Module for physical constants
+ Collaboration diagram for Module for physical constants:
Modules
 Module for turbulence constants
double precision tkelvi
 Temperature in Kelvin correponding to 0 degrees Celsius (= +273,15) More...
double precision xcal2j
 Calories (1 cvar_al = xcal2j J) More...
double precision stephn
 Stephan constant for the radiative module $\sigma$ in $W.m^{-2}.K^{-4}$. More...
real(c_double), pointer, save rair
 Perfect gas constant for air (mixture) More...
real(c_double), pointer, save rvsra
 ratio gaz constant h2o/ dry air More...
real(c_double), pointer, save clatev
 latent heat of evaporation More...
double precision kboltz
 Boltzmann constant ( $J.K^{-1}$) More...
double precision cs_physical_constants_r
 Ideal gas constant ( $J.mol^{-1}.K^{-1}$) More...
real(c_double), pointer, save gx
 Gravity. More...
real(c_double), pointer, save gy
real(c_double), pointer, save gz
integer(c_int), pointer, save icorio
 Coriolis effects. More...
integer(c_int), pointer, save ixyzp0
 Physical constants of the fluid filling xyzp0 indicator. More...
integer(c_int), pointer, save icp
 indicates if the isobaric specific heat $C_p$ is variable: More...
integer(c_int), pointer, save icv
 isochoric specific heat $ C_v $ More...
integer(c_int), pointer, save irovar
 variable density field $ \rho $: More...
integer(c_int), pointer, save ivivar
 variable viscosity field $ \mu $: More...
integer(c_int), pointer, save ivsuth
 Sutherland law for laminar viscosity and thermal conductivity Only useful in gas mix (igmix) specific physics. More...
real(c_double), pointer, save ro0
 reference density.
More...
real(c_double), pointer, save viscl0
 reference molecular dynamic viscosity.
More...
real(c_double), pointer, save p0
 reference pressure for the total pressure.
More...
real(c_double), pointer, save pred0
 reference value for the reduced pressure $P^*$ (see ro0).
More...
real(c_double), dimension(:), pointer, save xyzp0
 coordinates of the reference point $\vect{x}_0$ for the total pressure. More...
real(c_double), pointer, save t0
 reference temperature. More...
double precision, save eint0
 Reference internal energy for the barotropic compressible module. More...
real(c_double), pointer, save cp0
 reference specific heat. More...
real(c_double), pointer, save cv0
 Reference isochoric specific heat. More...
real(c_double), pointer, save lambda0
 Reference thermal conductivity. More...
real(c_double), pointer, save xmasmr
 Molar mass of the perfect gas in $ kg/mol $ (if ieos=1) More...
integer(c_int), pointer, save ipthrm
 Uniform variable thermodynamic pressure for the low-Mach algorithm. More...
real(c_double), pointer, save pther
 Thermodynamic pressure for the current time step. More...
real(c_double), pointer, save pthera
 Thermodynamic pressure for the previous time step. More...
real(c_double), pointer, save pthermax
 pthermax: Thermodynamic maximum pressure for user clipping, used to model a venting effect More...
real(c_double), pointer, save sleak
 Leak surface. More...
real(c_double), pointer, save kleak
 Leak head loss (2.9 by default, from Idelcick) More...
real(c_double), pointer, save roref
 Initial reference density. More...
◆ clatev
◆ cp0
Useful if there is 1 <= n <= nscaus, so that iscalt = n and itherm = 1 (there is a "temperature" scalar), unless the user specifies the specific heat in the user subroutine cs_user_physical_properties (icp > 0) with the compressible module or coal combustion, cp0 is also needed even when there is no user scalar.
Note
None of the scalars from the specific physics is a temperature.
When using the Graphical Interface, cp0 is also used to calculate the diffusivity of the thermal scalars, based on their conductivity; it is therefore needed, unless the diffusivity is also specified in cs_user_physical_properties.
◆ cs_physical_constants_r
◆ cv0
Useful for the compressible module (J/kg/K)
◆ eint0
◆ gx
Gravity.
◆ gy
◆ gz
◆ icorio
Coriolis effects.
◆ icp
  • 0: constant, no property field is declared
  • 1: variable, $C_p$ is declared as a property field
    When gas or coal combustion is activated, icp is automatically set to 0 (constant $C_p$). With the electric module, it is automatically set to 1. The user is not allowed to modify these default choices.
