| typedef struct _cs_probe_set_t | cs_probe_set_t |
| typedef void() | cs_probe_set_define_local_t(void *input, cs_lnum_t *n_elts, cs_real_3_t **coords, cs_real_t **s) |
| Function pointer to definition of probes based on rank-local points. More... | |
Enumerations | |
| enum | cs_probe_snap_t { CS_PROBE_SNAP_NONE, CS_PROBE_SNAP_ELT_CENTER, CS_PROBE_SNAP_VERTEX } |
| void | cs_probe_finalize (void) |
| Free all structures related to a set of probes. More... | |
| int | cs_probe_get_n_sets (void) |
| Retrieve the number of probe sets defined. More... | |
| cs_probe_set_t * | cs_probe_set_get (const char *name) |
| Retrieve a cs_probe_set_t structure. More... | |
| cs_probe_set_t * | cs_probe_set_get_by_id (int pset_id) |
| Retrieve a cs_probe_set_t structure from its id. More... | |
| const char * | cs_probe_set_get_name (cs_probe_set_t *pset) |
| Retrieve the name related to a cs_probe_set_t structure. More... | |
| void | cs_probe_set_get_post_info (const cs_probe_set_t *pset, bool *time_varying, bool *on_boundary, bool *on_curve, bool *auto_variables, int *n_writers, int *writer_ids[]) |
| Retrieve information useful for the postprocessing step. More... | |
| const char * | cs_probe_set_get_location_criteria (cs_probe_set_t *pset) |
| Return the location filter selection criteria string for a given probe set. More... | |
| cs_probe_set_t * | cs_probe_set_create (const char *name) |
| Create a new set of probes. More... | |
| void | cs_probe_set_add_probe (cs_probe_set_t *pset, cs_real_t x, cs_real_t y, cs_real_t z, const char *label) |
| Add a new probe to an existing set of probes. More... | |
| cs_probe_set_t * | cs_probe_set_create_from_array (const char *name, int n_probes, const cs_real_3_t *coords, const char **labels) |
| Define a new set of probes from an array of coordinates. More... | |
| cs_probe_set_t * | cs_probe_set_create_from_segment (const char *name, int n_probes, const cs_real_t start_coords[3], const cs_real_t end_coords[3]) |
| Define a new set of probes from the segment spanned by two points. More... | |
| cs_probe_set_t * | cs_probe_set_create_from_local (const char *name, cs_probe_set_define_local_t *p_define_func, void *p_define_input) |
| Define a new set of probes from rank-local definition function. More... | |
| void | cs_probe_set_allow_overwrite (const char *name) |
| allow overwriting the definition of a given probe set. More... | |
| void | cs_probe_set_associate_writers (cs_probe_set_t *pset, int n_writers, const int *writer_ids) |
| Associate a list of writers to a probe set. More... | |
| void | cs_probe_set_auto_var (cs_probe_set_t *pset, bool mode) |
| Set to true or false the automatic post-processing of variables. More... | |
| void | cs_probe_set_snap_mode (cs_probe_set_t *pset, cs_probe_snap_t snap_mode) |
| Set snap mode related to the management of a set of probes. More... | |
| void | cs_probe_set_option (cs_probe_set_t *pset, const char *keyname, const char *keyval) |
| Set optional parameters related to the management of a set of probes. More... | |
| void | cs_probe_set_locate (cs_probe_set_t *pset, const fvm_nodal_t *location_mesh) |
| Try to locate each probe and define the coordinate really used for the postprocessing step. More... | |
| fvm_nodal_t * | cs_probe_set_export_mesh (cs_probe_set_t *pset, const char *mesh_name) |
| Define a fvm_nodal_t structure from the set of probes. More... | |
| fvm_nodal_t * | cs_probe_set_unlocated_export_mesh (cs_probe_set_t *pset, const char *mesh_name) |
| Define a fvm_nodal_t structure from the set of unlocated probes. More... | |
| void | cs_probe_set_dump (const cs_probe_set_t *pset) |
| Dump a cs_probe_set_t structure. More... | |
| void | cs_probe_set_get_members (const cs_probe_set_t *pset, cs_probe_snap_t *snap_mode, int *n_probes, cs_real_3_t *coords[]) |
| Retrieve the main members of a cs_probe_set_t structure. More... | |
| int | cs_probe_set_get_n_local (const cs_probe_set_t *pset) |
| Return the number probes in the local domain. More... | |
| const cs_real_t * | cs_probe_set_get_curvilinear_abscissa (const cs_probe_set_t *pset) |
| Return the list of curvilinear abscissa for the given probe set. More... | |
| const cs_lnum_t * | cs_probe_set_get_elt_ids (const cs_probe_set_t *pset, int mesh_location_id) |
| Return the ids of a probe set's local matching elements, relative to a given mesh location. More... | |
| typedef void() cs_probe_set_define_local_t(void *input, cs_lnum_t *n_elts, cs_real_3_t **coords, cs_real_t **s) |
If non-empty and not containing all elements, a list of coordinates as well as a list of curvilinear coordinates should be allocated (using BFT_MALLOC) and defined by this function when called. Those list's lifecycle is then managed automatically by the probe set object.
