cs_velocity_pressure.c File Reference
#include "cs_field_default.h"
#include "cs_field_pointer.h"
#include "cs_map.h"
#include "cs_parameters.h"
#include "cs_porous_model.h"
#include "cs_mesh_location.h"
#include "cs_time_step.h"
#include "cs_velocity_pressure.h"
+ Include dependency graph for cs_velocity_pressure.c:
cs_velocity_pressure_model_tcs_get_glob_velocity_pressure_model (void)
cs_velocity_pressure_param_tcs_get_glob_velocity_pressure_param (void)
 Provide access to cs_glob_velocity_pressure_param. More...
void cs_velocity_pressure_set_n_buoyant_scalars (void)
void cs_velocity_pressure_set_solid (void)
void cs_velocity_pressure_model_log_setup (void)
 Print the volocity-pressure model parameters to setup log. More...
void cs_velocity_pressure_param_log_setup (void)
 Print Velocity-pressure parameters to setup.log. More...
Velocity-pressure coupling model and parameters.
◆ cs_get_glob_velocity_pressure_model()
cs_velocity_pressure_model_t* cs_get_glob_velocity_pressure_model ( void  )
◆ cs_get_glob_velocity_pressure_param()
cs_velocity_pressure_param_t* cs_get_glob_velocity_pressure_param ( void  )
velocity_pressure_param information structure
◆ cs_velocity_pressure_model_log_setup()
void cs_velocity_pressure_model_log_setup ( void  )
Print the stokes model parameters to setup.log.
◆ cs_velocity_pressure_param_log_setup()
void cs_velocity_pressure_param_log_setup ( void  )
◆ cs_velocity_pressure_set_n_buoyant_scalars()
void cs_velocity_pressure_set_n_buoyant_scalars ( void  )
◆ cs_velocity_pressure_set_solid()
void cs_velocity_pressure_set_solid ( void  )
