1 #ifndef __CS_NAVSTO_PARAM_H__ 2 #define __CS_NAVSTO_PARAM_H__ 52 #define CS_NAVSTO_STREAM_EQNAME "streamfunction_eq" 1163 const char *keyval);
void cs_navsto_param_transfer(const cs_navsto_param_t *nsp, cs_equation_param_t *eqp)
Apply the numerical settings defined for the Navier-Stokes system to an equation related to this syst...
Definition: cs_navsto_param.c:1331
Definition: cs_navsto_param.h:1049
Definition: cs_navsto_param.h:196
Definition: cs_navsto_param.h:454
void cs_navsto_param_log(const cs_navsto_param_t *nsp)
Summary of the main cs_navsto_param_t structure.
Definition: cs_navsto_param.c:1390
Definition: cs_navsto_param.h:1046
Definition: cs_navsto_param.h:1051
cs_property_t * lam_viscosity
Definition: cs_navsto_param.h:664
void cs_navsto_set_outlets(cs_navsto_param_t *nsp)
Add the definition of boundary conditions related to outlets into the set of parameters for the manag...
Definition: cs_navsto_param.c:2106
Definition: cs_navsto_param.h:1028
Definition: cs_navsto_param.h:1029
cs_navsto_param_sles_t * sles_param
Definition: cs_navsto_param.h:756
Definition: cs_navsto_param.h:1031
Structure storing the parameters related to the Boussinesq source term in the momentum equation...
Definition: cs_navsto_param.h:586
int n_velocity_ic_defs
Definition: cs_navsto_param.h:818
Definition: cs_navsto_param.h:453
Definition: cs_advection_field.h:149
cs_navsto_param_boussinesq_t * boussinesq_param
Definition: cs_navsto_param.h:743
Definition: cs_navsto_param.h:1041
Definition: cs_navsto_param.h:459
void cs_navsto_add_oseen_field(cs_navsto_param_t *nsp, cs_adv_field_t *adv_fld)
Add a advection field for the Oseen problem.
Definition: cs_navsto_param.c:2681
cs_navsto_param_t * cs_navsto_param_create(const cs_boundary_t *boundaries, cs_navsto_param_model_t model, cs_navsto_param_model_flag_t model_flag, cs_navsto_param_coupling_t algo_coupling, cs_navsto_param_post_flag_t post_flag)
Create a new structure to store all numerical parameters related to the resolution of the Navier-Stok...
Definition: cs_navsto_param.c:626
Definition: cs_navsto_param.h:136
cs_real_t reference_pressure
Definition: cs_navsto_param.h:898
Definition: cs_navsto_param.h:1038
void cs_navsto_param_set_notay_scaling(double scaling_coef)
Set the scaling coefficient used in the Notay's transformation devised in "Algebraic multigrid for St...
Definition: cs_navsto_param.c:605
Definition: cs_navsto_param.h:571
Definition: cs_navsto_param.h:462
Definition: cs_navsto_param.h:133
bool velocity_ic_is_owner
Definition: cs_navsto_param.h:817
Definition: cs_navsto_param.h:577
Definition: cs_navsto_param.h:467
Structure storing the parameters for solving the Navier-Stokes system.
Definition: cs_navsto_param.h:475
Definition: cs_equation_param.h:177
Definition: cs_navsto_param.h:457
Definition: cs_navsto_param.h:86
cs_param_nl_algo_t nl_algo_type
Definition: cs_navsto_param.h:524
cs_xdef_t ** pressure_ic_defs
Definition: cs_navsto_param.h:837
int n_boussinesq_terms
Definition: cs_navsto_param.h:742
cs_xdef_t * cs_navsto_add_velocity_ic_by_analytic(cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *analytic, void *input)
Define the initial condition for the velocity unknowns. This definition can be done on a specified me...
Definition: cs_navsto_param.c:1830
Definition: cs_navsto_param.h:1048
cs_real_t beta
Definition: cs_navsto_param.h:588
Structure storing all the parameters to drive the algorithm called Anderson acceleration.
Definition: cs_iter_algo.h:177
Definition: cs_navsto_param.h:463
Definition: cs_navsto_param.h:443
cs_param_nl_algo_t
Class of non-linear iterative algorithm.
Definition: cs_param_types.h:511
cs_xdef_t * cs_navsto_add_source_term_by_analytic(cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *ana, void *input)
Define a new source term structure defined by an analytical function.
