#include "cs_base.h"#include "cs_boundary.h"#include "cs_equation.h"#include "cs_iter_algo.h"#include "cs_navsto_param.h"#include "cs_time_plot.h"#include "cs_time_step.h"
Include dependency graph for cs_solidification.h:Go to the source code of this file.
| struct | cs_solidification_stefan_t |
| struct | cs_solidification_voller_t |
| struct | cs_solidification_binary_alloy_t |
| struct | cs_solidification_t |
Macros | |
Flags specifying automatic post-processing for the solidification | |
module | |
| #define | CS_SOLIDIFICATION_POST_CELL_STATE (1 << 0) /* = 1 */ |
| State related to each cell between (solid, mushy, liquid or eutectic) More... | |
| #define | CS_SOLIDIFICATION_POST_ENTHALPY (1 << 1) /* = 2 */ |
| Enthalpy in each cell. By default, only the temperature is post-processed. More... | |
| #define | CS_SOLIDIFICATION_POST_CBULK_ADIM (1 << 2) /* = 4 */ |
| Compute and post-process (C_bulk - C_0)/C_0 Only available if the model CS_SOLIDIFICATION_MODEL_BINARY_ALLOY is activated C_0 is the reference concentration. More... | |
| #define | CS_SOLIDIFICATION_POST_CLIQ (1 << 3) /* = 8 */ |
| Post-process Cliq the liquid solute distribution (wt %) Only available if the model CS_SOLIDIFICATION_MODEL_BINARY_ALLOY is activated. More... | |
| #define | CS_SOLIDIFICATION_POST_LIQUIDUS_TEMPERATURE (1 << 4) /* = 16 */ |
| Activate the (volumic) post-processing of the liquidus temperature in each cell. More... | |
| #define | CS_SOLIDIFICATION_POST_SEGREGATION_INDEX (1 << 5) /* = 32 */ |
| Activate the computation and output in the file solidification.dat for each time step of the segregation index defined by sqrt( 1/|Domaine| * {Domain} ((C_bulk - C_0)/C_0)**2 ) Only available if the model CS_SOLIDIFICATION_MODEL_BINARY_ALLOY is activated. More... | |
| #define | CS_SOLIDIFICATION_POST_SOLIDIFICATION_RATE (1 << 6) /* = 64 */ |
| Activate the computation and output in the file solidification.dat for each time step of the integral over the computational domain of the solid fraction divided by the volume of the domain. More... | |
| #define | CS_SOLIDIFICATION_ADVANCED_ANALYSIS (1 << 7) /* = 128 */ |
| Activate a set of post-processing (Advanced usage. Only for the understanding of the solidification process) More... | |
Flags specifying options specific to the solidification module | |
| #define | CS_SOLIDIFICATION_USE_ENTHALPY_VARIABLE (1 << 0) /*= 1 */ |
| The dynamic system of equations is associated with an energy equation solved using the enthalpy as variable (not fully available). More... | |
| #define | CS_SOLIDIFICATION_NO_VELOCITY_FIELD (1 << 1) /*= 2 */ |
| The system of equations does not involve the Navier-Stokes equations. No velocity is taken into account. More... | |
| #define | CS_SOLIDIFICATION_WITH_SOLUTE_SOURCE_TERM (1 << 2) /*= 4 */ |
| The solute equation related to the transport of the bulk concentration is treated with a source term related to an explicit advection of the quantity (C - Cl). The default behavior is to add a weighting coefficient to the (implicit) advection term related to the liquid fraction This option is related to the LEGACY strategy. More... | |
| #define | CS_SOLIDIFICATION_USE_EXTRAPOLATION (1 << 3) /*= 8 */ |
| Use an extrapolation during the computation of different terms according to the strategy. This extrapolation of variable at time step n+1 uses values at n and n-1: 2*u^n - u^{n-1}. More... | |
| #define | CS_SOLIDIFICATION_WITH_PENALIZED_EUTECTIC (1 << 4) /*= 16 */ |
| Option related to the PATH strategy. Introduce a reaction term and a source term in order to remain on the eutectic plateau. More... | |
| #define | CS_SOLIDIFICATION_BINARY_ALLOY_M_FUNC (1 << 7) /*= 128 */ |
| #define | CS_SOLIDIFICATION_BINARY_ALLOY_C_FUNC (1 << 8) /*= 256 */ |
