struct | cs_turb_model_t |
Turbulence model general options descriptor. More... | |
struct | cs_turb_ref_values_t |
struct | cs_turb_rans_model_t |
RANS turbulence model descriptor. More... | |
struct | cs_turb_les_model_t |
LES turbulence model descriptor. More... | |
Enumerations | |
enum | cs_turb_model_type_t { CS_TURB_NONE = 0, CS_TURB_MIXING_LENGTH = 10, CS_TURB_K_EPSILON = 20, CS_TURB_K_EPSILON_LIN_PROD = 21, CS_TURB_K_EPSILON_LS = 22, CS_TURB_K_EPSILON_QUAD = 23, CS_TURB_RIJ_EPSILON_LRR = 30, CS_TURB_RIJ_EPSILON_SSG = 31, CS_TURB_RIJ_EPSILON_EBRSM = 32, CS_TURB_LES_SMAGO_CONST = 40, CS_TURB_LES_SMAGO_DYN = 41, CS_TURB_LES_WALE = 42, CS_TURB_V2F_PHI = 50, CS_TURB_V2F_BL_V2K = 51, CS_TURB_K_OMEGA = 60, CS_TURB_SPALART_ALLMARAS = 70 } |
enum | { CS_TURB_TYPE_NONE = 0, CS_TURB_RANS = 1, CS_TURB_LES = 2, CS_TURB_HYBRID = 3 } |
enum | { CS_TURB_ALGEBRAIC = 0, CS_TURB_FIRST_ORDER = 1, CS_TURB_SECOND_ORDER = 2 } |
enum | { CS_HYBRID_NONE = 0, CS_HYBRID_DES = 1, CS_HYBRID_DDES = 2, CS_HYBRID_SAS = 3 } |
void | cs_turb_model_init (void) |
Initialize turbulence model structures. More... | |
void | cs_set_type_order_turbulence_model (void) |
Initialize type and order members of turbulence model structure. More... | |
void | cs_set_glob_turb_model (void) |
Set global pointer to turbulence model structure. More... | |
cs_turb_model_t * | cs_get_glob_turb_model (void) |
Provide write access to turbulence model structure. More... | |
void | cs_turb_compute_constants (void) |
Compute turbulence model constants, some of which may depend on the model choice. More... | |
cs_turb_ref_values_t * | cs_get_glob_turb_ref_values (void) |
Provide access to cs_glob_turb_ref_values. More... | |
cs_turb_rans_model_t * | cs_get_glob_turb_rans_model (void) |
Provide access to cs_glob_turb_rans_model. More... | |
cs_turb_les_model_t * | cs_get_glob_turb_les_model (void) |
Provide access to cs_glob_turb_les_model. More... | |
void | cs_turb_model_log_setup (void) |
Print the turbulence model parameters to setup.log. More... | |
void | cs_turb_constants_log_setup (void) |
Print the turbulent constants to setup.log. More... | |
void | cs_clip_turbulent_fluxes (int flux_id, int ivartt) |
Clipping for the turbulence flux vector. More... | |
enum cs_turb_model_type_t |
void cs_clip_turbulent_fluxes | ( | int | flux_id, |
int | variance_id | ||
[in] | flux_id | turbulent flux index |
[in] | variance_id | scalar variance index |
cs_turb_les_model_t* cs_get_glob_turb_les_model | ( | void | ) |
needed to initialize structure with GUI
cs_turb_model_t* cs_get_glob_turb_model | ( | void | ) |
cs_turb_rans_model_t* cs_get_glob_turb_rans_model | ( | void | ) |
cs_turb_ref_values_t* cs_get_glob_turb_ref_values | ( | void | ) |
void cs_set_glob_turb_model | ( | void | ) |
This global pointer provides a read-only access to the structure.
void cs_set_type_order_turbulence_model | ( | void | ) |
void cs_turb_compute_constants | ( | void | ) |
void cs_turb_constants_log_setup | ( | void | ) |
void cs_turb_model_init | ( | void | ) |
void cs_turb_model_log_setup | ( | void | ) |
const cs_turb_les_model_t* cs_glob_turb_les_model |
const cs_turb_model_t* cs_glob_turb_model |
const cs_turb_rans_model_t* cs_glob_turb_rans_model |
const cs_turb_ref_values_t* cs_glob_turb_ref_values |
const double cs_turb_ales |
Constant used to define, for each cell , the width of the (implicit) filter:
Useful if and only if iturb = 40 or 41.