Definition: cs_navsto_param.c:2590
Definition: cs_navsto_param.h:135
cs_xdef_t * cs_navsto_set_velocity_inlet_by_dof_func(cs_navsto_param_t *nsp, const char *z_name, cs_dof_func_t *func, void *func_input)
Define the velocity field for an inlet boundary using a DoF function.
Definition: cs_navsto_param.c:2519
Definition: cs_navsto_param.h:189
Definition: cs_navsto_param.h:448
Definition: cs_navsto_param.h:1024
Definition: cs_navsto_param.h:134
cs_quadrature_type_t qtype
Definition: cs_navsto_param.h:750
Definition: cs_navsto_param.h:1042
cs_xdef_t * cs_navsto_add_source_term_by_array(cs_navsto_param_t *nsp, const char *z_name, cs_flag_t loc, cs_real_t *array, bool is_owner, cs_lnum_t *index)
Define a new source term structure defined by an array.
Definition: cs_navsto_param.c:2655
Definition: cs_navsto_param.h:1035
cs_real_t gd_scale_coef
Definition: cs_navsto_param.h:691
Definition: cs_navsto_param.h:464
Definition: cs_navsto_param.h:1044
void cs_navsto_set_fixed_walls(cs_navsto_param_t *nsp)
Add the definition of boundary conditions related to a fixed wall into the set of parameters for the ...
Definition: cs_navsto_param.c:2006
cs_property_t * mass_density
Definition: cs_navsto_param.h:650
int n_pressure_ic_defs
Definition: cs_navsto_param.h:836
Definition: cs_navsto_param.h:1033
cs_property_t * tot_viscosity
Definition: cs_navsto_param.h:658
cs_flag_t cs_navsto_param_post_flag_t
Definition: cs_navsto_param.h:59
cs_xdef_t * cs_navsto_add_source_term_by_val(cs_navsto_param_t *nsp, const char *z_name, cs_real_t *val)
Define a new source term structure defined by a constant value.
Definition: cs_navsto_param.c:2625
void cs_navsto_param_set(cs_navsto_param_t *nsp, cs_navsto_key_t key, const char *keyval)
Set a parameter attached to a keyname in a cs_navsto_param_t structure.
Definition: cs_navsto_param.c:895
cs_xdef_t * cs_navsto_add_velocity_ic_by_value(cs_navsto_param_t *nsp, const char *z_name, cs_real_t *val)
Definition: cs_navsto_param.c:1766
Definition: cs_navsto_param.h:574
cs_equation_param_t * cs_navsto_param_get_velocity_param(const cs_navsto_param_t *nsp)
Retrieve the cs_equation_param_t structure related to the velocity equation (momentum equation in mos...
Definition: cs_navsto_param.c:1647
Structure storing information related to the "physical" boundaries associated with the computational ...
Definition: cs_boundary.h:155
Definition: cs_navsto_param.h:1026
Definition: cs_navsto_param.h:445
Definition: cs_navsto_param.h:1034
cs_param_advection_strategy_t
Choice of how to handle the advection term in an equation.
Definition: cs_param_types.h:352
cs_turbulence_param_t * turbulence
Definition: cs_navsto_param.h:630
Definition: cs_navsto_param.h:605
Structure and routines handling the SLES settings stored inside a cs_param_sles_t structure...
cs_xdef_t * cs_navsto_set_velocity_wall_by_value(cs_navsto_param_t *nsp, const char *z_name, cs_real_t *values)
Define the velocity field for a sliding wall boundary using a uniform value.
Definition: cs_navsto_param.c:2250
cs_xdef_t ** velocity_bc_defs
Definition: cs_navsto_param.h:869
cs_xdef_t * cs_navsto_set_velocity_inlet_by_array(cs_navsto_param_t *nsp, const char *z_name, cs_flag_t loc, cs_real_t *array, bool is_owner, cs_lnum_t *index)
Define the velocity field for an inlet boundary using an array of values.
Definition: cs_navsto_param.c:2449
Definition: cs_defs.h:322
Definition: cs_navsto_param.h:456
Definition: cs_navsto_param.h:1036
const cs_real_t * var
Definition: cs_navsto_param.h:596
cs_real_t delta_thermal_tolerance
Definition: cs_navsto_param.h:763
Definition: cs_navsto_param.h:450
Definition: cs_navsto_param.h:1023
cs_param_advection_extrapol_t
Choice of how to extrapolate the advection field in the advection term.
