#include <float.h>
#include "fvm_hilbert.h"
void | fvm_hilbert_get_coord_extents (int dim, size_t n_coords, const cs_coord_t coords[], cs_coord_t g_extents[]) |
void | fvm_hilbert_encode_coords (int dim, const cs_coord_t extents[], cs_lnum_t n_coords, const cs_coord_t coords[], fvm_hilbert_code_t h_code[]) |
void | fvm_hilbert_local_order (cs_lnum_t n_codes, const fvm_hilbert_code_t hilbert_codes[], cs_lnum_t order[]) |
void | fvm_hilbert_local_order_coords (int dim, const cs_coord_t extents[], cs_lnum_t n_coords, const cs_coord_t coords[], cs_lnum_t order[]) |
void | fvm_hilbert_s_to_code (double s, void *elt, const void *input) |
Function pointer for conversion of a double precision value in range [0, 1] to a given Hilbert code. More... | |
int | fvm_hilbert_compare (const void *elt1, const void *elt2, const void *input) |
Function pointer for comparison of 2 Hilbert codes. More... | |
int fvm_hilbert_compare | ( | const void * | elt1, |
const void * | elt2, | ||
const void * | input | ||
This function is the same type as that used by qsort_r.
[in] | elt1 | coordinate between 0 and 1 |
[in] | elt2 | pointer to optional (untyped) value or structure. |
[in] | input | pointer to optional (untyped) value or structure. |
void fvm_hilbert_encode_coords | ( | int | dim, |
const cs_coord_t | extents[], | ||
cs_lnum_t | n_coords, | ||
const cs_coord_t | coords[], | ||
fvm_hilbert_code_t | h_code[] | ||
void fvm_hilbert_get_coord_extents | ( | int | dim, |
size_t | n_coords, | ||
cs_coord_t | g_extents[] | ||
void fvm_hilbert_local_order | ( | cs_lnum_t | n_codes, |
const fvm_hilbert_code_t | hilbert_codes[], | ||
cs_lnum_t | order[] | ||
void fvm_hilbert_local_order_coords | ( | int | dim, |
void fvm_hilbert_s_to_code | ( | double | s, |
void * | elt, | ||
[in] | s | coordinate between 0 and 1 |
[out] | elt | pointer to element |
