7.1
fvm_hilbert.h
1 #ifndef __FVM_HILBERT_H__
2 #define __FVM_HILBERT_H__
5  * Hilbert space-filling curve construction for coordinates.
30 #include "cs_defs.h"
33  * Local headers
36 #include "fvm_defs.h"
43  * Macro and type definitions
45
46 /* Hilbert code
47  (could be switched from double to long double for extended range) */
48
49 typedef double fvm_hilbert_code_t;
50
52  * Public function definitions
54
55 /*----------------------------------------------------------------------------
56  * Determine the global extents associated with a set of coordinates
57  *
58  * parameters:
59  * dim <-- spatial dimension
60  * n_coords <-- local number of coordinates
61  * coords <-- entity coordinates; size: n_entities*dim (interlaced)
62  * g_extents --> global extents (size: dim*2)
63  * comm <-- associated MPI communicator
64  *---------------------------------------------------------------------------*/
65
66 #if defined(HAVE_MPI)
67 void
69  size_t n_coords,
70  const cs_coord_t coords[],
71  cs_coord_t g_extents[],
72  MPI_Comm comm);
73 #else
74 void
76  size_t n_coords,
77  const cs_coord_t coords[],
78  cs_coord_t g_extents[]);
79 #endif
80
81 /*----------------------------------------------------------------------------
82  * Encode an array of coordinates.
83  *
84  * The caller is responsible for freeing the returned array once it is
85  * no longer useful.
86  *
87  * parameters:
88  * dim <-- 1D, 2D or 3D
89  * extents <-- coordinate extents for normalization (size: dim*2)
90  * n_coords <-- nomber of coordinates in array
91  * coords <-- coordinates in the grid (interlaced, not normalized)
92  * h_code --> array of corresponding Hilbert codes (size: n_coords)
93  *----------------------------------------------------------------------------*/
94
95 void
97  const cs_coord_t extents[],
98  cs_lnum_t n_coords,
99  const cs_coord_t coords[],
100  fvm_hilbert_code_t h_code[]);
101
102 /*----------------------------------------------------------------------------
103  * Locally order a list of Hilbert ids.
104  *
105  * This variant uses an encoding into floating-point numbers. In 3D, this
106  * limits us to 19 levels for a double, though using a long double could
107  * increase this range.
108  *
109  * parameters:
110  * n_codes <-- number of Hilbert ids to order
111  * hilbert_codes <-- array of Hilbert ids to order
112  * order --> pointer to pre-allocated ordering table
113  *----------------------------------------------------------------------------*/
114
115 void
117  const fvm_hilbert_code_t hilbert_codes[],
118  cs_lnum_t order[]);
119
120 /*----------------------------------------------------------------------------
121  * Locally order a list of coordinates based on their Hilbert code.
122  *
123  * This variant may use a maximum depth of 32 levels, and switches
124  * to lexicographical ordering if this is not enough.
125  *
126  * parameters:
127  * dim <-- 1D, 2D or 3D
128  * extents <-- coordinate extents for normalization (size: dim*2)
129  * n_coords <-- nomber of coordinates in array
130  * coords <-- coordinates in the grid (interlaced, not normalized)
131  * order --> pointer to pre-allocated ordering table
132  *----------------------------------------------------------------------------*/
133
134 void
136  const cs_coord_t extents[],
137  cs_lnum_t n_coords,
138  const cs_coord_t coords[],
139  cs_lnum_t order[]);
140
141 /*----------------------------------------------------------------------------*/
150 /*----------------------------------------------------------------------------*/
151
152 void
153 fvm_hilbert_s_to_code(double s,
154  void *elt,
155  const void *input);
156
157 /*----------------------------------------------------------------------------*/
169 /*----------------------------------------------------------------------------*/
170
171 int
172 fvm_hilbert_compare(const void *elt1,
173  const void *elt2,
174  const void *input);
175
176 /*----------------------------------------------------------------------------*/
177
179
180 #endif /* __FVM_HILBERT_H__ */
void fvm_hilbert_get_coord_extents(int dim, size_t n_coords, const cs_coord_t coords[], cs_coord_t g_extents[])
Definition: fvm_hilbert.c:372
Definition: fvm_hilbert.h:49
double cs_coord_t
Definition: cs_defs.h:320
void fvm_hilbert_local_order_coords(int dim, const cs_coord_t extents[], cs_lnum_t n_coords, const cs_coord_t coords[], cs_lnum_t order[])
Definition: fvm_hilbert.c:570
int fvm_hilbert_compare(const void *elt1, const void *elt2, const void *input)
Function pointer for comparison of 2 Hilbert codes.
Definition: fvm_hilbert.c:624
void fvm_hilbert_s_to_code(double s, void *elt, const void *input)
Function pointer for conversion of a double precision value in range [0, 1] to a given Hilbert code...
Definition: fvm_hilbert.c:599
Definition: cs_defs.h:316
void fvm_hilbert_local_order(cs_lnum_t n_codes, const fvm_hilbert_code_t hilbert_codes[], cs_lnum_t order[])
Definition: fvm_hilbert.c:525
void fvm_hilbert_encode_coords(int dim, const cs_coord_t extents[], cs_lnum_t n_coords, const cs_coord_t coords[], fvm_hilbert_code_t h_code[])
Definition: fvm_hilbert.c:417
