47 #define CS_GWF_ADV_FIELD_NAME "darcy_velocity" 138 #define CS_GWF_POST_CAPACITY (1 << 0) 139 #define CS_GWF_POST_MOISTURE (1 << 1) 140 #define CS_GWF_POST_PERMEABILITY (1 << 2) 141 #define CS_GWF_POST_DARCY_FLUX_BALANCE (1 << 3) 142 #define CS_GWF_POST_DARCY_FLUX_DIVERGENCE (1 << 4) 143 #define CS_GWF_POST_DARCY_FLUX_AT_BOUNDARY (1 << 5) 151 typedef struct _gwf_t cs_gwf_t;
232 const char *var_name);
253 const char *var_name,
379 const cs_gwf_tracer_t *tracer,
void cs_gwf_init_setup(void)
Predefined settings for the Richards equation and the related equations defining the groundwater flow...
Definition: cs_gwf.c:937
time step descriptor
Definition: cs_time_step.h:64
void cs_gwf_extra_op(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq)
Predefined extra-operations for the groundwater flow module.
Definition: cs_gwf.c:1612
cs_gwf_tracer_t * cs_gwf_add_tracer(cs_gwf_tracer_model_t model, const char *eq_name, const char *var_name)
Add a new equation related to the groundwater flow module This equation is a particular type of unste...
Definition: cs_gwf.c:814
void cs_gwf_log_setup(void)
Summary of the main cs_gwf_t structure.
Definition: cs_gwf.c:707
void cs_gwf_compute_steady_state(const cs_mesh_t *mesh, const cs_time_step_t *time_step, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq)
Compute the steady-state of the groundwater flows module. Nothing is done if all equations are unstea...
Definition: cs_gwf.c:1353
cs_gwf_t * cs_gwf_activate(cs_property_type_t pty_type, cs_flag_t flag)
Initialize the module dedicated to groundwater flows.
Definition: cs_gwf.c:606
Definition: cs_gwf_tracer.h:47
Definition: cs_defs.h:495
cs_real_t cs_gwf_integrate_tracer(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_gwf_tracer_t *tracer, const char *z_name)
Compute the integral over a given set of cells of the field related to a tracer equation. This integral turns out to be exact for linear functions.
Definition: cs_gwf.c:1514
void() cs_gwf_tracer_setup_t(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_gwf_tracer_t *tracer)
Generic function to set the parameters related to a tracer equation.
Definition: cs_gwf_tracer.h:238
Definition: cs_defs.h:307
void cs_gwf_finalize_setup(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant)
Last initialization step of the groundwater flow module.
Definition: cs_gwf.c:1104
void cs_gwf_set_post_options(cs_flag_t post_flag)
Set the flag dedicated to the post-processing of the GWF module.
Definition: cs_gwf.c:786
bool cs_gwf_is_activated(void)
Check if the groundwater flow module has been activated.
Definition: cs_gwf.c:586
void cs_gwf_compute(const cs_mesh_t *mesh, const cs_time_step_t *time_step, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq)
Compute the system related to groundwater flows module.
Definition: cs_gwf.c:1429
void cs_gwf_update(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts, bool cur2prev)
Update the groundwater system (pressure head, head in law, moisture content, darcian velocity...
Definition: cs_gwf.c:1259
cs_gwf_tracer_t * cs_gwf_add_user_tracer(const char *eq_name, const char *var_name, cs_gwf_tracer_setup_t *setup, cs_gwf_tracer_add_terms_t *add_terms)
Definition: cs_gwf.c:866
Definition: cs_defs.h:301
cs_gwf_model_bit_t
elemental modelling choice either from the physical viewpoint or the numerical viewpoint ...
Definition: cs_gwf.h:89
Definition: cs_defs.h:496
unsigned short int cs_flag_t
Definition: cs_defs.h:309
void cs_gwf_extra_post(void *input, int mesh_id, int cat_id, int ent_flag[5], cs_lnum_t n_cells, cs_lnum_t n_i_faces, cs_lnum_t n_b_faces, const cs_lnum_t cell_ids[], const cs_lnum_t i_face_ids[], const cs_lnum_t b_face_ids[], const cs_time_step_t *time_step)
Predefined post-processing output for the groundwater flow module prototype of this function is fixed...
Definition: cs_gwf.c:1758
cs_flag_t cs_property_type_t
Definition: cs_property.h:102
void cs_gwf_add_tracer_terms(void)
Add new terms if needed (such as diffusion or reaction) to tracer equations according to the settings...
Definition: cs_gwf.c:1076
cs_gwf_t * cs_gwf_destroy_all(void)
Free the main structure related to groundwater flows.
Definition: cs_gwf.c:668
cs_flag_t cs_gwf_model_t
Definition: cs_gwf.h:49
void() cs_gwf_tracer_add_terms_t(cs_gwf_tracer_t *tracer)
Generic function to update the terms to build in the algebraic system for a tracer equation according...
Definition: cs_gwf_tracer.h:252
cs_gwf_tracer_t * cs_gwf_tracer_by_name(const char *eq_name)
Retrieve the pointer to the cs_gwf_tracer_t structure associated to the name given as parameter...
Definition: cs_gwf.c:909
