#include "cs_defs.h"#include <assert.h>#include <stdlib.h>#include <string.h>#include <float.h>#include <bft_mem.h>#include "cs_blas.h"#include "cs_boundary_zone.h"#include "cs_cdo_local.h"#include "cs_log.h"#include "cs_math.h"#include "cs_parall.h"#include "cs_parameters.h"#include "cs_xdef_eval.h"#include "cs_equation_common.h"
Include dependency graph for cs_equation_common.c:Functions | |
| void | cs_equation_common_init (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, cs_flag_t eb_flag, cs_flag_t fb_flag, cs_flag_t vb_flag, cs_flag_t vcb_flag, cs_flag_t hho_flag) |
| Allocate a pointer to a buffer of size at least the n_cells for managing temporary usage of memory when dealing with equations The size of the temporary buffer can be bigger according to the numerical settings Set also shared pointers from the main domain members. More... | |
| void | cs_equation_common_finalize (void) |
| Free buffers shared among the equations solved with CDO schemes. More... | |
| cs_equation_builder_t * | cs_equation_builder_init (const cs_equation_param_t *eqp, const cs_mesh_t *mesh) |
| Allocate a new structure to handle the building of algebraic system related to a cs_equation_t structure. More... | |
| void | cs_equation_builder_free (cs_equation_builder_t **p_builder) |
| Free a cs_equation_builder_t structure. More... | |
| void | cs_equation_builder_reset (cs_equation_builder_t *eqb) |
| Free some members of a cs_equation_builder_t structure. More... | |
| void | cs_equation_sync_rhs_normalization (cs_param_resnorm_type_t type, cs_lnum_t rhs_size, const cs_real_t rhs[], double *normalization) |
| Compute the value of the renormalization coefficient for the the residual norm of the linear system A pre-computation arising from cellwise contribution may have been done before this call according to the requested type of renormalization. More... | |
| void | cs_equation_prepare_system (int stride, cs_lnum_t x_size, const cs_matrix_t *matrix, const cs_range_set_t *rset, bool rhs_redux, cs_real_t *x, cs_real_t *b) |
| Prepare a linear system and synchronize buffers to handle parallelism. Transfer a mesh-based description of arrays x0 and rhs into an algebraic description for the linear system in x and b. More... | |
| int | cs_equation_solve_scalar_cell_system (cs_lnum_t n_dofs, const cs_param_sles_t *slesp, const cs_matrix_t *matrix, cs_real_t normalization, cs_sles_t *sles, cs_real_t *x, cs_real_t *b) |
| Solve a linear system arising with scalar-valued cell-based DoFs* No rotation is taken into account when synchronizing halo. More... | |
| int | cs_equation_solve_scalar_system (cs_lnum_t n_scatter_dofs, const cs_param_sles_t *slesp, const cs_matrix_t *matrix, const cs_range_set_t *rset, cs_real_t normalization, bool rhs_redux, cs_sles_t *sles, cs_real_t *x, cs_real_t *b) |
| Solve a linear system arising from CDO schemes with scalar-valued degrees of freedom. More... | |
| void | cs_equation_write_monitoring (const char *eqname, const cs_equation_builder_t *eqb) |
| Print a message in the performance output file related to the monitoring of equation. More... | |
| void | cs_equation_init_reaction_properties (const cs_equation_param_t *eqp, const cs_equation_builder_t *eqb, cs_real_t t_eval, cs_cell_builder_t *cb) |
| Initialize all reaction properties. This function is shared across all CDO schemes. The cs_cell_builder_t structure stores the computed property values. More... | |
| void | cs_equation_set_reaction_properties_cw (const cs_equation_param_t *eqp, const cs_equation_builder_t *eqb, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb) |
| Initialize all reaction properties. This function is shared across all CDO schemes. The cs_cell_builder_t structure stores the computed property values. If the property is uniform, a first call to the function cs_equation_init_reaction_properties or to the function cs_equation_init_properties has to be done before the loop on cells. More... | |
| void | cs_equation_init_properties (const cs_equation_param_t *eqp, const cs_equation_builder_t *eqb, cs_hodge_t *diffusion_hodge, cs_cell_builder_t *cb) |