const double cs_turb_apow |
Werner and Wengle coefficient
const double cs_turb_bles |
const double cs_turb_bpow |
const double cs_turb_c1trit |
Coefficient of turbulent DFM flow model.
const double cs_turb_c2trit |
const double cs_turb_c3trit |
const double cs_turb_c4trit |
const double cs_turb_ccaza |
Constants of the Cazalbou rotation/curvature correction.
const double cs_turb_ccazb |
const double cs_turb_ccazc |
const double cs_turb_ccazd |
const double cs_turb_ccaze2 |
const double cs_turb_ccazsc |
double cs_turb_cddes |
Constant for the
SST model. Useful if and only if iturb=60 (
SST) and hybrid_turb=1.
double cs_turb_cdries |
Van Driest constant appearing in the van Driest damping function applied to the Smagorinsky constant:
double cs_turb_ce1 |
Constant for all the RANS turbulence models except for the v2f and the
models. Useful if and only if iturb= 20, 21, 30 or 31 (
or
double cs_turb_ce2 |
Constant for the
and
LRR models. Useful if and only if iturb = 20, 21 or 30 (
or
LRR).
double cs_turb_ce4 |
Coefficient of interfacial coefficient in k-eps, used in Lagrange treatment.
Constant for the interfacial term (Lagrangian module) in case of two-way coupling. Useful in case of Lagrangian modelling, in
and
with two-way coupling.
const double cs_turb_cebme2 |
Constant of the Rij-epsilon EBRSM.
const double cs_turb_cebmmu |
const double cs_turb_cebmr1 |
const double cs_turb_cebms1 |
const double cs_turb_cebms2 |
const double cs_turb_ckwa1 |
Specific constant of k-omega SST. Constant for the
SST).
const double cs_turb_ckwbt1 |
Constant for the
SST).
const double cs_turb_ckwbt2 |
Constant for the
SST).
const double cs_turb_ckwc1 |
Constant for the
SST). Specific constant of k-omega SST.
double cs_turb_ckwgm1 |
. Constant
for the
SST).
double cs_turb_ckwgm2 |
. Constant
for the
SST).
const double cs_turb_ckwsk1 |
Constant for the
SST model. Useful if and only if iturb=60.
const double cs_turb_ckwsk2 |
Constant for the
const double cs_turb_ckwsw1 |
Constant for the
SST).
const double cs_turb_ckwsw2 |
Constant for the
SST).
double cs_turb_cmu |
Constant for all the RANS turbulence models except for the v2f model (see cs_turb_cv2fmu for the value of
in case of v2f modelling). Useful if and only if iturb = 20, 21, 30, 31 or 60 (
or
double cs_turb_cmu025 |
const double cs_turb_cnl1 |
Constants for the Baglietto et al. quadratic k-epsilon model. Useful if and only if iturb = CS_TURB_K_EPSILON_QUAD
const double cs_turb_cnl2 |
const double cs_turb_cnl3 |
const double cs_turb_cnl4 |
const double cs_turb_cnl5 |
const double cs_turb_cpalc1 |
Specific constant of v2f "BL-v2k" (or phi-alpha).
const double cs_turb_cpalc2 |
const double cs_turb_cpalcl |
const double cs_turb_cpalct |
const double cs_turb_cpale1 |
const double cs_turb_cpale2 |
const double cs_turb_cpale3 |
const double cs_turb_cpale4 |
const double cs_turb_cpalet |
const double cs_turb_cpalmu |
double cs_turb_crij1 |
Constant for the
LRR model. Useful if and only if iturb=30 (
LRR).
double cs_turb_crij2 |
double cs_turb_crij3 |
Constant for the
models. Value is 0.55 for SSG and LRR, 0.6 for EBRSM.
const double cs_turb_crijp1 |
Constant for the
LRR model, corresponding to the wall echo terms. Useful if and only if iturb=30 and cs_turb_rans_model_t::irijec=1 (
LRR).
