#include "cs_defs.h"#include <assert.h>#include <ctype.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include "bft_mem.h"#include "bft_error.h"#include "bft_printf.h"#include "cs_equation_param.h"#include "cs_log.h"#include "cs_mesh_location.h"#include "cs_post.h"#include "cs_field.h"#include "cs_field_default.h"
Include dependency graph for cs_field_default.c:Functions | |
| int | cs_variable_cdo_field_create (const char *name, const char *label, int location_id, int dim, int has_previous) |
| Add a field shared between CDO and legacy schemes. This field is related to a general solved variable, with default options. More... | |
| int | cs_variable_field_create (const char *name, const char *label, int location_id, int dim) |
| Add field defining a general solved variable, with default options. More... | |
| cs_equation_param_t * | cs_field_get_equation_param (cs_field_t *f) |
| Access a field's equation parameters. More... | |
| const cs_equation_param_t * | cs_field_get_equation_param_const (const cs_field_t *f) |
| Access a field's equation parameters for read only. More... | |
Field utility functions.
| cs_equation_param_t* cs_field_get_equation_param | ( | cs_field_t * | f | ) |
If the equation parameters were never initialized, they will be initialized based on the current defaults.
If the field does not have associated equation paremeters (i.e. is not a variable field or is a CDO field (which is referenced by but does not directly reference equations), NULL is returned.
| [in,out] | f | pointer to associated field |
| const cs_equation_param_t* cs_field_get_equation_param_const | ( | const cs_field_t * | f | ) |
If the equation parameters were never initialized, the current default parameters will be returned instead.
If the field does not have associated equation parameters (i.e. is not a variable field or is a CDO field (which is referenced by but does not directly reference equations), NULL is returned.
| [in] | f | pointer to associated field |
| int cs_variable_cdo_field_create | ( | const char * | name, |
| const char * | label, | ||
| int | location_id, | ||
| int | dim, | ||
| int | has_previous | ||
| [in] | name | field name |
| [in] | label | field default label, or empty |
| [in] | location_id | id of associated location |
| [in] | dim | field dimension |
| [in] | has_previous | no if lower than 1 |
| int cs_variable_field_create | ( | const char * | name, |
| int | dim | ||