    When icp = 1 is specified, the code automatically modifies this value to make icp designate the effective index-number of the property "specific heat". For each cell iel, the value of $C_p$ is then specified by the user in the appropriate subroutine (cs_user_physical_properties for the standard physics).
    Useful if there is 1 $\leqslant$N $\leqslant$nscal so that iscsth(n)=1 (there is a scalar temperature) or with the compressible module for non perfect gases.
◆ icv
◆ ipthrm
  • 1: true
  • 0: false
◆ irovar
◆ ivivar
◆ ivsuth
  • 1: Sutherland law
  • 0: low temperature law (linear except for helium)
◆ ixyzp0
◆ kboltz
◆ kleak
◆ lambda0
Useful with thermal model (W/m/K)
◆ p0
except with the compressible module, the total pressure $P$ is evaluated from the reduced pressure $P^*$ so that $P$ is equal to p0 at the reference position $\vect{x}_0$ (given by xyzp0). with the compressible module, the total pressure is solved directly. always Useful
◆ pred0
It is especially used to initialise the reduced pressure and as a reference value for the outlet boundary conditions. For an optimised precision in the resolution of $P^*$, it is wiser to keep pred0 to 0. With the compressible module, the "pressure" variable appearing in the equations directly represents the total pressure. It is therefore initialized to p0 and not pred0 (see ro0). Always useful, except with the compressible module
◆ pther
◆ pthera
◆ pthermax
◆ rair
◆ ro0
reference density.
Negative value: not initialized. Its value is not used in gas or coal combustion modelling (it will be calculated following the perfect gas law, with $P0$ and $T0$). With the compressible module, it is also not used by the code, but it may be (and often is) referenced by the user in user subroutines; it is therefore better to specify its value.
Always useful otherwise, even if a law defining the density is given by the user subroutines cs_user_physical_properties. indeed, except with the compressible module, CS does not use the total pressure $P$ when solving the Navier-Stokes equation, but a reduced pressure . $P^*=P-\rho_0\vect{g}.(\vect{x}-\vect{x}_0)+P^*_0-P_0$. where $\vect{x_0}$ is a reference point (see xyzp0) and $P^*_0$ and $P_0$ are reference values (see pred0 and p0). Hence, the term $-\grad{P}+\rho\vect{g}$ in the equation is treated as $-\grad{P^*}+(\rho-\rho_0)\vect{g}$. The closer ro0 is to the value of $\rho$, the more $P^*$ will tend to represent only the dynamic part of the pressure and the faster and more precise its solution will be. Whatever the value of ro0, both $P$ and $P^*$ appear in the log and the post-processing outputs.. with the compressible module, the calculation is made directly on the total pressure
◆ roref
◆ rvsra
◆ sleak
Leak surface.
◆ stephn
◆ t0
Useful for the specific physics gas or coal combustion (initialization of the density), for the electricity modules to initialize the domain temperature and for the compressible module (initializations). It must be given in Kelvin.
◆ tkelvi
◆ viscl0
Negative value: not initialized. Always useful, it is the used value unless the user specifies the viscosity in the subroutine cs_user_physical_properties
◆ xcal2j
◆ xmasmr
Always useful
◆ xyzp0
  • When there are no Dirichlet conditions for the pressure (closed domain), xyzp0 does not need to be specified (unless the total pressure has a clear physical meaning in the configuration treated).
  • When Dirichlet conditions on the pressure are specified but only through stantard outlet conditions (as it is in most configurations), xyzp0 does not need to be specified by the user, since it will be set to the coordinates of the reference outlet face (i.e. the code will automatically select a reference outlet boundary face and set xyzp0 so that $P$ equals p0 at this face). Nonetheless, if xyzp0 is specified by the user, the calculation will remain correct.
  • When direct Dirichlet conditions are specified by the user (specific value set on specific boundary faces), it is better to specify the corresponding reference point (i.e. specify where the total pressure is p0). This way, the boundary conditions for the reduced pressure will be close to pred0, ensuring an optimal precision in the resolution. If xyzp0 is not specified, the reduced pressure will be shifted, but the calculations will remain correct..
  • With the compressible module, the "pressure" variable appearing in the equations directly represents the total pressure. xyzp0 is therefore not used..
Always useful, except with the compressible module.