Definition: cs_param_types.h:386
void() cs_dof_func_t(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, void *input, cs_real_t *retval)
Definition: cs_navsto_param.h:85
cs_real_t var0
Definition: cs_navsto_param.h:589
Definition: cs_navsto_param.h:194
cs_param_space_scheme_t
Definition: cs_param_types.h:180
Definition: cs_navsto_param.h:624
cs_param_schur_approx_t
Strategy to build the Schur complement approximation. This appears in block preconditioning or uzawa ...
Definition: cs_param_types.h:621
Definition: cs_quadrature.h:52
Definition: cs_navsto_param.h:1037
cs_navsto_key_t
List of available keys for setting the parameters of the Navier-Stokes system.
Definition: cs_navsto_param.h:1021
Definition: cs_navsto_param.h:1025
void cs_navsto_set_reference_pressure(cs_navsto_param_t *nsp, cs_real_t pref)
Set the value to consider for the reference pressure.
Definition: cs_navsto_param.c:1740
Definition: cs_navsto_param.h:193
Definition: cs_param_types.h:100
bool velocity_bc_is_owner
Definition: cs_navsto_param.h:867
cs_param_time_scheme_t time_scheme
Definition: cs_navsto_param.h:701
Definition: cs_navsto_param.h:1032
Definition: cs_navsto_param.h:455
const cs_boundary_t * boundaries
Definition: cs_navsto_param.h:850
Definition: cs_navsto_param.h:88
cs_xdef_t * cs_navsto_set_velocity_inlet_by_value(cs_navsto_param_t *nsp, const char *z_name, cs_real_t *values)
Define the velocity field for an inlet boundary using a uniform value.
Definition: cs_navsto_param.c:2310
cs_navsto_param_post_bit_t
Bit values for additional generic postprocessing related to the Navier-Stokes module. In what follows, w denotes the vorticity vector, u the velocity vector and k the kinetic energy defined by 1/2 * u u.
Definition: cs_navsto_param.h:187
Definition: cs_navsto_param.h:197
Definition: cs_navsto_param.h:618
Definition: cs_navsto_param.h:789
Definition: cs_navsto_param.h:465
cs_param_advection_extrapol_t adv_extrapol
Definition: cs_navsto_param.h:726
Structure storing the parameters related to the resolution of the turbulence modelling. Several members are structures defined in cs_turbulence_model.h as a global variable. The purpose of this structure is to store all parameters in one place.
Definition: cs_cdo_turbulence.h:64
cs_xdef_t ** velocity_ic_defs
Definition: cs_navsto_param.h:819
cs_param_advection_form_t adv_form
Definition: cs_navsto_param.h:723
Definition: cs_navsto_param.h:446
cs_xdef_t * cs_navsto_add_pressure_ic_by_value(cs_navsto_param_t *nsp, const char *z_name, cs_real_t *val)
Define the initial condition for the pressure unknowns. This definition can be done on a specified me...
Definition: cs_navsto_param.c:1903
Definition: cs_navsto_param.h:1040
bool pressure_ic_is_owner
Definition: cs_navsto_param.h:835
Definition: cs_navsto_param.h:1047
Definition: cs_navsto_param.h:137
void cs_navsto_set_symmetries(cs_navsto_param_t *nsp)
Add the definition of boundary conditions related to a symmetry into the set of parameters for the ma...
Definition: cs_navsto_param.c:2055
Definition: cs_xdef.h:154
Definition: cs_navsto_param.h:458
Definition: cs_navsto_param.h:447
cs_real_t theta
Definition: cs_navsto_param.h:702
Definition: cs_navsto_param.h:1039
int il_algo_restart
Definition: cs_navsto_param.h:509
cs_param_advection_strategy_t adv_strategy
Definition: cs_navsto_param.h:725
cs_xdef_t * cs_navsto_set_velocity_inlet_by_analytic(cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *ana, void *input)
Define the velocity field for an inlet boundary using an analytical function.
Definition: cs_navsto_param.c:2373
cs_iter_algo_param_t il_algo_param
Definition: cs_navsto_param.h:502
const char * cs_navsto_param_get_coupling_name(cs_navsto_param_coupling_t coupling)
Retrieve the name of the coupling algorithm.
Definition: cs_navsto_param.c:1712
cs_xdef_t * cs_navsto_add_pressure_ic_by_analytic(cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *analytic, void *input)
Definition: cs_navsto_param.c:1953
cs_navsto_sles_t
High-level information about the way of settings the SLES for solving the Navier-Stokes system...