| Initialize all properties potentially useful to build the algebraic system. This function is shared across all CDO schemes. The cs_cell_builder_t structure stores property values related to the reaction term, unsteady term and grad-div term. More... | |
| void | cs_equation_enforced_internal_dofs (const cs_equation_builder_t *eqb, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Take into account the enforcement of internal DoFs. Apply an algebraic manipulation. Update members of the cs_cell_sys_t structure related to the internal enforcement. More... | |
| void | cs_equation_enforced_internal_block_dofs (const cs_equation_builder_t *eqb, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Take into account the enforcement of internal DoFs. Case of matrices defined by blocks. Apply an algebraic manipulation. Update members of the cs_cell_sys_t structure related to the internal enforcement. More... | |
| cs_real_t * | cs_equation_get_tmpbuf (void) |
| Retrieve a pointer to a buffer of size at least the 2*n_cells The size of the temporary buffer can be bigger according to the numerical settings. More... | |
| size_t | cs_equation_get_tmpbuf_size (void) |
| Get the allocation size of the temporary buffer. More... | |
| cs_equation_balance_t * | cs_equation_balance_create (cs_flag_t location, cs_lnum_t size) |
| Allocate a cs_equation_balance_t structure. More... | |
| void | cs_equation_balance_reset (cs_equation_balance_t *b) |
| Reset a cs_equation_balance_t structure. More... | |
| void | cs_equation_balance_sync (const cs_cdo_connect_t *connect, cs_equation_balance_t *b) |
| Synchronize balance terms if this is a parallel computation. More... | |
| void | cs_equation_balance_destroy (cs_equation_balance_t **p_balance) |
| Free a cs_equation_balance_t structure. More... | |
| void | cs_equation_sync_vol_def_at_vertices (const cs_cdo_connect_t *connect, int n_defs, cs_xdef_t **defs, cs_lnum_t def2v_idx[], cs_lnum_t def2v_ids[]) |
| Synchronize the volumetric definitions to consider at each vertex. More... | |
| void | cs_equation_sync_vol_def_at_edges (const cs_cdo_connect_t *connect, int n_defs, cs_xdef_t **defs, cs_lnum_t def2e_idx[], cs_lnum_t def2e_ids[]) |
| Synchronize the volumetric definitions to consider at each edge. More... | |
| void | cs_equation_sync_vol_def_at_faces (const cs_cdo_connect_t *connect, int n_defs, cs_xdef_t **defs, cs_lnum_t def2f_idx[], cs_lnum_t def2f_ids[]) |
| Synchronize the volumetric definitions to consider at each face. More... | |
| void | cs_equation_sync_vertex_mean_values (const cs_cdo_connect_t *connect, int dim, int *counter, cs_real_t *values) |
| Compute the mean-value across ranks at each vertex. More... | |
| cs_equation_balance_t* cs_equation_balance_create | ( | cs_flag_t | location, |
| cs_lnum_t | size | ||
| [in] | location | where the balance is performed |
| [in] | size | size of arrays in the structure |
| void cs_equation_balance_destroy | ( | cs_equation_balance_t ** | p_balance | ) |
| [in,out] | p_balance | pointer to the pointer to free |
| void cs_equation_balance_reset | ( | cs_equation_balance_t * | b | ) |
| [in,out] | b | pointer to a cs_equation_balance_t to reset |
| void cs_equation_balance_sync | ( | const cs_cdo_connect_t * | connect, |
| cs_equation_balance_t * | b | ||
| [in,out] | b | pointer to a cs_equation_balance_t to rsync |
| void cs_equation_builder_free | ( | cs_equation_builder_t ** | p_builder | ) |
| [in,out] | p_builder | pointer of pointer to the cs_equation_builder_t structure to free |
| cs_equation_builder_t* cs_equation_builder_init | ( | const cs_equation_param_t * | eqp, |
| const cs_mesh_t * | mesh | ||
Allocate a new structure to handle the building of algebraic system related to an cs_equation_t structure.
| void cs_equation_builder_reset | ( | cs_equation_builder_t * | eqb | ) |
| [in,out] | eqb | pointer to the cs_equation_builder_t structure |
| void cs_equation_common_finalize | ( | void | ) |
Allocate a pointer to a buffer of size at least the 2*n_cells for managing temporary usage of memory when dealing with equations Call specific structure allocation related to a numerical scheme according to the scheme flag The size of the temporary buffer can be bigger according to the numerical settings.
