cs_field_pointer.h
1 #ifndef __CS_FIELD_POINTER_H__
2 #define __CS_FIELD_POINTER_H__
5  * Field pointers and ids for standard and model fields
31  * Local headers
34 #include "cs_defs.h"
35 #include "cs_field.h"
36
38
41 /*=============================================================================
42  * Macro definitions
45 /* Macro used for scoping of field pointer enums */
46
47 #define CS_ENUMF_(e) CS_FIELD_POINTER_ ## e
48
49 /* Macro used to return a field pointer by its enumerated value */
50
51 #define CS_F_(e) cs_glob_field_pointers[CS_FIELD_POINTER_ ## e].f
52
53 #define CS_FI_(e, i) cs_glob_field_pointers[CS_FIELD_POINTER_ ## e].p[i]
54
55 /*============================================================================
56  * Type definitions
58
61 typedef enum {
62
63  /* Base variables and properties */
64
119  /* Specific physics variables and properties */
120
204  /* Cooling tower fields */
214  /* NCFD fields */
250  /* Added variables (scalars) */
253  /* User-defined arrays */
255
256  /* End of attributes */
257
259
261
267 };
268
269 /*============================================================================
270  * Global variables
271  *============================================================================*/
272
273 /* Pointers */
274
276
277 /*=============================================================================
278  * Public function prototypes
279  *============================================================================*/
280
281 /*----------------------------------------------------------------------------
282  * Ensure field pointer array is initialized.
283  *----------------------------------------------------------------------------*/
284
285 void
287
288 /*----------------------------------------------------------------------------
289  * Free all field pointer data.
290  *----------------------------------------------------------------------------*/
291
292 void
294
295 /*----------------------------------------------------------------------------
296  * Map a simple field to an enumerated pointer.
297  *
298  * The associated field pointer may then be retreived using \ref CS_F_(e).
299  *
300  * parameters:
301  * e <-- field enumerator value
302  * f <-- pointer to field structure
303  *----------------------------------------------------------------------------*/
304
305 void
307  cs_field_t *f);
308
309 /*----------------------------------------------------------------------------
310  * Map a field to an (enumerated pointer, index) couple.
311  *
312  * This sort of mapping may be used for sets of fields whose size
313  * is not known in advance.
314  *
315  * The associated field pointer may then be retreived using \ref CS_F_(e, i).
316  *
317  * parameters:
318  * e <-- field enumerator value
319  * index <-- field enumerator index
320  * f <-- pointer to field structure
321  *----------------------------------------------------------------------------*/
322
323 void
325  int index,
326  cs_field_t *f);
327
328 /*----------------------------------------------------------------------------
329  * Map base fields to enumerated pointers.
330  *----------------------------------------------------------------------------*/
331
332 void
334
335 /*----------------------------------------------------------------------------
336  * Map some boundary fields to enumerated pointers.
337  *----------------------------------------------------------------------------*/
338
339 void
341
342 /*----------------------------------------------------------------------------
343  * Map base fields to enumerated pointers for atmospheric models
344  *
345  * parameters:
346  * n_chem_species <-- number of chemical species
347  * species_f_if <-- field id for each chemical species
348  *----------------------------------------------------------------------------*/
349
350 void
351 cs_field_pointer_map_atmospheric(int n_chem_species,
352  const int species_f_id[]);
353
354 /*----------------------------------------------------------------------------
355  * Map base fields to enumerated pointers for atmospheric models
356  *
357  * parameters:
358  * n_coals <-- number of coals
359  * n_classes <-- number of coal classes
360  *----------------------------------------------------------------------------*/
361
362 void
364  int n_classes);
365
366 /*----------------------------------------------------------------------------*
367  * Map base fields to enumerated pointers for compressible model
368  *----------------------------------------------------------------------------*/
369
370 void
372
373 /*----------------------------------------------------------------------------*
374  * Map base fields to enumerated pointers for gas mix model
375  *----------------------------------------------------------------------------*/
376
377 void
379
380 /*----------------------------------------------------------------------------
381  * Map base fields to enumerated pointers for gas combustion.
