7.2
cs_iter_algo_t Struct Reference
Set of common parameters to manage an iterative algorithm. More...
#include <cs_iter_algo.h>
+ Collaboration diagram for cs_iter_algo_t:
Data Fields
Generic parameters
cs_iter_algo_param_t param
void * context
Convergence indicators
cs_sles_convergence_state_t cvg
double normalization
double tol
double prev_res
double res
double res0
int n_algo_iter
int n_inner_iter
int last_inner_iter
Metadata to manage an iterative algorithm such as Picard or Uzawa for instance. This structure can handle embedded iterative algorithm since the notion of inner and outer iterations is defined. Nevertheless, only the outer iterative algorithm is managed (information about inner iterations are only for monitoring purposes).
Field Documentation
◆ context
context
pointer to structure cast on the fly
◆ cvg
cvg
Converged, iterating or diverged status
◆ last_inner_iter
last_inner_iter
Last number of iterations for the inner solver
◆ n_algo_iter
n_algo_iter
Current number of iterations for the algorithm (outer iterations)
◆ n_inner_iter
n_inner_iter
Curent cumulated number of inner iterations (sum over the outer iterations)
◆ normalization
normalization
Value of the normalization for the relative tolerance.
The stopping criterion is such that res < rtol * normalization. By default, the normalization is set to 1.
◆ param
param
structure storing the main settings
◆ prev_res
prev_res
Value of the previous residual achieved during the iterative process
◆ res
res
Value of the residual for the iterative algorithm
◆ res0
res0
Value of the first residual of the iterative process. This is used for detecting the divergence of the algorithm.
◆ tol
tol
Tolerance computed as tol = max(atol, normalization*rtol) where atol and rtol are respectively the absolute and relative tolerance associated to the algorithm
