cs_velocity_pressure_model_t Struct Reference
Stokes equation model descriptor. More...
#include <cs_velocity_pressure.h>
+ Collaboration diagram for cs_velocity_pressure_model_t:
Data Fields
int ivisse
int idilat
bool fluid_solid
int n_buoyant_scal
Members of these Stokes equation model descriptor are publicly accessible, to allow for concise syntax, as it is expected to be used in many places.
Field Documentation
◆ fluid_solid
fluid_solid
Has a solid zone where dynamics must be killed?
  • false (default)
  • true
◆ idilat
idilat
algorithm to take into account the density variation in time
  • 0: Boussinesq approximation (rho constant except in the buoyant term where $\Delta \rho \vect{g} = - \rho \beta \Delta T \vect{g} $
  • 1: dilatable steady algorithm (default)
  • 2: dilatable unsteady algorithm
  • 3: low-Mach algorithm
  • 4: algorithm for fire
◆ ivisse
ivisse
Indicates whether the source terms in transposed gradient and velocity divergence should be taken into account in the momentum equation. In the compressible module, these terms also account for the volume viscosity (cf. viscv0 and iviscv) $\partial_i \left[(\kappa -2/3\,(\mu+\mu_t))\partial_k U_k \right] + \partial_j \left[ (\mu+\mu_t)\partial_i U_j \right]$:
  • 0: not taken into account,
  • 1: taken into account.
◆ n_buoyant_scal
int n_buoyant_scal
