Input of calculation parameters (Fortran subroutines in cs_user_parameters.f90)
Introduction
User subroutines for input of calculation parameters (Fortran modules). These subroutines are called in all cases.
If the Code_Saturne GUI is used, this file is not required (but may be used to override parameters entered through the GUI, and to set parameters not accessible through the GUI).
Several routines are present in the file, each destined to defined specific parameters.
To modify the default value of parameters which do not appear in the examples provided, code should be placed as follows:
  • usipsu for numerical and physical options
  • usipes for input-output related options
  • usppmo for specific physics options
  • usipph for additional input of parameters
  • usati1 for calculation options for the atmospheric module
  • cs_user_combustion for calculation options for the combustion module
  • uscfx1 and uscfx2 for non-standard options for the compressible module
  • uscti1 for the definition of cooling tower model and exchange zones
  • user_darcy_ini1 for calculation options for the Darcy module
As a convention, "specific physics" defers to the following modules only: pulverized coal, gas combustion, electric arcs.
In addition, specific routines are provided for the definition of some "specific physics" options. These routines are described at the end of this file and will be activated when the corresponding option is selected in the usppmo routine.
General options (usipsu)
All options
The following code block presents all the options available in the usipsu subroutine.
! Calculation options (optcal)
! In case of restart, read auxiliary restart file ileaux (= 1) or not (0).
! By default, this file is read, but it may be useful to deactivate
! its use when restarting after a preprocessing stage possibly leading
! to a different number of faces (such as simply joining meshes on
! a different architecture or optimization level or with different options).
! Writing of auxiliary restart files may also be deactivated using: iecaux = 0
ileaux = 0
! --- Algorithm to take into account the thermodynamical pressure variation in time
! (not used by default except if idilat = 3)
! by default:
! - the thermodynamic pressure (pther) is initialized with p0 = p_atmos
! - the maximum thermodynamic pressure (pthermax) is initialized with -1
! (no maximum by default, this term is used to model a venting effect when
! a positive value is given by the user)
! - a global leak can be set through a leakage surface sleak with a head
! loss kleak of 2.9 (Idelcick)
ipthrm = 0
pthermax= -1.d0
sleak = 0.d0
kleak = 2.9d0
! --- Temperature or enthalpy
! When used without specific physics, if we have chosen to solve in temperature
! (that is if itherm = 1), the fluid temperature is considered to be in
! degrees Kelvin by default (be careful for boundary conditions an expression
! of physical properties depending on temperature)t.
! If we wish for the fluid solver to work with a temperature in degrees Celsius,
! we must set itpscl = 2.
! This is recommended for Syrthes Coupling, but not recommended for the
! radiative model, as it is a source of user errors in this case:
! Indeed, the boundary conditions for the fluid temperature will then be
! in degrees Celsius, while the boundary conditions for radiation in
! cs_user_radiative_transfer_bcs must still be in Kelvin.
if (nmodpp.eq.0) then
itpscl = 2
endif
! If a USER scalar behaves like a temperature (relative to Cp):
! we set the "is_temperature" keyword to 1.
if (nscaus.gt.0) then
do ii = 1, nscaus
call field_set_key_int(ivarfl(isca(ii)), kscacp, 1)
enddo
endif
! --- Calculation (restart) with frozen velocity field (1 yes, 0 no)
iccvfg = 1
! --- Rotation/curvature correction for eddy-viscosity turbulence models
! 0: deactivated
! 1: activated
irccor = 1
! --- rotation of the reference frame (omega in rad/s)
! If the rotation is not nul, then
! icorio = 0: rotation is taken into account by rotating the mesh
! (simulation in the absolute frame)
! = 1: rotation is taken into account by Coriolis source terms
! (simulation in the relative frame)
icorio = 0
call rotation_define(0.d0, 0.d0, 0.d0, & ! rotation vector
0.d0, 0.d0, 0.d0) ! invariant point
! --- Variable diffusivity field id (ifcvsl>=0) or constant
! diffusivity (ifcvsl=-1) for the thermal scalar and USER scalars.
! With ifcvsl = 0, the field will be added automatically, and later calls to
! field_get_key_int(ivarfl(isca(iscal)), kivisl, ifcvsl)
! will return its id.
! With ifcvsl > 0, the id of an existing, predifined field is given. This
! may allow sharing a diffusivity between multiple scalars.
