cs_user_parameters.f90 File Reference
User subroutines for input of calculation parameters (Fortran modules). These subroutines are called in all cases. More...
Functions/Subroutines
subroutine usppmo (ixmlpu)
 User subroutine for selection of specific physics module. More...
subroutine usipph (ixmlpu, iturb, itherm, iale)
 User subroutine for input of model selection parameters. More...
subroutine usipsu (nmodpp)
 User subroutine for the input of additional user parameters. More...
subroutine usipes (nmodpp)
 User subroutine for the input of additional user parameters for input/output. More...
subroutine cs_user_combustion
 This routine is called: More...
subroutine cs_f_user_radiative_transfer_param
 User subroutines for input of calculation parameters, and to initialize variables used for radiative transfer module. More...
subroutine uscfx1
 User subroutine. More...
subroutine uscfx2
subroutine cs_user_cooling_towers
 Definition of cooling tower model and exchange zones. More...
subroutine user_darcy_ini1
 User routine for definition of computation parameters dealing with Darcy module. More...
See Input of calculation parameters (Fortran subroutines in cs_user_parameters.f90) for examples.
If the Code_Saturne GUI is used, this file is not required (but may be used to override parameters entered through the GUI, and to set parameters not accessible through the GUI).
Several routines are present in the file, each destined to defined specific parameters.
To modify the default value of parameters which do not appear in the examples provided, code should be placed as follows:
  • usipsu for numerical and physical options
  • usipes for input-output related options
As a convention, "specific physics" defers to the following modules only: pulverized coal, gas combustion, electric arcs.
In addition, specific routines are provided for the definition of some "specific physics" options. These routines are described at the end of this file and will be activated when the corresponding option is selected in the usppmo routine.
◆ cs_f_user_radiative_transfer_param()
subroutine cs_f_user_radiative_transfer_param ( )
◆ cs_user_combustion()
subroutine cs_user_combustion ( )
  1. Additional Calculation Options a. Density Relaxation
  2. Physical Constants a.Dynamic Diffusion Coefficient b.Constants of the chosen model (EBU, Libby-Williams, ...) - Eddy Break Up pre-mixed flame
    • Diffusion flame in the framework of ``3 points'' rapid complete chemistry
    • Libby-Williams pre-mixed flame
    • Lagrangian module coupled with pulverized coal: Eulerian combustion of pulverized coal and Lagrangian transport of coal particles
    • Pulverised coal combustion
    • Fuel (oil) combustion
◆ cs_user_cooling_towers()
subroutine cs_user_cooling_towers ( )
◆ uscfx1()
subroutine uscfx1 ( )
User subroutine.
Initialize non standard options for the compressible flow scheme such as the variability of the thermal conductivity and the volume viscosity. Their values can be given in the subroutine uscfx2 .
◆ uscfx2()
subroutine uscfx2 ( )
User subroutine.
Set values for the reference volumic viscosity, the reference conductivity and the molar mass for compressible flow.
Initialize non standard options for the compressible flow scheme such as the hydrostatic equilibrium.
In addition to options set in the user subroutine uscfx1 (or in the GUI): this subroutine allows to set a switch to indicate if the molecular viscosity is constant, its values being given in the user subroutine usipsu .
◆ user_darcy_ini1()
subroutine user_darcy_ini1 ( )
◆ usipes()
subroutine usipes ( integer  nmodpp)
[in]nmodppnumber of active specific physics models
This subroutine allows setting parameters which do not already appear in the other subroutines of this file.
It is possible to add or remove parameters. The number of physical properties and variables is known here.
◆ usipph()
subroutine usipph ( integer  ixmlpu,
integer  iturb,
integer  itherm,
integer  iale
[in]ixmlpuindicates if the XML file from the GUI is used used (1: yes, 0: no
[in,out]iturbturbulence model
[in,out]ithermthermal model
[in,out]ialeALE module
In this subroutine, only the parameters which already appear may be set, to the exclusion of any other.
If we are not using the Code_Saturne GUI: All the parameters which appear in this subroutine must be set.
If we are using the Code_Saturne GUI: parameters protected by a test of the form:
if (ixmlpu.eq.0) then ... endif
should already have been defined using the GUI, so only experts should consider removing the test and adapting them here.
◆ usipsu()
subroutine usipsu ( integer  nmodpp)
[in]nmodppnumber of active specific physical models !
◆ usppmo()
subroutine usppmo ( integer  ixmlpu)
Define the use of a specific physics amongst the following:
  • combustion with gas / coal / heavy fuel oil
  • compressible flows
  • electric arcs
  • atmospheric modelling
  • radiative transfer
  • cooling towers modelling
    Only one specific physics module can be activated at once.
    [in]ixmlpuindicates if an XML file from the GUI is used !
