_param.h"
41  * Macro definitions
45  * Type definitions
53 typedef struct {
54
77
79
80
90 typedef struct {
91
104
117
130
146
152
161 typedef struct {
162
174
187
209
249
251
257
295 typedef struct {
296
297  /* Set of equations associated to this modelling */
298
311
319
326
334
341
358
400
402
406
409
437
549
551
556
559
562
563  /* These arrays are not always allocated. It depends on the numerical
564  settings */
565
571
618
658
662
664
670
671
679 typedef struct {
680
700
721
733
738 } cs_gwf_t;
739
740 /*============================================================================
741  * Public function prototypes
742  *============================================================================*/
743
744 /*----------------------------------------------------------------------------*/
752 /*----------------------------------------------------------------------------*/
753
756
757 /*----------------------------------------------------------------------------*/
763 /*----------------------------------------------------------------------------*/
764
765 void
767
768 /*----------------------------------------------------------------------------*/
774 /*----------------------------------------------------------------------------*/
775
776 void
778
779 /*----------------------------------------------------------------------------*/
789 /*----------------------------------------------------------------------------*/
790
791 void
793  const cs_cdo_quantities_t *quant,
794  cs_param_space_scheme_t space_scheme,
795  cs_gwf_darcy_flux_t *darcy);
796
797 /*----------------------------------------------------------------------------*/
806 /*----------------------------------------------------------------------------*/
807
808 void
810  const cs_equation_t *eq,
811  bool cur2prev,
812  cs_gwf_darcy_flux_t *darcy);
813
814 /*----------------------------------------------------------------------------*/
825 /*----------------------------------------------------------------------------*/
826
827 void
829  const cs_cdo_quantities_t *quant,
830  const cs_equation_param_t *eqp,
831  cs_gwf_darcy_flux_t *darcy);
832
833 /*----------------------------------------------------------------------------*/
834
836
837 #endif /* __CS_GWF_PRIV_H__ */
cs_real_t * l_saturation_submesh
Definition: cs_gwf_priv.h:569
cs_property_t * moisture_content
Definition: cs_gwf_priv.h:129
bool use_properties_on_submesh
Consider a submesh to define the liquid saturation.
Definition: cs_gwf_priv.h:657
void cs_gwf_darcy_flux_free(cs_gwf_darcy_flux_t **p_darcy)
Free a cs_gwf_darcy_flux_t structure.
Definition: cs_gwf_priv.c:161
cs_iter_algo_param_t nl_algo_param
Definition: cs_gwf_priv.h:660
cs_real_t * l_rel_permeability
Definition: cs_gwf_priv.h:560
Definition: cs_advection_field.h:150
cs_gwf_model_type_t model
Definition: cs_gwf_priv.h:697
cs_real_t * g_rel_permeability
Definition: cs_gwf_priv.h:561
cs_property_t * diff_wl_pty
Definition: cs_gwf_priv.h:399
Definition: cs_field.h:125
cs_param_nl_algo_t nl_algo_type
Definition: cs_gwf_priv.h:659
cs_property_t * diff_hg_pty
Definition: cs_gwf_priv.h:404
void * model_context
Definition: cs_gwf_priv.h:732
Structure storing all the parameters to drive the algorithm called Anderson acceleration.
Definition: cs_iter_algo.h:177
void cs_gwf_darcy_flux_balance(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_equation_param_t *eqp, cs_gwf_darcy_flux_t *darcy)
Operate the balance by zone (relying on the splitting arising from the boundary settings) for the adv...
Definition: cs_gwf_priv.c:430
bool use_coupled_solver
When a model relies on several coupled equations, there are two main options to build and solve the s...
Definition: cs_gwf_priv.h:655
cs_property_t * reac_hg_pty
Definition: cs_gwf_priv.h:405
cs_gwf_darcy_flux_t * g_darcy
Definition: cs_gwf_priv.h:357
cs_property_t * soil_capacity
Definition: cs_gwf_priv.h:208
cs_param_nl_algo_t
Class of non-linear iterative algorithm.
Definition: cs_param_types.h:546
Structure to handle the modelling of miscible or immiscible two-phase flows in a porous media...
Definition: cs_gwf_priv.h:295
cs_property_t * time_wg_pty
Definition: cs_gwf_priv.h:401
cs_field_t * c_pressure
Definition: cs_gwf_priv.h:434
cs_real_t * diff_hg_array
Definition: cs_gwf_priv.h:553
cs_gwf_darcy_flux_t * cs_gwf_darcy_flux_create(cs_flag_t loc_flag)
Allocate and initialize a cs_gwf_darcy_flux_t structure.
Definition: cs_gwf_priv.c:138
cs_flag_t flux_location
Definition: cs_gwf_priv.h:74
cs_real_t * time_wg_array
Definition: cs_gwf_priv.h:550
cs_real_t g_viscosity
Definition: cs_gwf_priv.h:612
cs_real_t * time_wl_array
Definition: cs_gwf_priv.h:546
cs_gwf_darcy_flux_t * l_darcy
Definition: cs_gwf_priv.h:356
cs_real_t w_molar_mass
Definition: cs_gwf_priv.h:614
cs_real_t * srct_wl_array
Definition: cs_gwf_priv.h:548
cs_iter_algo_t * nl_algo
Definition: cs_gwf_priv.h:663
cs_gwf_model_type_t
Definition: cs_gwf_param.h:102
cs_real_t * g_cell_pressure
Definition: cs_gwf_priv.h:568
Definition: cs_defs.h:322
Definition: cs_cdo_quantities.h:132
void cs_gwf_darcy_flux_log(cs_gwf_darcy_flux_t *darcy)
Log a cs_gwf_darcy_flux_t structure.
