cs_gwf.h File Reference
#include "cs_equation.h"
#include "cs_gwf_soil.h"
#include "cs_gwf_tracer.h"
+ Include dependency graph for cs_gwf.h:
Macros
#define CS_GWF_ADV_FIELD_NAME   "darcy_velocity"
Flags specifying the kind of post-processing to perform in
   the groundwater flow module
#define CS_GWF_POST_CAPACITY   (1 << 0)
 Activate the post-processing of the capacity (property in front of the unsteady term in Richards equation) More...
#define CS_GWF_POST_MOISTURE   (1 << 1)
 Activate the post-processing of the moisture content. More...
#define CS_GWF_POST_PERMEABILITY   (1 << 2)
 Activate the post-processing of the permeability field. More...
#define CS_GWF_POST_DARCY_FLUX_BALANCE   (1 << 3)
 Compute the overall balance at the different boundaries of the Darcy flux. More...
#define CS_GWF_POST_DARCY_FLUX_DIVERGENCE   (1 << 4)
 Compute in each control volume (vertices or cells w.r.t the space scheme) the divergence of the Darcy flux. More...
#define CS_GWF_POST_DARCY_FLUX_AT_BOUNDARY   (1 << 5)
 Define a field at boundary faces for the Darcy flux and activate the post-processing. More...
Typedefs
typedef cs_flag_t cs_gwf_model_t
Enumerations
Flags specifying the general behavior of the groundwater flow module
enum  cs_gwf_model_bit_t {
  CS_GWF_GRAVITATION = 1<< 0, CS_GWF_RICHARDS_UNSTEADY = 1<< 1, CS_GWF_SOIL_PROPERTY_UNSTEADY = 1<< 2, CS_GWF_SOIL_ALL_SATURATED = 1<< 3,
  CS_GWF_FORCE_RICHARDS_ITERATIONS = 1<< 6, CS_GWF_RESCALE_HEAD_TO_ZERO_MEAN_VALUE = 1<< 7, CS_GWF_ENFORCE_DIVERGENCE_FREE = 1<< 8
 elemental modelling choice either from the physical viewpoint or the numerical viewpoint More...
bool cs_gwf_is_activated (void)
 Check if the groundwater flow module has been activated. More...
cs_gwf_t * cs_gwf_activate (cs_property_type_t pty_type, cs_flag_t flag)
 Initialize the module dedicated to groundwater flows. More...
cs_gwf_t * cs_gwf_destroy_all (void)
 Free the main structure related to groundwater flows. More...
void cs_gwf_log_setup (void)
 Summary of the main cs_gwf_t structure. More...
void cs_gwf_set_post_options (cs_flag_t post_flag)
 Set the flag dedicated to the post-processing of the GWF module. More...
cs_gwf_tracer_t * cs_gwf_add_tracer (cs_gwf_tracer_model_t model, const char *eq_name, const char *var_name)
 Add a new equation related to the groundwater flow module This equation is a particular type of unsteady advection-diffusion reaction eq. Tracer is advected thanks to the darcian velocity and diffusion/reaction parameters result from a physical modelling. Terms solved in the equation are activated according to the settings. More...
cs_gwf_tracer_t * cs_gwf_add_user_tracer (const char *eq_name, const char *var_name, cs_gwf_tracer_setup_t *setup, cs_gwf_tracer_add_terms_t *add_terms)
 Add a new equation related to the groundwater flow module This equation is a particular type of unsteady advection-diffusion reaction eq. Tracer is advected thanks to the darcian velocity and diffusion/reaction parameters result from a physical modelling. Terms are activated according to the settings. Modelling of the tracer parameters are left to the user. More...
cs_gwf_tracer_t * cs_gwf_tracer_by_name (const char *eq_name)
 Retrieve the pointer to the cs_gwf_tracer_t structure associated to the name given as parameter. More...
void cs_gwf_init_setup (void)
 Predefined settings for the Richards equation and the related equations defining the groundwater flow module Create new cs_field_t structures according to the setting. More...
void cs_gwf_add_tracer_terms (void)
 Add new terms if needed (such as diffusion or reaction) to tracer equations according to the settings. More...
void cs_gwf_finalize_setup (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant)
 Last initialization step of the groundwater flow module. More...
void cs_gwf_update (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts, bool cur2prev)
 Update the groundwater system (pressure head, head in law, moisture content, darcian velocity, soil capacity or permeability if needed) More...
void cs_gwf_compute_steady_state (const cs_mesh_t *mesh, const cs_time_step_t *time_step, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq)
 Compute the steady-state of the groundwater flows module. Nothing is done if all equations are unsteady. More...
void cs_gwf_compute (const cs_mesh_t *mesh, const cs_time_step_t *time_step, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq)
 Compute the system related to groundwater flows module. More...
cs_real_t cs_gwf_integrate_tracer (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_gwf_tracer_t *tracer, const char *z_name)
 Compute the integral over a given set of cells of the field related to a tracer equation. This integral turns out to be exact for linear functions. More...
void cs_gwf_extra_op (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq)
 Predefined extra-operations for the groundwater flow module. More...
void cs_gwf_extra_post (void *input, int mesh_id, int cat_id, int ent_flag[5], cs_lnum_t n_cells, cs_lnum_t n_i_faces, cs_lnum_t n_b_faces, const cs_lnum_t cell_ids[], const cs_lnum_t i_face_ids[], const cs_lnum_t b_face_ids[], const cs_time_step_t *time_step)
 Predefined post-processing output for the groundwater flow module prototype of this function is fixed since it is a function pointer defined in cs_post.h (cs_post_time_mesh_dep_output_t) More...
