cs_physical_constants.h
1 #ifndef __CS_PHYSICAL_CONSTANTS_H__
2 #define __CS_PHYSICAL_CONSTANTS_H__
5  * Base physical constants data.
31  * Local headers
34 #include "cs_defs.h"
41  * Macro definitions
45  * Type definitions
48 /* physical constants descriptor */
49 /*-------------------------------*/
50
51 typedef struct {
52
53  cs_real_3_t gravity; /* gravity vector */
54  int icorio; /* Coriolis source terms indicator */
55
57
58 /* fluid properties descriptor */
59 /*-----------------------------*/
60
61 typedef struct {
62
63  int ixyzp0; /* indicator for filling of reference point for
64  total pressure */
65  int icp; /* property index of the isobaric specific heat */
66  int icv; /* property index of the isochoric specific
67  heat */
68  int irovar; /* variable density field */
69  int ivivar; /* variable viscosity field */
70  int ivsuth; /* Sutherland law for laminar viscosity and
71  thermal conductivity in gas mix spec. phys. */
72  double ro0; /* reference density */
73  double viscl0; /* reference molecular dynamic viscosity */
74  double viscv0; /* reference volume viscosity
75  (for compressible model) */
76  double p0; /* reference pressure for the total pressure */
77  double pred0; /* reference value for the reduced pressure */
78  double xyzp0[3]; /* reference point coordinates for the total
79  pressure */
80  double t0; /* reference temperature */
81  double cp0; /* reference specific heat at constant pressure */
82  double cv0; /* reference specific heat at constant volume */
83  double lambda0; /* reference heat conductivity */
84
85  double r_pg_cnst; /* Perfect Gas R constant */
86  double rvsra; /* ratio gaz constant h2o/ dry air */
87  double clatev; /* latent heat of evaporation: */
88  double xmasmr; /* molar mass of the perfect gas in kg/mol
89  (if ieos=1) */
90  int ipthrm; /* Uniform variable thermodynamic pressure for the
91  low-Mach algorithm */
92  double pther; /* uniform thermodynamic pressure for the low-Mach
93  algorithm */
94  double pthera; /* thermodynamic pressure for the previous time
95  step */
96  double pthermax; /* thermodynamic maximum pressure for user
97  clipping, used to model a venting effect */
98  double sleak; /* Leak surface */
99  double kleak; /* Leak head loss (2.9 by default, from Idelcick) */
100  double roref; /* Initial reference density */
101
103
104 /*============================================================================
105  * Static global variables
106  *============================================================================*/
107
108 /* Physical constants */
109
110 extern const double cs_physical_constants_r; /* Ideal gas constant (J/mol/K) */
111 extern const double cs_physical_constants_kb; /* Boltzmann constant (J/K) */
112 extern const double cs_physical_constants_celsius_to_kelvin; /* Celsius to
113  Kelvin*/
114 extern const double cs_physical_constants_stephan; /* Stephan constant
115  (W/m2/K4)*/
116
117 /* Pointer to main physical constants structure */
118
120
121 /* Pointer to main fluid properties structure */
122
124
125 /*=============================================================================
126  * Public function prototypes
127  *============================================================================*/
128
129 /*----------------------------------------------------------------------------
130  * Provide access to cs_glob_physical_constants
131  *
132  * needed to initialize structure with GUI
133  *----------------------------------------------------------------------------*/
134
137
138 /*----------------------------------------------------------------------------
139  * Provide access to cs_glob_fluid_properties
140  *
141  * needed to initialize structure with GUI
142  *----------------------------------------------------------------------------*/
143
146
147 /*----------------------------------------------------------------------------
148  * Print the physical constants structure to setup.log.
149  *----------------------------------------------------------------------------*/
150
151 void
153
154 /*----------------------------------------------------------------------------
155  * Print the fluid properties structure to setup.log.
156  *----------------------------------------------------------------------------*/
157
158 void
160
161 /*----------------------------------------------------------------------------*/
162
164
165 #endif /* __CS_PHYSICAL_CONSTANTS_H__ */
Definition: cs_physical_constants.c:375
Fluid properties descriptor.
int ixyzp0
Definition: cs_physical_constants.h:63
double cp0
Definition: cs_physical_constants.h:81
cs_fluid_properties_t * cs_get_glob_fluid_properties(void)
Definition: cs_physical_constants.c:598
double clatev
Definition: cs_physical_constants.h:87
real(c_double), dimension(:), pointer, save xyzp0
coordinates of the reference point for the total pressure.
Definition: cstphy.f90:207
double sleak
Definition: cs_physical_constants.h:98
Definition: cs_defs.h:495
Definition: cs_physical_constants.c:380
double xmasmr
Definition: cs_physical_constants.h:88
double kleak
Definition: cs_physical_constants.h:99
const cs_physical_constants_t * cs_glob_physical_constants
Definition: cs_physical_constants.c:382
cs_physical_constants_t * cs_get_glob_physical_constants(void)
Definition: cs_physical_constants.c:585
double t0
Definition: cs_physical_constants.h:80
double pthermax
Definition: cs_physical_constants.h:96
double rvsra
Definition: cs_physical_constants.h:86
int icv
Definition: cs_physical_constants.h:66
void cs_fluid_properties_log_setup(void)
Definition: cs_physical_constants.c:642
Definition: cs_physical_constants.c:385
double r_pg_cnst
Definition: cs_physical_constants.h:85
int irovar
Definition: cs_physical_constants.h:68
Ideal gas constant ( )
Definition: cs_physical_constants.c:367
int icorio
Definition: cs_physical_constants.h:54
double viscv0
Definition: cs_physical_constants.h:74
double pther
Definition: cs_physical_constants.h:92
Definition: cs_physical_constants.c:371
double viscl0
Definition: cs_physical_constants.h:73
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:320
double lambda0
Definition: cs_physical_constants.h:83
void cs_physical_constants_log_setup(void)
Definition: cs_physical_constants.c:610
int icp
Definition: cs_physical_constants.h:65
double cv0
Definition: cs_physical_constants.h:82
cs_real_3_t gravity
Definition: cs_physical_constants.h:53
int ipthrm
Definition: cs_physical_constants.h:90
Definition: cs_defs.h:496
double pthera
Definition: cs_physical_constants.h:94
double p0
Definition: cs_physical_constants.h:76
Physical constants descriptor.
Definition: cs_physical_constants.h:51
int ivsuth
Definition: cs_physical_constants.h:70
int ivivar
Definition: cs_physical_constants.h:69
double roref
Definition: cs_physical_constants.h:100
double pred0
Definition: cs_physical_constants.h:77
double ro0
Definition: cs_physical_constants.h:72