382  *----------------------------------------------------------------------------*/
383
384 void
386
387 /*----------------------------------------------------------------------------*/
388 /*
389  * Map base fields to enumerated pointers for groundwater flows
390  *----------------------------------------------------------------------------*/
391
392 void
394
395 /*----------------------------------------------------------------------------*/
396
398
399 #endif /* __CS_FIELD_POINTER_H__ */
Definition: cs_field_pointer.h:247
Definition: cs_field_pointer.h:170
Definition: cs_field_pointer.h:202
Definition: cs_field_pointer.h:230
Definition: cs_field_pointer.h:171
Definition: cs_field_pointer.h:166
Definition: cs_field_pointer.h:181
Definition: cs_field_pointer.h:210
void cs_field_pointer_map_base(void)
Definition: cs_field_pointer.c:277
Definition: cs_field_pointer.h:198
Definition: cs_field_pointer.h:110
Definition: cs_field_pointer.h:156
Definition: cs_field_pointer.h:175
Definition: cs_field_pointer.h:145
Definition: cs_field_pointer.h:172
Definition: cs_field.h:125
Definition: cs_field_pointer.h:178
Definition: cs_field_pointer.h:112
Definition: cs_field_pointer.h:149
Definition: cs_field_pointer.h:83
void cs_field_pointer_ensure_init(void)
Definition: cs_field_pointer.c:173
Definition: cs_field_pointer.h:235
void cs_field_pointer_destroy_all(void)
Definition: cs_field_pointer.c:186
Definition: cs_field_pointer.h:233
Definition: cs_field_pointer.h:221
Definition: cs_field_pointer.h:208
Definition: cs_field_pointer.h:157
Definition: cs_field_pointer.h:167
Definition: cs_field_pointer.h:90
Definition: cs_field_pointer.h:243
Definition: cs_defs.h:495
Definition: cs_field_pointer.h:130
Definition: cs_field_pointer.h:222
Definition: cs_field_pointer.h:234
Definition: cs_field_pointer.h:79
Macro used for scoping of field pointer enums.
Definition: cs_field_pointer.h:47
Definition: cs_field_pointer.h:185
Definition: cs_field_pointer.h:139
Definition: cs_field_pointer.h:168
Definition: cs_field_pointer.h:236
Definition: cs_field_pointer.h:237
cs_field_t * f
Definition: cs_field_pointer.h:265
void cs_field_pointer_map_boundary(void)
Definition: cs_field_pointer.c:353
Definition: cs_field_pointer.h:220
Definition: cs_field_pointer.h:132
Definition: cs_field_pointer.h:151
void cs_field_pointer_map_gas_mix(void)
Map base fields to enumerated pointers for gas mix model.
Definition: cs_field_pointer.c:503
Definition: cs_field_pointer.h:67
Definition: cs_field_pointer.h:184
Definition: cs_field_pointer.h:106
void cs_field_pointer_map_compressible(void)
Map base fields to enumerated pointers for compressible model.
Definition: cs_field_pointer.c:466
Definition: cs_field_pointer.h:142
Definition: cs_field_pointer.h:218
Definition: cs_field_pointer.h:78
Definition: cs_field_pointer.h:223
Definition: cs_field_pointer.h:206
Definition: cs_field_pointer.h:245
Definition: cs_field_pointer.h:229
Definition: cs_field_pointer.h:148
Definition: cs_field_pointer.h:160
Definition: cs_field_pointer.h:159
Definition: cs_field_pointer.h:240
void cs_field_pointer_map_coal_combustion(int n_coals, int n_classes)
Map base fields to enumerated pointers for coal combustion.
Definition: cs_field_pointer.c:399
Definition: cs_field_pointer.h:115
Definition: cs_field_pointer.h:183
Definition: cs_field_pointer.h:165
Definition: cs_field_pointer.h:194
Definition: cs_field_pointer.h:113
Definition: cs_field_pointer.h:258
void cs_field_pointer_map_groundwater(void)
Map base fields to enumerated pointers for groundwater flows.
