#include "cs_boundary_conditions.h"
#include "cs_boundary_zone.h"
#include "cs_cell_to_vertex.h"
#include "cs_cdo_connect.h"
#include "cs_cdo_main.h"
#include "cs_domain.h"
#include "cs_domain_setup.h"
#include "cs_equation.h"
#include "cs_equation_iterative_solve.h"
#include "cs_face_viscosity.h"
#include "cs_field_pointer.h"
#include "cs_gui_mobile_mesh.h"
#include "cs_interface.h"
#include "cs_math.h"
#include "cs_mesh_bad_cells.h"
#include "cs_time_step.h"
#include "cs_ale.h"
void | cs_f_ale_get_pointers (int **iale) |
void | cs_ale_update_mesh_quantities (cs_real_t *min_vol, cs_real_t *max_vol, cs_real_t *tot_vol) |
Compute cell and face centers of gravity, cell volumes and update bad cells. More... | |
void | cs_ale_project_displacement (const int ale_bc_type[], const cs_real_3_t *meshv, const cs_real_33_t gradm[], const cs_real_3_t *claale, const cs_real_33_t *clbale, const cs_real_t *dt, cs_real_3_t *disp_proj) |
Project the displacement on mesh vertices (solved on cell center). More... | |
void | cs_ale_update_mesh (const int itrale) |
Update mesh in the ALE framework. More... | |
void | cs_ale_update_bcs (int *ale_bc_type, cs_real_3_t *b_fluid_vel) |
Update ALE BCs for required for the fluid. More... | |
void | cs_ale_solve_mesh_velocity (const int iterns, const int *impale, const int *ale_bc_type) |
Solve a Poisson equation on the mesh velocity in ALE framework. More... | |
void | cs_ale_activate (void) |
Activate the mesh velocity solving with CDO. More... | |
bool | cs_ale_is_activated (void) |
Test if mesh velocity solving with CDO is activated. More... | |
void | cs_ale_init_setup (cs_domain_t *domain) |
Setup the equations solving the mesh velocity. More... | |
void | cs_ale_setup_boundaries (const cs_domain_t *domain) |
void | cs_ale_finalize_setup (cs_domain_t *domain) |
Finalize the setup stage for the equation of the mesh velocity. More... | |
void | cs_ale_destroy_all (void) |
Free the main structure related to the ALE mesh velocity solving. More... | |
int | cs_glob_ale = 0 |
void cs_ale_activate | ( | void | ) |
void cs_ale_destroy_all | ( | void | ) |
void cs_ale_finalize_setup | ( | cs_domain_t * | domain | ) |
[in,out] | domain | pointer to a cs_domain_t structure |
void cs_ale_init_setup | ( | cs_domain_t * | domain | ) |
Setup the equations related to mesh deformation.
bool cs_ale_is_activated | ( | void | ) |
void cs_ale_project_displacement | ( | const int | ale_bc_type[], |
const cs_real_3_t * | meshv, | ||
const cs_real_33_t | gradm[], | ||
const cs_real_3_t * | claale, | ||
const cs_real_33_t * | clbale, | ||
const cs_real_t * | dt, | ||
cs_real_3_t * | disp_proj | ||
[in] | ale_bc_type | Type of boundary for ALE |
[in] | meshv | Mesh velocity |
[in] | gradm | Mesh velocity gradient (du_i/dx_j : gradv[][i][j]) |
[in] | claale | Boundary conditions A |
[in] | clbale | Boundary conditions B |
[in] | dt | Time step |
[out] | disp_proj | Displacement projected on vertices |
void cs_ale_setup_boundaries | ( | const cs_domain_t * | domain | ) |
[in] | domain | pointer to a cs_domain_t structure |
void cs_ale_solve_mesh_velocity | ( | const int | iterns, |
const int * | impale, | ||
const int * | ale_bc_type | ||
It also updates the mesh displacement so that it can be used to update mass fluxes (due to mesh displacement).
[in] | iterns | Navier-Stokes iteration number |
[in] | impale | Indicator for fixed node displacement |
void cs_ale_update_bcs | ( | int * | ale_bc_type, |
cs_real_3_t * | b_fluid_vel | ||
[out] | ale_bc_type | type of ALE bcs |
[out] | b_fluid_vel | Fluid velocity at boundary faces |
void cs_ale_update_mesh | ( | const int | itrale | ) |
[in] | itrale | number of the current ALE iteration |
void cs_ale_update_mesh_quantities | ( | cs_real_t * | min_vol, |
cs_real_t * | max_vol, | ||
cs_real_t * | tot_vol | ||
[out] | min_vol | Minimum cell volume |
[out] | max_vol | Maximum cell volume |
[out] | tot_vol | Total cell volume |
void cs_f_ale_get_pointers | ( | int ** | iale | ) |
int cs_glob_ale = 0 |