| #define | CS_SOLIDIFICATION_BINARY_ALLOY_G_FUNC (1 << 9) /*= 512 */ |
| #define | CS_SOLIDIFICATION_BINARY_ALLOY_T_FUNC (1 <<10) /*= 1024 */ |
| typedef void() | cs_solidification_func_t(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts) |
| Function pointer associated to a solidification model aiming at updating/initializing the solidification variables/properties dedicated to the model. More... | |
Enumerations | |
| enum | cs_solidification_model_t { CS_SOLIDIFICATION_MODEL_STEFAN, CS_SOLIDIFICATION_MODEL_VOLLER_PRAKASH_87, CS_SOLIDIFICATION_MODEL_VOLLER_NL, CS_SOLIDIFICATION_MODEL_BINARY_ALLOY, CS_SOLIDIFICATION_N_MODELS } |
| Type of physical model used to simulate the solidifcation/fusion process. More... | |
| enum | cs_solidification_state_t { CS_SOLIDIFICATION_STATE_SOLID = 0, CS_SOLIDIFICATION_STATE_MUSHY = 1, CS_SOLIDIFICATION_STATE_LIQUID = 2, CS_SOLIDIFICATION_STATE_EUTECTIC = 3, CS_SOLIDIFICATION_N_STATES = 4 } |
| Kind of state in which a cell or an entity is. More... | |
| enum | cs_solidification_strategy_t { CS_SOLIDIFICATION_STRATEGY_LEGACY, CS_SOLIDIFICATION_STRATEGY_TAYLOR, CS_SOLIDIFICATION_STRATEGY_PATH, CS_SOLIDIFICATION_N_STRATEGIES } |
| Kind of strategy to use to model the segregation/solidification process. This implies a setting of functions to update the liquid fraction, the thermal source terms, the liquid concentration and its related quantities. More... | |
| bool | cs_solidification_is_activated (void) |
| Test if solidification module is activated. More... | |
| cs_solidification_t * | cs_solidification_get_structure (void) |
| Retrieve the main structure to deal with solidification process. More... | |
| void | cs_solidification_set_verbosity (int verbosity) |
| Set the level of verbosity for the solidification module. More... | |
| void | cs_solidification_set_forcing_eps (cs_real_t forcing_eps) |
| Set the value of the epsilon parameter used in the forcing term of the momentum equation. More... | |
| cs_solidification_t * | cs_solidification_activate (cs_solidification_model_t model, cs_flag_t options, cs_flag_t post_flag, const cs_boundary_t *boundaries, cs_navsto_param_model_t ns_model, cs_navsto_param_model_flag_t ns_model_flag, cs_navsto_param_coupling_t algo_coupling, cs_navsto_param_post_flag_t ns_post_flag) |
| Activate the solidification module. More... | |
| cs_solidification_stefan_t * | cs_solidification_get_stefan_struct (void) |
| Get the structure defining the Stefan model. More... | |
| cs_solidification_stefan_t * | cs_solidification_check_stefan_model (void) |
| Sanity checks on the consistency of the Stefan's model settings. More... | |
| void | cs_solidification_set_stefan_model (cs_real_t t_change, cs_real_t latent_heat) |
| Set the main physical parameters which describe the Stefan model. More... | |
| cs_solidification_voller_t * | cs_solidification_get_voller_struct (void) |
| Get the structure defining the Voller model. More... | |
| cs_solidification_voller_t * | cs_solidification_check_voller_model (void) |
| Sanity checks on the consistency of the Voller's model settings. More... | |
| void | cs_solidification_set_voller_model (cs_real_t beta, cs_real_t t_ref, cs_real_t t_solidus, cs_real_t t_liquidus, cs_real_t latent_heat, cs_real_t s_das) |
| Set the main physical parameters which describe the Voller and Prakash modelling. More... | |
| void | cs_solidification_set_voller_model_no_velocity (cs_real_t t_solidus, cs_real_t t_liquidus, cs_real_t latent_heat) |
| cs_solidification_binary_alloy_t * | cs_solidification_get_binary_alloy_struct (void) |
| Get the structure defining the binary alloy model. More... | |
| cs_solidification_binary_alloy_t * | cs_solidification_check_binary_alloy_model (void) |
