struct | cs_gwf_tracer_input_t |
struct | cs_gwf_tracer_t |
typedef cs_flag_t | cs_gwf_tracer_model_t |
typedef void() | cs_gwf_tracer_update_t(cs_gwf_tracer_t *tracer, cs_real_t t_eval, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant) |
Generic function to update the phisical properties related to a tracer modelling. More... | |
typedef void() | cs_gwf_tracer_free_input_t(cs_gwf_tracer_t *tracer) |
Generic function to free the input of a tracer model. More... | |
typedef void() | cs_gwf_tracer_setup_t(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_gwf_tracer_t *tracer) |
Generic function to set the parameters related to a tracer equation. More... | |
typedef void() | cs_gwf_tracer_add_terms_t(cs_gwf_tracer_t *tracer) |
Generic function to update the terms to build in the algebraic system for a tracer equation according to the settings. More... | |
Enumerations | |
Flags specifying the general behavior of a tracer associated to | |
the groundwater flow module | |
enum | cs_gwf_tracer_model_bit_t { CS_GWF_TRACER_USER = 1<< 0, CS_GWF_TRACER_SORPTION_EK_3_PARAMETERS = 1<< 1, CS_GWF_TRACER_SORPTION_EK_5_PARAMETERS = 1<< 2, CS_GWF_TRACER_PRECIPITATION = 1<< 4 } |
elemental modelling choice either from the physical viewpoint or the numerical viewpoint for the transport of a tracer More... | |
cs_gwf_tracer_t * | cs_gwf_tracer_init (int tracer_id, const char *eq_name, const char *var_name, cs_adv_field_t *adv_field, cs_gwf_tracer_model_t model) |
Create a new cs_gwf_tracer_t structure and initialize its members by default. Add a new equation related to the groundwater flow module. This equation is a specific transport equation. Tracer is advected thanks to the darcian velocity which is given by the resolution of the Richards equation. Diffusion/reaction parameters result from a physical modelling. More... | |
cs_gwf_tracer_t * | cs_gwf_tracer_free (cs_gwf_tracer_t *tracer) |
Free a cs_gwf_tracer_t structure. More... | |
void | cs_gwf_set_main_tracer_param (cs_gwf_tracer_t *tracer, const char *soil_name, double wmd, double alpha_l, double alpha_t, double distrib_coef, double reaction_rate) |
For a specified soil set the main parameters corresponding to a default modelling of a tracer transport. More... | |
void | cs_gwf_set_precip_tracer_param (cs_gwf_tracer_t *tracer, const char *soil_name, double conc_w_star) |
For a specified soil set the parameters corresponding to a precipitation modelling of a tracer transport. More... | |
void | cs_gwf_tracer_add_terms (cs_gwf_tracer_t *tracer) |
Add terms to the algebraic system related to a tracer equation according to the settings. Case of the standard tracer modelling Rely on the generic function: cs_gwf_tracer_add_terms_t. More... | |
void | cs_gwf_tracer_setup (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_gwf_tracer_t *tracer) |
Set the parameters related to a standard tracer equation. More... | |
void | cs_gwf_tracer_log_setup (const cs_gwf_tracer_t *tracer) |
Display the main features related to a tracer. More... | |
typedef void() cs_gwf_tracer_add_terms_t(cs_gwf_tracer_t *tracer) |
[in,out] | tracer | pointer to a cs_gwf_tracer_t structure |
typedef void() cs_gwf_tracer_free_input_t(cs_gwf_tracer_t *tracer) |
[in,out] | tracer | pointer to a structure cs_gwf_tracer_t |
typedef cs_flag_t cs_gwf_tracer_model_t |
typedef void() cs_gwf_tracer_setup_t(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_gwf_tracer_t *tracer) |
[in] | connect | pointer to a cs_cdo_connect_t structure |
[in] | quant | pointer to a cs_cdo_quantities_t structure |
typedef void() cs_gwf_tracer_update_t(cs_gwf_tracer_t *tracer, cs_real_t t_eval, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant) |
[in,out] | tracer | pointer to a cs_gwf_tracer_structure |
[in] | t_eval | time at which one performs the evaluation |
[in] | mesh | pointer to a cs_mesh_t structure |
void cs_gwf_set_main_tracer_param | ( | cs_gwf_tracer_t * | tracer, |
const char * | soil_name, | ||
double | wmd, | ||
double | alpha_l, | ||
double | alpha_t, | ||
double | distrib_coef, | ||
double | reaction_rate | ||
[in] | soil_name | name of the related soil (or NULL if all soils are selected) |
[in] | wmd | value of the water molecular diffusivity |
[in] | alpha_l | value of the longitudinal dispersivity |
[in] | alpha_t | value of the transversal dispersivity |
[in] | distrib_coef | value of the distribution coefficient |
[in] | reaction_rate | value of the first order rate of reaction |
void cs_gwf_set_precip_tracer_param | ( | cs_gwf_tracer_t * | tracer, |
double | conc_w_star | ||
[in] | conc_w_star | value of the saturated concentration in the liquid phase |
void cs_gwf_tracer_add_terms | ( | cs_gwf_tracer_t * | tracer | ) |
cs_gwf_tracer_t* cs_gwf_tracer_free | ( | cs_gwf_tracer_t * | tracer | ) |
cs_gwf_tracer_t* cs_gwf_tracer_init | ( | int | tracer_id, |
const char * | eq_name, | ||
const char * | var_name, | ||
cs_adv_field_t * | adv_field, | ||
cs_gwf_tracer_model_t | model | ||
[in] | tracer_id | id number of the soil |
[in] | eq_name | name of the tracer equation |
[in] | var_name | name of the related variable |
[in] | adv_field | pointer to a cs_adv_field_t structure |
[in] | model | model related to this tracer |
void cs_gwf_tracer_log_setup | ( | const cs_gwf_tracer_t * | tracer | ) |
[in] | tracer | pointer to a cs_gwf_tracer_t structure |
void cs_gwf_tracer_setup | ( | const cs_cdo_connect_t * | connect, |
const cs_cdo_quantities_t * | quant, | ||
cs_gwf_tracer_t * | tracer | ||