| void cs_equation_common_init | ( | const cs_cdo_connect_t * | connect, |
| cs_flag_t | eb_flag, | ||
| cs_flag_t | fb_flag, | ||
| cs_flag_t | vb_flag, | ||
| cs_flag_t | vcb_flag, | ||
| cs_flag_t | hho_flag | ||
| [in] | quant | pointer to additional mesh quantities struct. |
| [in] | eb_flag | metadata for Edge-based schemes |
| [in] | fb_flag | metadata for Face-based schemes |
| [in] | vb_flag | metadata for Vertex-based schemes |
| [in] | vcb_flag | metadata for Vertex+Cell-basde schemes |
| [in] | hho_flag | metadata for HHO schemes |
| void cs_equation_enforced_internal_block_dofs | ( | const cs_equation_builder_t * | eqb, |
| cs_cell_sys_t * | csys | ||
| | | | | | | | | | | Aii | Aie | | Aii | 0 | |bi| |bi -Aid.x_enf| |---------—| –> |---------—| and |–| –> |----------—| | | | | | | | | | | | Aei | Aee | | 0 | Id | |be| | x_enf |
where x_enf is the value of the enforcement for the selected internal DoFs
| [in,out] | csys | structure storing the cell-wise system |
| void cs_equation_enforced_internal_dofs | ( | const cs_equation_builder_t * | eqb, |
| cs_real_t* cs_equation_get_tmpbuf | ( | void | ) |
| size_t cs_equation_get_tmpbuf_size | ( | void | ) |
| void cs_equation_init_properties | ( | const cs_equation_param_t * | eqp, |
| cs_hodge_t * | diffusion_hodge, | ||
| [in,out] | diffusion_hodge | pointer to the diffusion hodge structure |
| void cs_equation_init_reaction_properties | ( | const cs_equation_param_t * | eqp, |
| cs_real_t | t_eval, | ||
| void cs_equation_prepare_system | ( | int | stride, |
| cs_lnum_t | x_size, | ||
| const cs_matrix_t * | matrix, | ||
| const cs_range_set_t * | rset, | ||
| bool | rhs_redux, | ||
| cs_real_t * | x, | ||
| cs_real_t * | b | ||
| [in] | stride | stride to apply to the range set operations |
| [in] | x_size | size of the vector unknowns (scatter view) |
| [in] | matrix | pointer to a cs_matrix_t structure |
| [in] | rset | pointer to a range set structure |
| [in] | rhs_redux | do or not a parallel sum reduction on the RHS |
| [in,out] | x | array of unknowns (in: initial guess) |
| [in,out] | b | right-hand side |
| void cs_equation_set_reaction_properties_cw | ( | const cs_equation_param_t * | eqp, |
| int cs_equation_solve_scalar_cell_system | ( | cs_lnum_t | n_dofs, |
| const cs_param_sles_t * | slesp, | ||
| cs_real_t | normalization, | ||
| cs_sles_t * | sles, | ||
Solve a linear system arising with scalar-valued cell-based DoFs No rotation is taken into account when synchronizing halo.
| [in] | n_dofs | local number of DoFs |
| [in] | slesp | pointer to a cs_param_sles_t structure |
| [in] | normalization | value used for the residual normalization |
| [in,out] | sles | pointer to a cs_sles_t structure |
| [in,out] | x | solution of the linear system (in: initial guess) |
| [in,out] | b | right-hand side (scatter/gather if needed) |
| int cs_equation_solve_scalar_system | ( | cs_lnum_t | n_scatter_dofs, |
| [in] | n_scatter_dofs | local number of DoFs (may be != n_gather_elts) |
| [in] | rs | pointer to a cs_range_set_t structure |
| void cs_equation_sync_rhs_normalization | ( | cs_param_resnorm_type_t | type, |
| cs_lnum_t | rhs_size, | ||
| const cs_real_t | rhs[], | ||
| double * | normalization | ||
| [in] | type | type of renormalization |
| [in] | rhs_size | size of the rhs array |
| [in] | rhs | array related to the right-hand side |
| [in,out] | normalization | value of the residual normalization |
| void cs_equation_sync_vertex_mean_values | ( | const cs_cdo_connect_t * | connect, |
| int | dim, | ||
| int * | counter, | ||
| cs_real_t * | values | ||
| [in] | dim | number of entries for each vertex |
| [in] | counter | number of occurences on this rank |
| [in,out] | values | array to update |
| void cs_equation_sync_vol_def_at_edges | ( | const cs_cdo_connect_t * | connect, |
| int | n_defs, | ||
| cs_xdef_t ** | defs, | ||
| cs_lnum_t | def2e_idx[], | ||
| cs_lnum_t | def2e_ids[] | ||
| [in] | n_defs | number of definitions |
| [in] | defs | number of times the values has been updated |
| [in,out] | def2e_idx | index array to define |
| [in,out] | def2e_ids | array of ids to define |
| void cs_equation_sync_vol_def_at_faces | ( | const cs_cdo_connect_t * | connect, |
| int | n_defs, | ||
| cs_lnum_t | def2f_idx[], | ||
| cs_lnum_t | def2f_ids[] | ||
| [in,out] | def2f_idx | index array to define |
| [in,out] | def2f_ids | array of ids to define |
| void cs_equation_sync_vol_def_at_vertices | ( | const cs_cdo_connect_t * | connect, |
| int | n_defs, | ||
| cs_lnum_t | def2v_idx[], | ||
| cs_lnum_t | def2v_ids[] | ||
| [in,out] | def2v_idx | index array to define |
| [in,out] | def2v_ids | array of ids to define |
| void cs_equation_write_monitoring | ( | const char * | eqname, |
| const cs_equation_builder_t * | eqb | ||
| [in] | eqname | pointer to the name of the current equation |