Definition: cs_navsto_param.h:441
cs_navsto_param_sles_t * cs_navsto_param_get_sles_param(const cs_navsto_param_t *nsp)
Definition: cs_navsto_param.c:1627
Definition: cs_navsto_param.h:84
Definition: cs_navsto_param.h:444
bool pressure_bc_is_owner
Definition: cs_navsto_param.h:884
Definition: cs_navsto_param.h:451
Definition: cs_defs.h:316
double cs_navsto_param_get_notay_scaling(void)
Retrieve the scaling coefficient used in the Notay's transformation devised in "Algebraic multigrid f...
Definition: cs_navsto_param.c:588
cs_xdef_t ** pressure_bc_defs
Definition: cs_navsto_param.h:886
int n_pressure_bc_defs
Definition: cs_navsto_param.h:885
cs_navsto_param_model_bit_t
Bit values for additional physical modelling related to the Navier-Stokes system of equations...
Definition: cs_navsto_param.h:131
Definition: cs_navsto_param.h:195
unsigned short int cs_flag_t
Definition: cs_defs.h:324
cs_navsto_param_t * cs_navsto_param_free(cs_navsto_param_t *param)
Free a cs_navsto_param_t structure.
Definition: cs_navsto_param.c:810
cs_param_dof_reduction_t
Definition: cs_param_types.h:207
cs_iter_algo_param_t nl_algo_param
Definition: cs_navsto_param.h:532
Physical constants descriptor.
Definition: cs_physical_constants.h:51
int verbosity
Definition: cs_navsto_param.h:783
Definition: cs_iter_algo.h:53
Definition: cs_navsto_param.h:461
cs_param_sles_t * schur_sles_param
Definition: cs_navsto_param.h:551
const char * cs_navsto_param_get_model_name(cs_navsto_param_model_t model)
Retrieve the name of the model system of equations.
Definition: cs_navsto_param.c:1683
cs_navsto_param_boussinesq_t * cs_navsto_param_add_boussinesq_term(cs_navsto_param_t *nsp, cs_real_t dilatation_coef, cs_real_t reference_value)
Add a new Boussinesq term (source term for the momemtum equation)
Definition: cs_navsto_param.c:1570
int n_velocity_bc_defs
Definition: cs_navsto_param.h:868
Definition: cs_navsto_param.h:575
Definition: cs_navsto_param.h:573
Definition: cs_navsto_param.h:452
Definition: cs_navsto_param.h:138
cs_param_advection_scheme_t
Definition: cs_param_types.h:319
Definition: cs_navsto_param.h:192
cs_iter_algo_param_aa_t anderson_param
Definition: cs_navsto_param.h:539
Definition: cs_navsto_param.h:1045
Definition: cs_navsto_param.h:190
Definition: cs_navsto_param.h:1043
cs_param_dof_reduction_t dof_reduction_mode
Definition: cs_navsto_param.h:677
Definition: cs_navsto_param.h:1030
cs_param_schur_approx_t schur_approximation
Definition: cs_navsto_param.h:487
Describe the system of equations related to the Navier-Stokes to be solved.
Definition: cs_navsto_param.h:82
int n_max_outer_iter
Definition: cs_navsto_param.h:772
Definition: cs_param_types.h:242
Definition: cs_navsto_param.h:198
cs_navsto_sles_t strategy
Definition: cs_navsto_param.h:481
Definition: cs_param_types.h:275
Definition: cs_navsto_param.h:1027
cs_flag_t cs_navsto_param_model_flag_t
cs_xdef_t * cs_navsto_set_pressure_bc_by_value(cs_navsto_param_t *nsp, const char *z_name, cs_real_t *values)
Set the pressure field on a boundary using a uniform value.
Definition: cs_navsto_param.c:2161
cs_physical_constants_t * phys_constants
Definition: cs_navsto_param.h:643
Structure storing all metadata related to the resolution of a linear system with an iterative solver...
Definition: cs_param_sles.h:62
void cs_navsto_param_set_boussinesq_array(cs_navsto_param_boussinesq_t *bp, const cs_real_t *var)
Set the array of values to consider in the Boussinesq term.
Definition: cs_navsto_param.c:1605
Definition: cs_navsto_param.h:460
cs_param_advection_scheme_t adv_scheme
Definition: cs_navsto_param.h:724
Definition: cs_navsto_param.h:683
cs_param_space_scheme_t space_scheme
Definition: cs_navsto_param.h:708
Definition: cs_navsto_param.h:191
Definition: cs_navsto_param.h:449