Note: if the input pointer is non-NULL, it must point to valid data when the selection function is called, so that value or structure should not be temporary (i.e. local);
| [in,out] | input | pointer to optional (untyped) value or structure |
| [out] | n_elts | number of selected coordinates |
| [out] | coords | coordinates of selected elements. |
| [out] | s | curvilinear coordinates of selected elements |
| typedef struct _cs_probe_set_t cs_probe_set_t |
| enum cs_probe_snap_t |
| void cs_probe_finalize | ( | void | ) |
| int cs_probe_get_n_sets | ( | void | ) |
| void cs_probe_set_add_probe | ( | cs_probe_set_t * | pset, |
| cs_real_t | x, | ||
| cs_real_t | y, | ||
| cs_real_t | z, | ||
| const char * | label | ||
| [in,out] | pset | set of probes |
| [in] | x | x coordinate of the point to add |
| [in] | y | y coordinate of the point to add |
| [in] | z | z coordinate of the point to add |
| [in] | label | NULL or the name of the point (optional) |
| void cs_probe_set_allow_overwrite | ( | const char * | name | ) |
If no a probe set of the given name exists, the operation is ignored.
| [in] | name | name of the probe set |
| void cs_probe_set_associate_writers | ( | cs_probe_set_t * | pset, |
| int | n_writers, | ||
| const int * | writer_ids | ||
| [in,out] | pset | pointer to a cs_probe_set_t structure to set |
| [in] | n_writers | number of writers assocuated to this probe set |
| [in] | writer_ids | list of writer ids |
| void cs_probe_set_auto_var | ( | cs_probe_set_t * | pset, |
| bool | mode | ||
| [in,out] | pset | pointer to a cs_probe_set_t structure |
| [in] | mode | true or false |
| cs_probe_set_t* cs_probe_set_create | ( | const char * | name | ) |
| [in] | name | name of the set of probes |
| cs_probe_set_t* cs_probe_set_create_from_array | ( | const char * | name, |
| int | n_probes, | ||
| const cs_real_3_t * | coords, | ||
| const char ** | labels | ||
| [in] | n_probes | number of probes in coords and labels |
| [in] | coords | list of coordinates related to each probe |
| [in] | labels | list of label related to each probe (optional) |
| cs_probe_set_t* cs_probe_set_create_from_local | ( | const char * | name, |
| cs_probe_set_define_local_t * | p_define_func, | ||
| void * | p_define_input | ||
The local definition function given by the p_define_func pointer is called just before locating probes on the parent mesh, so this allows building probe sets based on subsets of the computational mesh.