Definition: cs_field_pointer.c:550
Definition: cs_field_pointer.h:212
Definition: cs_field_pointer.h:101
cs_field_t ** p
Definition: cs_field_pointer.h:266
struct cs_field_pointer_array_t * cs_glob_field_pointers
Definition: cs_field_pointer.c:130
Definition: cs_field_pointer.h:134
Definition: cs_field_pointer.h:121
Definition: cs_field_pointer.h:104
Definition: cs_field_pointer.h:207
Definition: cs_field_pointer.h:182
Definition: cs_field_pointer.h:224
Definition: cs_field_pointer.h:228
Definition: cs_field_pointer.h:209
Definition: cs_field_pointer.h:129
Definition: cs_field_pointer.h:216
Definition: cs_field_pointer.h:215
Definition: cs_field_pointer.h:173
void cs_field_pointer_map_indexed(cs_field_pointer_id_t e, int index, cs_field_t *f)
Definition: cs_field_pointer.c:232
Definition: cs_field_pointer.h:158
void cs_field_pointer_map(cs_field_pointer_id_t e, cs_field_t *f)
Definition: cs_field_pointer.c:210
Definition: cs_field_pointer.h:191
Definition: cs_field_pointer.h:147
Definition: cs_field_pointer.h:99
Definition: cs_field_pointer.h:232
Definition: cs_field_pointer.h:254
Definition: cs_field_pointer.h:95
Definition: cs_field_pointer.h:227
Definition: cs_field_pointer.h:196
Definition: cs_field_pointer.h:244
Definition: cs_field_pointer.h:87
Definition: cs_field_pointer.h:126
Definition: cs_field_pointer.h:231
Definition: cs_field_pointer.h:200
Definition: cs_field_pointer.h:117
Definition: cs_field_pointer.h:107
Definition: cs_field_pointer.h:100
Definition: cs_field_pointer.h:188
Definition: cs_field_pointer.h:219
Definition: cs_field_pointer.h:225
Definition: cs_field_pointer.h:239
Definition: cs_field_pointer.h:187
Definition: cs_field_pointer.h:205
Definition: cs_field_pointer.h:150
Definition: cs_field_pointer.h:189
Definition: cs_field_pointer.h:75
Definition: cs_field_pointer.h:176
Definition: cs_field_pointer.h:162
Definition: cs_field_pointer.h:241
Definition: cs_field_pointer.h:238
Definition: cs_field_pointer.h:143
Definition: cs_field_pointer.h:86
Definition: cs_field_pointer.h:77
Definition: cs_field_pointer.h:251
Definition: cs_field_pointer.h:192
Definition: cs_field_pointer.h:264
Definition: cs_defs.h:496
Definition: cs_field_pointer.h:152
Definition: cs_field_pointer.h:73
Definition: cs_field_pointer.h:81
Definition: cs_field_pointer.h:211
Definition: cs_field_pointer.h:137
Definition: cs_field_pointer.h:169
Definition: cs_field_pointer.h:163
Definition: cs_field_pointer.h:153
Definition: cs_field_pointer.h:127
Definition: cs_field_pointer.h:154
Definition: cs_field_pointer.h:141
Definition: cs_field_pointer.h:155
Definition: cs_field_pointer.h:195
Definition: cs_field_pointer.h:217
Definition: cs_field_pointer.h:103
Definition: cs_field_pointer.h:197
Definition: cs_field_pointer.h:74
Definition: cs_field_pointer.h:109
Definition: cs_field_pointer.h:135
Definition: cs_field_pointer.h:61
Definition: cs_field_pointer.h:131
Definition: cs_field_pointer.h:246
Definition: cs_field_pointer.h:94
Definition: cs_field_pointer.h:161
Definition: cs_field_pointer.h:193
Definition: cs_field_pointer.h:116
Definition: cs_field_pointer.h:71
Definition: cs_field_pointer.h:174
Definition: cs_field_pointer.h:226
Definition: cs_field_pointer.h:125
Definition: cs_field_pointer.h:248
Definition: cs_field_pointer.h:179
void cs_field_pointer_map_atmospheric(int n_chem_species, const int species_f_id[])
Map base fields to enumerated pointers for atmospheric models.
Definition: cs_field_pointer.c:372
Definition: cs_field_pointer.h:138
Definition: cs_field_pointer.h:146
Definition: cs_field_pointer.h:82
Definition: cs_field_pointer.h:242
Definition: cs_field_pointer.h:190
Definition: cs_field_pointer.h:76
void cs_field_pointer_map_gas_combustion(void)
Definition: cs_field_pointer.c:516
Definition: cs_field_pointer.h:123