Definition: cs_gwf_priv.c:192
cs_property_t * time_hg_pty
Definition: cs_gwf_priv.h:403
cs_equation_t * richards
Definition: cs_gwf_priv.h:173
cs_real_t henry_constant
Definition: cs_gwf_priv.h:617
cs_real_t l_diffusivity_h
Definition: cs_gwf_priv.h:613
void cs_gwf_darcy_flux_update(const cs_real_t t_eval, const cs_equation_t *eq, bool cur2prev, cs_gwf_darcy_flux_t *darcy)
Update the advection field/arrays related to the Darcy flux.
Definition: cs_gwf_priv.c:327
Definition: cs_gwf_priv.h:207
Set of common parameters to manage an iterative algorithm.
Definition: cs_iter_algo.h:101
cs_flag_t post_flag
Definition: cs_gwf_priv.h:699
Definition: cs_gwf_priv.h:103
Structure to handle the Darcy flux.
Definition: cs_gwf_priv.h:53
cs_field_t * l_saturation
Definition: cs_gwf_priv.h:433
cs_real_t * l_capacity
Definition: cs_gwf_priv.h:566
Definition: cs_param_types.h:207
cs_property_t * time_wl_pty
Definition: cs_gwf_priv.h:398
cs_real_t * diff_wl_array
Definition: cs_gwf_priv.h:547
cs_real_t * srct_hg_array
Definition: cs_gwf_priv.h:555
cs_real_t l_viscosity
Definition: cs_gwf_priv.h:611
cs_equation_system_t * system
Definition: cs_gwf_priv.h:340
Main set of parameters/structures to manage the groundwater flow (GWF) module. This is an explicit de...
Definition: cs_gwf_priv.h:679
cs_equation_t * wl_eq
Definition: cs_gwf_priv.h:310
cs_field_t * capacity_field
Definition: cs_gwf_priv.h:247
cs_equation_t * hg_eq
Definition: cs_gwf_priv.h:318
Structure to handle the modelling of a single-phase flows in a porous media considered as saturated...
Definition: cs_gwf_priv.h:90
cs_real_t l_mass_density
Definition: cs_gwf_priv.h:610
void cs_gwf_darcy_flux_define(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_param_space_scheme_t space_scheme, cs_gwf_darcy_flux_t *darcy)
Set the definition of the advection field attached to a cs_gwf_darcy_flux_t structure.
Definition: cs_gwf_priv.c:217
Structure to handle the modelling of a single-phase flows in a porous media considered as saturated o...
Definition: cs_gwf_priv.h:161
Main structure to handle a set of coupled equations.
Definition: cs_equation_system.h:123
cs_property_t * time_hl_pty
Definition: cs_gwf_priv.h:407
cs_field_t * pressure_head
Definition: cs_gwf_priv.h:145
cs_adv_field_t * adv_field
bool use_incremental_solver
When a model includes non-linearities it can be useful to formulate the problem using increment and t...
Definition: cs_gwf_priv.h:656
cs_property_t * abs_permeability
Definition: cs_gwf_priv.h:720
cs_equation_param_t * wg_eqp
Definition: cs_gwf_priv.h:325
cs_real_t * head_in_law
Definition: cs_gwf_priv.h:250
cs_real_t * time_hg_array
Definition: cs_gwf_priv.h:552
unsigned short int cs_flag_t
Definition: cs_defs.h:324
cs_equation_param_t * hl_eqp
Definition: cs_gwf_priv.h:333
cs_iter_algo_param_aa_t anderson_param
Definition: cs_gwf_priv.h:661
Definition: cs_iter_algo.h:53
cs_flag_t flag
Definition: cs_gwf_priv.h:698
cs_field_t * g_pressure
Definition: cs_gwf_priv.h:436
cs_gwf_darcy_flux_t * darcy
Definition: cs_gwf_priv.h:116
Definition: cs_gwf_priv.h:186
cs_property_t * soil_porosity
Definition: cs_gwf_priv.h:719
cs_property_t * permeability
Definition: cs_gwf_priv.h:206
Definition: cs_gwf_priv.h:248
cs_real_t h_molar_mass
Definition: cs_gwf_priv.h:615
cs_real_t * time_hl_array
Definition: cs_gwf_priv.h:557
cs_real_t * boundary_flux_val
Definition: cs_gwf_priv.h:76
cs_real_t * reac_hg_array
Definition: cs_gwf_priv.h:554
cs_real_t * l_saturation_submesh_pre
Definition: cs_gwf_priv.h:570
cs_field_t * moisture_field
Definition: cs_gwf_priv.h:246
cs_field_t * permeability_field
Definition: cs_gwf_priv.h:245
cs_field_t * l_pressure
Definition: cs_gwf_priv.h:435
cs_real_t ref_temperature
Definition: cs_gwf_priv.h:616
cs_real_t * flux_val
Definition: cs_gwf_priv.h:75
cs_real_t * capillarity_cell_pressure
Definition: cs_gwf_priv.h:567
cs_property_t * diff_hl_pty
Definition: cs_gwf_priv.h:408
cs_real_t * diff_hl_array
Definition: cs_gwf_priv.h:558