const double cs_turb_crijp2 |
Constant for the
LRR).
const double cs_turb_csab1 |
Specific constant of Spalart-Allmaras.
const double cs_turb_csab2 |
const double cs_turb_csas |
Constant for the hybrid
SST) and hybrid_turb=3.
const double cs_turb_csas_eta2 |
constant for the hybrid
const double cs_turb_csasig |
const double cs_turb_csav1 |
double cs_turb_csaw1 |
const double cs_turb_csaw2 |
const double cs_turb_csaw3 |
double cs_turb_csmago |
Smagorinsky constant used in the Smagorinsky model for LES. The sub-grid scale viscosity is calculated by where
is the width of the filter and
the filtered strain rate.
Useful if and only if iturb = 40.
double cs_turb_csmago_max |
Maximum allowed value for the variable appearing in the LES dynamic model. Any larger value yielded by the calculation procedure of the dynamic model will be clipped to
Useful if and only if iturb = 41.
double cs_turb_csmago_min |
Minimum allowed value for the variable appearing in the LES dynamic model. Any smaller value yielded by the calculation procedure of the dynamic model will be clipped to
double cs_turb_csrij |
Constant for the
LRR).
const double cs_turb_cssge2 |
Constant for the
SSG model. Useful if and only if iturb=31 (
SSG).
const double cs_turb_cssgr1 |
Constant for the
SSG).
const double cs_turb_cssgr2 |
Constant for the
SSG).
const double cs_turb_cssgr3 |
Constant for the
SSG).
const double cs_turb_cssgr4 |
constant for the
SSG).
const double cs_turb_cssgr5 |
Constant for the
SSG).
const double cs_turb_cssgs1 |
Constant for the
SSG).
const double cs_turb_cssgs2 |
Constant for the
SSG).
const double cs_turb_cssr1 |
Constant of the Spalart-Shur rotation/curvature correction.
const double cs_turb_cssr2 |
const double cs_turb_cssr3 |
const double cs_turb_cstlog |
Constant of logarithmic smooth law function: (
Constant of the logarithmic wall function. Useful if and only if iturb >= 10 (mixing length, ,
, LES, v2f or
double cs_turb_cstlog_alpha |
Constant for logarithmic law function switching from rough to smooth:
, LES, v2f or
const double cs_turb_cstlog_rough |
Constant of logarithmic rough law function: (
, LES, v2f or
const double cs_turb_cthafm |
Constant of GGDH and AFM on the thermal scalar.
const double cs_turb_cthdfm |
const double cs_turb_cv2fa1 |
Constant for the v2f
-model. Useful if and only if iturb=50 (v2f
-model).
const double cs_turb_cv2fc1 |
-model).
const double cs_turb_cv2fc2 |
-model).
const double cs_turb_cv2fcl |
-model).
const double cs_turb_cv2fct |
-model).
const double cs_turb_cv2fe2 |
-model).
const double cs_turb_cv2fet |
-model).
const double cs_turb_cv2fmu |
-model).
double cs_turb_cwale |
Constant of the WALE LES method.
double cs_turb_dpow |
const double cs_turb_etaafm |
Coefficient of turbulent AFM flow model.
const double cs_turb_vdriest |
Van Driest constant. (= 25.6)
Useful if and only if cs_glob_wall_functions::iwallf = CS_WALL_F_2SCALES_VDRIEST. (Two scales log law at the wall using Van Driest mixing length expression).
const double cs_turb_xa1 |
Constant in the expression of Ce1' for the Rij-epsilon EBRSM.
const double cs_turb_xceta |
const double cs_turb_xcl |
const double cs_turb_xct |
const double cs_turb_xiafm |
const double cs_turb_xkappa |
Karman constant. (= 0.42)
Useful if and only if iturb >= 10. (mixing length, ,
, LES, v2f or
double cs_turb_xlesfd |
Ratio between explicit and explicit filter width for a dynamic model. Constant used to define, for each cell , the width of the explicit filter used in the framework of the LES dynamic model:
const double cs_turb_xlesfl |
Constant used in the definition of LES filtering diameter: cs_turb_xlesfl is a constant used to define, for each cell
