cs_hho_vecteq.h File Reference
#include "cs_cdo_connect.h"
#include "cs_cdo_local.h"
#include "cs_equation_common.h"
#include "cs_hho_builder.h"
#include "cs_matrix.h"
#include "cs_matrix_assembler.h"
#include "cs_restart.h"
#include "cs_source_term.h"
#include "cs_time_step.h"
+ Include dependency graph for cs_hho_vecteq.h:
void cs_hho_vecteq_init_common (cs_flag_t scheme_flag, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step, const cs_matrix_structure_t *ms0, const cs_matrix_structure_t *ms1, const cs_matrix_structure_t *ms2)
 Allocate work buffer and general structures related to HHO schemes Set shared pointers. More...
void cs_hho_vecteq_get (cs_cell_sys_t **csys, cs_cell_builder_t **cb, cs_hho_builder_t **hhob)
void cs_hho_vecteq_finalize_common (void)
 Free buffers and generic structures related to HHO schemes. More...
void * cs_hho_vecteq_init_context (const cs_equation_param_t *eqp, int var_id, int bflux_id, cs_equation_builder_t *eqb)
 Initialize a cs_hho_vecteq_t structure storing data useful for managing such a scheme. More...
void * cs_hho_vecteq_free_context (void *data)
 Destroy a cs_hho_vecteq_t structure. More...
void cs_hho_vecteq_init_values (cs_real_t t_eval, const int field_id, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
 Set the initial values of the variable field taking into account the boundary conditions. Case of vector-valued HHO schemes. More...
void cs_hho_vecteq_compute_source (const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data)
 Compute the contributions of source terms (store inside builder) More...
void cs_hho_vecteq_initialize_system (const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data, cs_matrix_t **system_matrix, cs_real_t **system_rhs)
 Create the matrix of the current algebraic system. Allocate and initialize the right-hand side associated to the given data structure. More...
void cs_hho_vecteq_build_system (const cs_mesh_t *mesh, const cs_real_t *field_val, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data, cs_real_t *rhs, cs_matrix_t *matrix)
 Build the linear system arising from a scalar convection/diffusion equation with a HHO scheme. One works cellwise and then process to the assembly. More...
void cs_hho_vecteq_update_field (const cs_real_t *solu, const cs_real_t *rhs, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data, cs_real_t *field_val)
 Store solution(s) of the linear system into a field structure Update extra-field values required for hybrid discretization. More...
cs_real_tcs_hho_vecteq_get_face_values (void *data, bool previous)
 Get the computed values at faces (DoF used in the linear system are located at primal faces) More...
cs_real_tcs_hho_vecteq_get_cell_values (void *data, bool previous)
 Get the computed values at cells (DoF used in the linear system are located at primal faces) More...
void cs_hho_vecteq_read_restart (cs_restart_t *restart, const char *eqname, void *scheme_context)
void cs_hho_vecteq_write_restart (cs_restart_t *restart, const char *eqname, void *scheme_context)
void cs_hho_vecteq_extra_post (const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
◆ cs_hho_vecteq_build_system()
void cs_hho_vecteq_build_system ( const cs_mesh_t mesh,
const cs_real_t field_val,
const cs_equation_param_t eqp,
cs_equation_builder_t eqb,
void *  data,
cs_real_t rhs,
cs_matrix_t matrix
[in]field_valpointer to the current value of the field
[in,out]datapointer to cs_hho_vecteq_t structure
[in,out]rhsright-hand side
[in,out]matrixpointer to cs_matrix_t structure to compute
◆ cs_hho_vecteq_compute_source()
void cs_hho_vecteq_compute_source ( const cs_equation_param_t eqp,
void *  data
[in,out]datapointer to a cs_hho_vecteq_t structure
◆ cs_hho_vecteq_extra_post()
void cs_hho_vecteq_extra_post ( const cs_equation_param_t eqp,
void *  context
[in,out]contextpointer to cs_hho_vecteq_t structure
◆ cs_hho_vecteq_finalize_common()
void cs_hho_vecteq_finalize_common ( void  )
◆ cs_hho_vecteq_free_context()
void* cs_hho_vecteq_free_context ( void *  data)
a NULL pointer
◆ cs_hho_vecteq_get()
void cs_hho_vecteq_get ( cs_cell_sys_t **  csys,
cs_cell_builder_t **  cb,
cs_hho_builder_t **  hhob
[out]hhobpointer to a pointer on a cs_hho_builder_t structure
◆ cs_hho_vecteq_get_cell_values()
cs_real_t* cs_hho_vecteq_get_cell_values ( void *  data,
bool  previous
[in,out]datapointer to a data structure cast-on-fly
a pointer to an array of cs_real_t
◆ cs_hho_vecteq_get_face_values()
cs_real_t* cs_hho_vecteq_get_face_values ( void *  data,
bool  previous
◆ cs_hho_vecteq_init_common()
void cs_hho_vecteq_init_common ( cs_flag_t  scheme_flag,
const cs_time_step_t time_step,
const cs_matrix_structure_t ms0,
const cs_matrix_structure_t ms1,
const cs_matrix_structure_t ms2
[in]scheme_flagflag to identify which kind of numerical scheme is requested to solve the computational domain
[in]quantpointer to a cs_cdo_quantities_t struct.
[in]time_steppointer to a cs_time_step_t struct.
[in]ms0pointer to a cs_matrix_structure_t struct. (P0)
[in]ms1pointer to a cs_matrix_structure_t struct. (P1)
[in]ms2pointer to a cs_matrix_structure_t struct. (P2)
◆ cs_hho_vecteq_init_context()
void* cs_hho_vecteq_init_context ( const cs_equation_param_t eqp,
int  var_id,
int  bflux_id,
a pointer to a new allocated cs_hho_vecteq_t structure
◆ cs_hho_vecteq_init_values()
void cs_hho_vecteq_init_values ( cs_real_t  t_eval,
const int  field_id,
void *  context
◆ cs_hho_vecteq_initialize_system()
void cs_hho_vecteq_initialize_system ( const cs_equation_param_t eqp,
void *  data,
cs_matrix_t **  system_matrix,
cs_real_t **  system_rhs
[in,out]datapointer to generic data structure
[in,out]system_matrixpointer of pointer to a cs_matrix_t struct.
[in,out]system_rhspointer of pointer to an array of cs_real_t
◆ cs_hho_vecteq_read_restart()
void cs_hho_vecteq_read_restart ( cs_restart_t restart,
const char *  eqname,
void *  scheme_context
◆ cs_hho_vecteq_update_field()
void cs_hho_vecteq_update_field ( const cs_real_t solu,
const cs_real_t rhs,
void *  data,
cs_real_t field_val
[in]solusolution array
[in]rhsrhs associated to this solution array
[in,out]field_valpointer to the current value of the field
◆ cs_hho_vecteq_write_restart()
void cs_hho_vecteq_write_restart ( cs_restart_t restart,