! For user scalars iscal which represent the variance of another user
! scalar, the diffusivity of the variance of a scalar is assumed to
! have the same behavior as the diffusivity of this scalar,
! so values set here will be ignored.
! For non-user scalars relative to specific physics (coal, combustion,
! electric arcs: see usppmo) implicitly defined in the model,
! the diffusivity should not be modified here.
! Caution: complete cs_user_physical_properties with the law defining the diffusivity
! ======== if and only if ifcvsl = 0 has been set here.
! For thermal scalar
if (ippmod(icompf).ge.0) then
ifcvsl = -1
call field_set_key_int(ivarfl(isca(itempk)), kivisl, ifcvsl)
else if (iscalt.gt.0) then
ifcvsl = -1
call field_set_key_int(ivarfl(isca(iscalt)), kivisl, ifcvsl)
endif
do iscal = 1, nscaus
if (iscavr(iscal).le.0) then
ifcvsl = -1
call field_set_key_int(ivarfl(isca(iscal)), kivisl, ifcvsl)
endif
enddo
! --- Variable density field id (ifcvsl>=0) or bulk
! density (ifcvsl=-1) for USER scalars.
! field_get_key_int(ivarfl(isca(iscal)), kromsl, ifcvsl)
! may allow sharing a density between multiple scalars.
! scalar, the density of the variance of a scalar is assumed to
! have the same behavior as the density of this scalar,
! Caution: complete cs_user_physical_properties with the law defining the density
ifcvsl = -1
call field_set_key_int(ivarfl(isca(iscal)), kromsl, ifcvsl)
endif
enddo
! --- Turbulent flux model u'T' for the scalar T
! Algebraic Model
! 0 SGDH
! 10 GGDH
! 11 EB-GGDH (Elliptic Blending)
! 20 AFM
! 21 EB-AFM (Elliptic Blending)
! Model with transport equations
! 30 DFM
! 31 EB-DFM (Elliptic Blending)
call field_get_key_id('turbulent_flux_model', kturt)
! GGDH for thermal scalar:
turb_flux_model = 10
call field_set_key_int(ivarfl(isca(iscalt)), kturt, turb_flux_model)
endif
! GGDH for all the scalars:
do jj = 1, nscaus
call field_set_key_int(ivarfl(isca(jj)), kturt, turb_flux_model)
enddo
! Error estimators for Navier-Stokes (non-frozen velocity field)
! We recommend running a calculation restart on a few time steps
! with the activation of the most interesting of those.
! (=2 to activate, =0 to deactivate).
iescal(iescor) = 2 ! div(rho u) -Gamma
iescal(iestot) = 2 ! resolution precision for the momentum
! ALE (Arbitrary Lagrangian Eulerian) related options
! Number of iterations for fluid initialization. Contrary to ntmabs,
! nalinf is not an absolute iteration number, meaning that in case of
! restart calculation nalinf corresponds to the number of iterations
! for fuid initialization beginning from the first current iteration of
! the calculation restart. In general nalinf = 0 in that case.
nalinf = 75
! Maximum number of iterations in case of implicit Fluid Structure Coupling
! with structural calculations (internal and/or external
! (i.e. using code_aster)).
! nalimx = 1, in case of explicit FSI algorithm.
nalimx = 15
! Relative precision of sub-cycling Fluid Structure Coupling algorithm.
epalim = 1.d-5
Specific physic activation (usppmo)
The usppmo routine can be found in the cs_user_parameters.f90 file.
! 1. Choice for a specific physics
! --- cod3p: Diffusion flame with complete fast chemistry (3 points)
! if = -1 module not activated
! if = 0 adiabatic model
! if = 1 extended model with enthalpy source term
ippmod(icod3p) = -1
! --- coebu: Eddy-Break Up pre-mixed flame
! if = 0 reference Spalding model
! (adiabatic, homogeneous mixture fraction)
! (homogeneous mixture fraction : perfect premix)
! if = 2 extended model with mixture fraction transport
! (adiabatic, no variance of mixture fraction)
! if = 3 extended model with enthalpy and mixture fraction transport
! (dilution, thermal losses, etc.)