◆ CS_GWF_ADV_FIELD_NAME
◆ CS_GWF_POST_CAPACITY
◆ CS_GWF_POST_DARCY_FLUX_AT_BOUNDARY
◆ CS_GWF_POST_DARCY_FLUX_BALANCE
◆ CS_GWF_POST_DARCY_FLUX_DIVERGENCE
◆ CS_GWF_POST_MOISTURE
◆ CS_GWF_POST_PERMEABILITY
Typedef Documentation
◆ cs_gwf_model_t
◆ cs_gwf_model_bit_t
Enumerator
CS_GWF_GRAVITATION
◆ cs_gwf_activate()
cs_gwf_t* cs_gwf_activate ( cs_property_type_t  pty_type,
cs_flag_t  flag
[in]pty_typetype of permeability (iso, ortho...)
[in]flagflag to handle this module
a pointer to a new allocated groundwater flow structure
◆ cs_gwf_add_tracer()
cs_gwf_tracer_t* cs_gwf_add_tracer ( cs_gwf_tracer_model_t  model,
const char *  eq_name,
const char *  var_name
[in]modelphysical modelling to consider (0 = default settings)
[in]eq_namename of the tracer equation
[in]var_namename of the related variable
◆ cs_gwf_add_tracer_terms()
void cs_gwf_add_tracer_terms ( void  )
◆ cs_gwf_add_user_tracer()
cs_gwf_tracer_t* cs_gwf_add_user_tracer ( const char *  eq_name,
const char *  var_name,
cs_gwf_tracer_setup_t setup,
cs_gwf_tracer_add_terms_t add_terms
[in]setupfunction pointer (predefined prototype)
[in]add_termsfunction pointer (predefined prototype)
◆ cs_gwf_compute()
void cs_gwf_compute ( const cs_mesh_t mesh,
const cs_time_step_t time_step,
const cs_cdo_quantities_t cdoq
◆ cs_gwf_compute_steady_state()
void cs_gwf_compute_steady_state ( const cs_mesh_t mesh,
◆ cs_gwf_destroy_all()
cs_gwf_t* cs_gwf_destroy_all ( void  )
a NULL pointer
◆ cs_gwf_extra_op()
void cs_gwf_extra_op ( const cs_cdo_connect_t connect,
◆ cs_gwf_extra_post()
void cs_gwf_extra_post ( void *  input,
int  mesh_id,
int  cat_id,
int  ent_flag[5],
cs_lnum_t  n_cells,
[in,out]inputpointer to a optional structure (here a cs_gwf_t structure)
[in]mesh_idid of the output mesh for the current call
[in]cat_idcategory id of the output mesh for this call
[in]ent_flagindicate global presence of cells (ent_flag[0]), interior faces (ent_flag[1]), boundary faces (ent_flag[2]), particles (ent_flag[3]) or probes (ent_flag[4])
[in]n_cellslocal number of cells of post_mesh
[in]n_i_faceslocal number of interior faces of post_mesh
[in]n_b_faceslocal number of boundary faces of post_mesh
[in]cell_idslist of cells (0 to n-1)
[in]i_face_idslist of interior faces (0 to n-1)
[in]b_face_idslist of boundary faces (0 to n-1)
[in]time_steppointer to a cs_time_step_t struct.
◆ cs_gwf_finalize_setup()
void cs_gwf_finalize_setup ( const cs_cdo_connect_t connect,
const cs_cdo_quantities_t quant
◆ cs_gwf_init_setup()
void cs_gwf_init_setup ( void  )
◆ cs_gwf_integrate_tracer()
cs_real_t cs_gwf_integrate_tracer ( const cs_cdo_connect_t connect,
const cs_cdo_quantities_t cdoq,
const cs_gwf_tracer_t *  tracer,
const char *  z_name
[in]tracerpointer to a cs_gwf_tracer_t structure
[in]z_namename of the volumic zone where the integral is done (if NULL or "" all cells are considered)
the value of the integral
◆ cs_gwf_is_activated()
bool cs_gwf_is_activated ( void  )
true or false
◆ cs_gwf_log_setup()
void cs_gwf_log_setup ( void  )
◆ cs_gwf_set_post_options()
void cs_gwf_set_post_options ( cs_flag_t  post_flag)
[in]post_flagflag to set
◆ cs_gwf_tracer_by_name()
cs_gwf_tracer_t* cs_gwf_tracer_by_name ( const char *  eq_name)
the pointer to a cs_gwf_tracer_t structure
◆ cs_gwf_update()
void cs_gwf_update ( const cs_mesh_t mesh,
const cs_time_step_t ts,
bool  cur2prev
[in]tspointer to a cs_time_step_t structure
[in]cur2prevtrue or false