| Sanity checks on the consistency of the settings of the binary alloy model. More... | |
| void | cs_solidification_set_binary_alloy_model (const char *name, const char *varname, cs_real_t beta_t, cs_real_t temp0, cs_real_t beta_c, cs_real_t conc0, cs_real_t kp, cs_real_t mliq, cs_real_t t_eutec, cs_real_t t_melt, cs_real_t solute_diff, cs_real_t latent_heat, cs_real_t s_das) |
| Set the main physical parameters which describe a solidification process with a binary alloy (with components A and B) Add a transport equation for the solute concentration to simulate the conv/diffusion of the alloy ratio between the two components of the alloy. More... | |
| void | cs_solidification_set_strategy (cs_solidification_strategy_t strategy) |
| Set the strategy to update quantitiess (liquid fraction and the thermal source term for the two main quantities) More... | |
| void | cs_solidification_set_segr_functions (cs_solidification_func_t *vel_forcing, cs_solidification_func_t *cliq_update, cs_solidification_func_t *gliq_update, cs_solidification_func_t *thm_st_update) |
| Set the functions to perform the update of physical properties and/or the computation of the thermal source term or quantities and/or the way to perform the coupling between the thermal equation and the bulk concentration computation. All this setting defines the way to compute the solidification process of a binary alloy. If a function is set to NULL then the automatic settings are kept. More... | |
| cs_solidification_t * | cs_solidification_destroy_all (void) |
| Free the main structure related to the solidification module. More... | |
| void | cs_solidification_init_setup (void) |
| Setup equations/properties related to the solidification module. More... | |
| void | cs_solidification_finalize_setup (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant) |
| Finalize the setup stage for equations related to the solidification module. More... | |
| void | cs_solidification_log_setup (void) |
| Summarize the solidification module in the log file dedicated to the setup. More... | |
| void | cs_solidification_initialize (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step) |
| Initialize the context structure used to build the algebraic system This is done after the setup step. More... | |
| void | cs_solidification_compute (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step) |
| Solve equations related to the solidification module. More... | |
| void | cs_solidification_extra_op (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts) |
| Predefined extra-operations for the solidification module. More... | |
| void | cs_solidification_extra_post (void *input, int mesh_id, int cat_id, int ent_flag[5], cs_lnum_t n_cells, cs_lnum_t n_i_faces, cs_lnum_t n_b_faces, const cs_lnum_t cell_ids[], const cs_lnum_t i_face_ids[], const cs_lnum_t b_face_ids[], const cs_time_step_t *time_step) |
| Predefined post-processing output for the solidification module. Prototype of this function is fixed since it is a function pointer defined in cs_post.h (cs_post_time_mesh_dep_output_t) More... | |
| #define CS_SOLIDIFICATION_ADVANCED_ANALYSIS (1 << 7) /* = 128 */ |
| #define CS_SOLIDIFICATION_BINARY_ALLOY_C_FUNC (1 << 8) /*= 256 */ |
| #define CS_SOLIDIFICATION_BINARY_ALLOY_G_FUNC (1 << 9) /*= 512 */ |
| #define CS_SOLIDIFICATION_BINARY_ALLOY_M_FUNC (1 << 7) /*= 128 */ |
| #define CS_SOLIDIFICATION_BINARY_ALLOY_T_FUNC (1 <<10) /*= 1024 */ |
| #define CS_SOLIDIFICATION_NO_VELOCITY_FIELD (1 << 1) /*= 2 */ |
| #define CS_SOLIDIFICATION_POST_CBULK_ADIM (1 << 2) /* = 4 */ |
| #define CS_SOLIDIFICATION_POST_CELL_STATE (1 << 0) /* = 1 */ |
| #define CS_SOLIDIFICATION_POST_CLIQ (1 << 3) /* = 8 */ |