ippmod(icoebu) = -1
! --- colwc: Libby-Williams pre-mixed flame
! if = 0 reference two-peak model with adiabatic condition
! if = 1 extended two-peak model with enthapy source terms
! if = 2 extended three-peak model, adiabatic
! if = 3 extended three-peak model with enthalpy source terms
! if = 4 extended four-peak model, adiabatic
! if = 5 extended four-peak model with enthalpy source terms
ippmod(icolwc) = -1
! --- Soot model
! if = 0 constant soot yield
! if = 1 2 equations model of Moss et al.
isoot = 0
xsoot = 0.1d0 ! (if isoot = 0 and only if the soot yield is not
! defined in the thermochemistry data file)
rosoot = 2000.d0 ! kg/m3
! --- cfuel: Heavy fuel oil combustion
! Progressive evaporation (temperature gap)
! Char residue
! Sulphur tracking
! if = 0 module activated
ippmod(icfuel) = -1
! --- coal :
! Pulverized coal combustion
! Description of granulometry
! Assumption of diffusion flame around particles
! (extension of 3-point fast chemistry "D3P")
! Between a mixture of gaseous fuels (volatiles matters, CO from char
! oxydation)
! and a mixture of oxidisers (air and water vapor)
! Enthalpy for both mix and solid phase are solved
! if = 1 with drying
ippmod(iccoal) = -1
! Activate the drift: 0 (no activation),
! 1 (transported particle velocity)
! 2 (limit drop particle velocity)
i_comb_drift = 1
! --- cpl3c: Pulverized coal with Lagrangian reciprocal approach
! Not recently tested... at least outdated, may be obsolete
! if = 1 with drying (NOT functional)
ippmod(icpl3c) = -1
! --- eljou: Joule effect
! if = 1 real potential
! if = 2 complex potential
! if = 3 real potential + Transfo
! if = 4 complex potential + Transfo
ippmod(ieljou) = -1
! --- elarc: Electric arcs
! if = 1 electric potential
! if = 2 electric potential and vector potential (hence 3D modelling)
ippmod(ielarc) = -1
! --- aeros: Cooling towers
! if = 0 no model (NOT functional)
! if = 1 Poppe's model
! if = 2 Merkel's model
ippmod(iaeros) = -1
! --- igmix: Gas mixtures modelling
! if =-1 module not activated
! if = 0 Air/Helium gas mixtures
! if = 1 Air/Hydrogen gas mixtures
! if = 2 Air/Steam gas mixtures
! if = 3 Air/Helium/Steam gas mixtures
! if = 4 Air/Hydrogen/Steam gas mixtures
ippmod(igmix) = 0
! Radiative transfer module (iirayo)
! if = 0: not activated (Default)
! if = 1: DOM
! if = 2: approximation P1 method
iirayo = 1
! --- richards model
! if = 1 module activated
ippmod(idarcy) = -1
! 2. Specific options related to herebefore modules
! These options are defined here at the moment, this might change in the future
! --- Enthalpy-Temperature conversion law (for gas combustion modelling)
! if = 0 user-specified
! if = 1 tabulated by JANAF (default)
indjon = 1
! 2. Data file related to modules above
! Combustion
if ( ippmod(icod3p).ge.0 &
.or. ippmod(icoebu).ge.0 .or. ippmod(icolwc).ge.0) then
if (indjon.eq.1) then
ficfpp = 'dp_C3P'
else
ficfpp = 'dp_C3PSJ'
endif
endif
! Fuel combustion
if (ippmod(icfuel).ge.0) then
ficfpp = 'dp_FUE'
endif
if (ippmod(igmix).ge.0) then
! Specific condensation modelling
! wall condensation
! if = 0 condensation source terms activated
icondb = -1
! internal condensation
! if = 0 condensation source terms with metal
! structures activate
icondv = -1
endif
Additional input of parameters (usipph)
The usipph routine can be found in the cs_user_parameters.f90 file.
Calculation options for the atmospheric module (usati1)
The usati1 routine can be found in the cs_user_parameters.f90 file.
! Atmospheric imbrication on large scale meteo (atimbr module)
! activation flag
imbrication_flag = .false.
imbrication_verbose = .false.
! flags for activating the cressman interpolation for the boundary conditions
cressman_u = .true.
cressman_v = .true.
cressman_tke = .true.
cressman_eps = .true.
cressman_theta = .true.
cressman_qw = .true.
cressman_nc = .true.