Note: if the p_define_input pointer is non-NULL, it must point to valid data when the selection function is called, so that value or structure should not be temporary (i.e. local);
| [in] | p_define_func | function used for local definition |
| [in] | p_define_input | optional input for local definition function |
| cs_probe_set_t* cs_probe_set_create_from_segment | ( | const char * | name, |
| const cs_real_t | start_coords[3], | ||
| const cs_real_t | end_coords[3] | ||
| [in] | n_probes | number of probes |
| [in] | start_coords | coordinates of the starting point |
| [in] | end_coords | coordinates of the ending point |
| void cs_probe_set_dump | ( | const cs_probe_set_t * | pset | ) |
| [in] | pset | pointer to a cs_probe_set_t structure |
| fvm_nodal_t* cs_probe_set_export_mesh | ( | cs_probe_set_t * | pset, |
| const char * | mesh_name | ||
| [in] | mesh_name | name of the mesh to export |
| cs_probe_set_t* cs_probe_set_get | ( | const char * | name | ) |
| [in] | name | name of the set of probes to find |
| cs_probe_set_t* cs_probe_set_get_by_id | ( | int | pset_id | ) |
| [in] | pset_id | id related to the set of probes to find |
| const cs_real_t* cs_probe_set_get_curvilinear_abscissa | ( | const cs_probe_set_t * | pset | ) |
| const cs_lnum_t* cs_probe_set_get_elt_ids | ( | const cs_probe_set_t * | pset, |
| int | mesh_location_id | ||
The mesh_location id must match one of CS_MESH_LOCATION_CELLS, CS_MESH_LOCATION_BOUNDARY_FACES, or CS_MESH_LOCATION_VERTICES.
| [in] | mesh_location_id | id of parent mesh location |
| const char* cs_probe_set_get_location_criteria | ( | cs_probe_set_t * | pset | ) |
| void cs_probe_set_get_members | ( | const cs_probe_set_t * | pset, |
| cs_probe_snap_t * | snap_mode, | ||
| int * | n_probes, | ||
| cs_real_3_t * | coords[] | ||
| [in,out] | snap_mode | mode of location |
| [in,out] | n_probes | number of probes |
| [in,out] | coords | probe coordinates |
| int cs_probe_set_get_n_local | ( | const cs_probe_set_t * | pset | ) |
| const char* cs_probe_set_get_name | ( | cs_probe_set_t * | pset | ) |
| void cs_probe_set_get_post_info | ( | const cs_probe_set_t * | pset, |
| bool * | time_varying, | ||
| bool * | on_boundary, | ||
| bool * | on_curve, | ||
| bool * | auto_variables, | ||
| int * | n_writers, | ||
| int * | writer_ids[] | ||
Output arguments may be set to NULL if we do not need to query them.
| [out] | time_varying | true if probe locations may change with time |
| [out] | on_boundary | true if probes are located on boundary |
| [out] | on_curve | true if the probe set has cuvilinear coordinates |
| [out] | auto_variables | true if set of variables to output is predefined |
| [out] | n_writers | number of associated user-defined writers, or -1 if default unchanged |
| [out] | writer_ids | pointer to a list of writer ids |
| void cs_probe_set_locate | ( | cs_probe_set_t * | pset, |
| const fvm_nodal_t * | location_mesh | ||
For better performance when using multiple probe sets, a pointer to an existing location mesh may be passed to this function. The caller is responsible for ensuring this mesh matches selection criteria for the probe set.
| [in] | location_mesh | optional pointer to mesh relative to which probe set should be located, or NULL |
| void cs_probe_set_option | ( | cs_probe_set_t * | pset, |
| const char * | keyname, | ||
| const char * | keyval | ||
Available option key names accepting true or false:
transient_location if true, relocate probes relative to deforming or moving mesh (default: false)boundary if \ c true, locate on boundary mesh; if false, locate on volume mesh (default)Other options:
selection_criteria where keyval is selection criteria stringtolerance where keyval is for instance "0.05" (default "0.10")| [in,out] | pset | pointer to a cs_probe_set_t structure to set |
| [in] | keyname | name of the keyword related to the parameter to set |
| [in] | keyval | value of the keyword to set |
| void cs_probe_set_snap_mode | ( | cs_probe_set_t * | pset, |
| cs_probe_snap_t | snap_mode | ||
| [in] | snap_mode | snap mode to set |
| fvm_nodal_t* cs_probe_set_unlocated_export_mesh | ( | cs_probe_set_t * | pset, |