| #define CS_SOLIDIFICATION_POST_ENTHALPY (1 << 1) /* = 2 */ |
| #define CS_SOLIDIFICATION_POST_LIQUIDUS_TEMPERATURE (1 << 4) /* = 16 */ |
| #define CS_SOLIDIFICATION_POST_SEGREGATION_INDEX (1 << 5) /* = 32 */ |
| #define CS_SOLIDIFICATION_POST_SOLIDIFICATION_RATE (1 << 6) /* = 64 */ |
| #define CS_SOLIDIFICATION_USE_ENTHALPY_VARIABLE (1 << 0) /*= 1 */ |
| #define CS_SOLIDIFICATION_USE_EXTRAPOLATION (1 << 3) /*= 8 */ |
| #define CS_SOLIDIFICATION_WITH_PENALIZED_EUTECTIC (1 << 4) /*= 16 */ |
| #define CS_SOLIDIFICATION_WITH_SOLUTE_SOURCE_TERM (1 << 2) /*= 4 */ |
| typedef void() cs_solidification_func_t(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts) |
| Enumerator | |
| CS_SOLIDIFICATION_MODEL_STEFAN | Phase change model without advection field. The phase change is assumed to be at a given temperature meaning that the liquid fraction is a step function w.r.t. the temperature. |
| CS_SOLIDIFICATION_MODEL_VOLLER_PRAKASH_87 | Modelling introduced in Voller and Prakash entitled: "A fixed grid numerical modelling methodology for convection-diffusion mushy region phase-change problems" Int. J. Heat Transfer, 30 (8), 1987. No tracer. Only physical constants describing the solidification process are used. |
| CS_SOLIDIFICATION_MODEL_VOLLER_NL | Modelling based on CS_SOLIDIFICATION_MODEL_VOLLER_PRAKASH_87 but the thermal equation and the update of the liquid fraction is non-linear |
| CS_SOLIDIFICATION_MODEL_BINARY_ALLOY | The basis is similar to CS_SOLIDIFICATION_MODEL_VOLLER_PRAKASH_87 A tracer equation is added corresponding to the evolution of the bulk concentration in alloy. This alloy has two chemical constituents hence the name "binary alloy". |
| CS_SOLIDIFICATION_N_MODELS | |
| Enumerator | |
| CS_SOLIDIFICATION_STATE_SOLID | Solid state (the liquid fraction is equal to 0) |
| CS_SOLIDIFICATION_STATE_MUSHY | Mushy state meaning that the liquid fraction is strictly below 1 and strictly above 0. |
| CS_SOLIDIFICATION_STATE_LIQUID | Liquid state (the liquid fraction is equal to 1) |
| CS_SOLIDIFICATION_STATE_EUTECTIC | Eutectic state. Only possible with a CS_SOLIDIFICATION_MODEL_BINARY_ALLOY model. A rough transition between the mushy and solid state occurs when an eutectic transition happens. |
| CS_SOLIDIFICATION_N_STATES | |
| Enumerator | |
| CS_SOLIDIFICATION_STRATEGY_LEGACY | |
| CS_SOLIDIFICATION_STRATEGY_TAYLOR | |
| CS_SOLIDIFICATION_STRATEGY_PATH | |
| CS_SOLIDIFICATION_N_STRATEGIES | |
| cs_solidification_t* cs_solidification_activate | ( | cs_solidification_model_t | model, |
| cs_flag_t | options, | ||
| cs_flag_t | post_flag, | ||
| const cs_boundary_t * | boundaries, | ||
| cs_navsto_param_model_t | ns_model, | ||
| cs_navsto_param_model_flag_t | ns_model_flag, | ||
| cs_navsto_param_coupling_t | algo_coupling, | ||
| cs_navsto_param_post_flag_t | ns_post_flag | ||
| [in] | model | type of modelling |
| [in] | options | flag to handle optional parameters |
| [in] | post_flag | predefined post-processings |
| [in] | ns_model | model equations for the NavSto system |
| [in] | ns_model_flag | option flag for the Navier-Stokes system |
| [in] | algo_coupling | algorithm used for solving the NavSto system |
| [in] | ns_post_flag | predefined post-processings for Navier-Stokes |
| cs_solidification_binary_alloy_t* cs_solidification_check_binary_alloy_model | ( | void | ) |
| cs_solidification_stefan_t* cs_solidification_check_stefan_model | ( | void | ) |
| cs_solidification_voller_t* cs_solidification_check_voller_model | ( | void | ) |
| void cs_solidification_compute | ( | const cs_mesh_t * | mesh, |
| cs_solidification_t* cs_solidification_destroy_all | ( | void | ) |
| void cs_solidification_extra_op | ( | const cs_cdo_connect_t * | connect, |