! numerical parameters for the cressman interpolation formulas
horizontal_influence_radius = 8500.d0
vertical_influence_radius = 100.d0
! ifilechemistry: choice to read (=1,2,3,4, according to the scheme)
! or not (0) a concentration profile file
! if ichemistry>0 ifilechemistry is automaticaly set to ichemistry
ifilechemistry = 0
! isepchemistry: splitted (=1) or semi-coupled (=2, pu-sun)
! resolution of chemistry.
! Splitted (=1) mandatory for aerosols.
! Semi-coupled (=2) by default.
isepchemistry = 1
! dtchemmax: maximal time step (s) for chemistry resolution
dtchemmax = 10.0d0
! computation / storage of downward and upward infrared radiative fluxes
irdu = 1
Calculation options for the combustion module (cs_user_combustion)
The cs_user_combustion routine can be found in the cs_user_parameters.f90 file.
! 1. Additional Calculation Options
! --- Kinetic model for CO <=> CO2
! if = 0 unused (maximal conversion in turbulent model)
! if = 1 transport of CO2 mass fraction
! if = 2 transport of CO mass fraction (coal and fuel only)
ieqco2 = 0
! --- Density Relaxation
! RHO(n+1) = SRROM * RHO(n) + (1-SRROM) * RHO(n+1)
srrom = 0.8d0
! 2. Physical Constants
! diftl0: Dynamic Diffusion Coefficient (kg/(m s))
diftl0 = 4.25d-5
! 2.1 For 3 points combusution model ONLY
! Reference temperature for fuel and oxydant (K)
tinfue = 436.d0
tinoxy = 353.d0
! 2.2 For EBU-model ONLY
! cebu: EBU-model constant
cebu = 2.5d0
! 2.3 For Libby-Williams model ONLY
! Reference velocity
vref = 60.d0
! Reference length scale
lref = 0.1d0
! Activation Temperature
ta = 0.2d5
! Cross-over Temperature (combustion of propane)
tstar= 0.12d4
Non-standard options for the compressible module (uscfx1)
The uscfx1 routine can be found in the cs_user_parameters.f90 file.
! 1. Properties options
! --> Molecular thermal conductivity
! constant : ifcvsl = -1
! variable : ifcvsl = 0
ifcvsl = -1
! --> Volumetric molecular viscosity
! iviscv = -1 : uniform in space and constant in time
! = 0 : variable in space and time
iviscv = -1
Non-standard options for the compressible module (uscfx2)
The uscfx2 routine can be found in the cs_user_parameters.f90 file.
! 1. Physical properties
! --> Molecular viscosity
! constant : ivivar = 0
! variable : ivivar = 1
ivivar = 0
! --> Reference molecular thermal conductivity
! visls0 = lambda0 (molecular thermal conductivity, W/(m K))
! Reference conductivity must be strictly positive
! (set a realistic value here even if conductivity is variable)
call field_set_key_double(ivarfl(isca(itempk)), kvisl0, 3.d-2)
! If the molecular thermal conductivity is variable, its values
! must be provided in the user subroutine 'cs_user_physical_properties'
! Reference volumetric molecular viscosity
! viscv0 = kappa0 (volumetric molecular viscosity, kg/(m s))
viscv0 = 0.d0
! If the volumetric molecular viscosity is variable, its values
! --> Molar mass of the gas (kg/mol)
! For example with dry air, xmasml is around 28.8d-3 kg/mol
xmasmr = 0.028966
! --> Hydrostatic equilibrium
! Specify if the hydrostatic equilibrium must be accounted for
! (yes = 1 , no = 0)
icfgrp = 1
Definition of cooling tower model and exchange zones (uscti1)
The uscti1 routine can be found in the cs_user_parameters.f90 file.
Calculation options for the Darcy module (user_darcy_ini1)
The user_darcy_ini1 routine can be found in the cs_user_parameters.f90 file.
darcy_anisotropic_permeability = 0 ! permeability : 0 isotrop, 1 anisotrop
darcy_anisotropic_dispersion = 0 ! dispersion : 0 isotrop, 1 anisotrop
darcy_unsteady = 0 ! 0 steady flow, 1 unsteady flow
darcy_convergence_criterion = 0 ! convergence criterion of Newton scheme:
! 0, over pressure, 1, over velocity
darcy_gravity = 0 ! gravity is taken into account : 0 no, 1 yes
