cs_user_physical_properties.c File Reference
User definition of physical properties. More...
#include <ple_coupling.h>
#include "cs_headers.h"
+ Include dependency graph for cs_user_physical_properties.c:
void cs_user_physical_properties (cs_domain_t *domain)
 Function called at each time step to define physical properties. More...
void cs_user_physical_properties_h_to_t (cs_domain_t *domain, const cs_zone_t *z, bool z_local, const cs_real_t h[], cs_real_t t[])
 User definition of enthalpy to temperature conversion. More...
void cs_user_physical_properties_t_to_h (cs_domain_t *domain, const cs_zone_t *z, bool z_local, const cs_real_t t[], cs_real_t h[])
 User definition of temperature to enthalpy conversion. More...
◆ cs_user_physical_properties()
void cs_user_physical_properties ( cs_domain_t domain)
This function is called each time step to define physical properties.
◆ cs_user_physical_properties_h_to_t()
void cs_user_physical_properties_h_to_t ( cs_domain_t domain,
const cs_zone_t z,
bool  z_local,
cs_real_t  t[]
This allows overwriting the solver defaults if necessary.
This function may be called on a per-zone basis, so as to allow different conversion relations in zones representing solids or different fluids.
[in]zzone (volume or boundary) applying to current call
[in]z_localif true, h and t arrays are defined in a compact (contiguous) manner for this zone only; if false, h and t are defined on the zone's parent location (usually all cells or boundary faces)
[in]henthalpy values
[in,out]ttemperature values
◆ cs_user_physical_properties_t_to_h()
void cs_user_physical_properties_t_to_h ( cs_domain_t domain,
const cs_zone_t z,
bool  z_local,
cs_real_t  h[]
[in]htemperature values
[in,out]tenthalpy values