| void cs_solidification_extra_post | ( | void * | input, |
| int | mesh_id, | ||
| int | cat_id, | ||
| int | ent_flag[5], | ||
| cs_lnum_t | n_cells, | ||
| cs_lnum_t | n_i_faces, | ||
| cs_lnum_t | n_b_faces, | ||
| [in,out] | input | pointer to an optional structure (here a cs_gwf_t structure) |
| void cs_solidification_finalize_setup | ( | const cs_cdo_connect_t * | connect, |
| cs_solidification_binary_alloy_t* cs_solidification_get_binary_alloy_struct | ( | void | ) |
| cs_solidification_stefan_t* cs_solidification_get_stefan_struct | ( | void | ) |
| cs_solidification_t* cs_solidification_get_structure | ( | void | ) |
| cs_solidification_voller_t* cs_solidification_get_voller_struct | ( | void | ) |
| void cs_solidification_init_setup | ( | void | ) |
| void cs_solidification_initialize | ( | const cs_mesh_t * | mesh, |
| bool cs_solidification_is_activated | ( | void | ) |
| void cs_solidification_log_setup | ( | void | ) |
| void cs_solidification_set_binary_alloy_model | ( | const char * | name, |
| const char * | varname, | ||
| cs_real_t | beta_t, | ||
| cs_real_t | temp0, | ||
| cs_real_t | beta_c, | ||
| cs_real_t | conc0, | ||
| cs_real_t | kp, | ||
| cs_real_t | mliq, | ||
| cs_real_t | t_eutec, | ||
| cs_real_t | t_melt, | ||
| cs_real_t | solute_diff, | ||
| cs_real_t | latent_heat, | ||
| cs_real_t | s_das | ||
| [in] | name | name of the binary alloy |
| [in] | varname | name of the unknown related to the tracer eq. |
| [in] | beta_t | thermal dilatation coefficient |
| [in] | temp0 | reference temperature (Boussinesq term) |
| [in] | beta_c | solutal dilatation coefficient |
| [in] | conc0 | reference mixture concentration (Boussinesq term) |
| [in] | kp | value of the distribution coefficient |
| [in] | mliq | liquidus slope for the solute concentration |
| [in] | t_eutec | temperature at the eutectic point |
| [in] | t_melt | phase-change temperature for the pure material (A) |
| [in] | solute_diff | solutal diffusion coefficient in the liquid |
| [in] | latent_heat | latent heat |
| [in] | s_das | secondary dendrite arm spacing |
| void cs_solidification_set_forcing_eps | ( | cs_real_t | forcing_eps | ) |
| [in] | forcing_eps | epsilon used in the penalization term to avoid a division by zero |
| void cs_solidification_set_segr_functions | ( | cs_solidification_func_t * | vel_forcing, |
| cs_solidification_func_t * | cliq_update, | ||
| cs_solidification_func_t * | gliq_update, | ||
| cs_solidification_func_t * | thm_st_update | ||
–Advanced usage– This enables to finely control the numerical or physical modelling aspects.
| [in] | vel_forcing | pointer to update the velocity forcing |
| [in] | cliq_update | pointer to update the liquid concentration |
| [in] | gliq_update | pointer to update the liquid fraction |
| [in] | thm_st_update | pointer to update thermal source terms |
| [in] | t_change | liquidus/solidus temperature (in K) |
| void cs_solidification_set_strategy | ( | cs_solidification_strategy_t | strategy | ) |
| [in] | strategy | strategy to perform the update of quantities |
| void cs_solidification_set_verbosity | ( | int | verbosity | ) |
| [in] | verbosity | level of verbosity to set |
| void cs_solidification_set_voller_model | ( | cs_real_t | beta, |
| cs_real_t | t_ref, | ||
| cs_real_t | t_solidus, | ||
| cs_real_t | t_liquidus, | ||
| [in] | beta | thermal dilatation coefficient |
| [in] | t_ref | reference temperature (for the Boussinesq approx) |
| [in] | t_solidus | solidus temperature (in K) |
| [in] | t_liquidus | liquidus temperature (in K) |
| [in] | s_das | secondary dendrite space arms |
| void cs_solidification_set_voller_model_no_velocity | ( | cs_real_t | t_solidus, |
| cs_real_t | latent_heat | ||
